Question about Garden
Landini mythos 110 . 3 point linkage slowly coming to a halt. Pump still works okay. Checked pressure on remotes. I suspect main lifts with in cab. Mudguard switches not working either.
3 Suggested Answers
wadembly
  • 513 Answers
SOURCE: 3 point linkage cant lift anything sometimes works
check the hydrolic fluid & pump if low on fluid then it wont lift or the pump might be going out
Posted on Jun 14, 2009
  • 218 Answers
SOURCE: ford 9n 3 point will not lift
Hey Chris..my name is Keith..and i restore 9N's,2N's and 8N's ..and i can help you with your hydraulic problem...the most probable cause is the hydraulic safety relief valve and i would change that 1st..the part number for it is..8N-638..and they cost about 25 dollars..and to change it..you either jack up the rear axle or you part the tractor down hill..so the hydraulic fluid goes to the front..and then you open up the side cover..that has the dip stick in it and unscrew the Safety relief valve from the hydraulic pump9located on the back side of the pump)..and install a new one..and have plenty of rags..because it is a mess job..and if you dont want to opent that cover again..i would replace the hydraulic control valve..part number 9N-640..is costs about 35 dollars and its on the back side of the pump also..and dont forget to get a new cover gasket and that part number is 9N-4131 and it costs about 1 dollar..i hope this has helped..if not write me back and we will get into the hard stuff on the hydraulic system
Posted on Jun 30, 2009
Why doesn't it scan correctly?
Hi Anonymous,
This is really difficult to answer without seeing the problem first hand.
If you suspect a possible problem with the scan motor then you could switch off completely remove the mains plug. remove the scan glass carefully clean it (It's always worth a clean both side when you have it removed.
Now mark a tiny on the metal work where the sense carriage is parked up at, so you can move the carriage manually and return it back to the start position.
Now once you have axis to the sense carriage you can move it slowly and I mean slowly across the scan table all the way to the other side, it should be smooth running once your part way across you could take a look at the mirrors if your confident enough carefully clean them with a lint free cloth. (use, hardly any pressure on the cloth to remove any dust)
Now when you get to the point where your scanner stopped when under power, can you feel anything that would bring your mirror carriage to a halt at this point.
If it's nice and smooth then return it back to the starting mark you made earlier replace the glass and switch back on.
Once your printer has returned back to ready, try another scan
If not look for error messages and go from there.
Finally try and work through the service menu something that would checkout the action of the scan unit.
Good luck.
Jun 19, 2015 | Xerox Phaser 3100MFP/S Laser Printer
My 1976 allis Chalmers three point won't lift up and the PTO won't stay engaged. Everything on this tractor is run by hydraulic pumps. There are 3 pumps on this tractor. A piston pump, a gear pump, and a...
I would try checking the remote valves, maybe undo the line at each one and see where your pressure is stopped and maybe you can work down to where whitch with valve is not working..
Jan 29, 2015 | Garden
Clutch on landini mythos 115 tractor needs calibrating
Hello, for landini mythos 110 delta five, l need software landtools 4.4 or 4.5. Do you have it?
Jul 24, 2014 | Garden
99 explorer 4.0 new fuel tank & fuel pump,fuel filter. fuel flows through fuel line & up to the pressure regulator. vechile will start run for few seconds everytime ignition is turned over. vechile ran...
Hi Kenneth, Have the fuel pump output pressure checked. The pressure at the test point should be more than three bar (+43 lbs per square inch) A gentle trickle is not enough, it should be a fountain! (Always wear safety googles before testing) Make sure you've connected the delivery and return pipes correctly and the pipes are not crimped or bent causing a restriction. If all is okay maybe replace the pump again. Regards John
Oct 06, 2013 | 1998 Ford Explorer
Kenmore model 110
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows though the inlet then the flow pressure should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Test a pressure switch: Click on : http://www.youtube.com/watch?v=HZZ2bDMspj8
Check this link to replace the inlet valve:
http://www.espares.co.uk/advice/washing-machines/a/7/1408/how-to-replace-the-inlet-valve-on-a-washer-dr.html
Sep 27, 2013 | Washing Machines
Bosch dishwasher power light flashing Water to unit, power ok, drain pump runs, When cap lifted, door shuts fully No.- scs43a32uk/01
It is possible that the machine does not start off the cycle because there are errors or feedback from the inputs. For the program to start up the main program controller must initiate the INLET/PUMP MOTOR/DRAIN to work when it is commanded .If this does not happen then the voltage at these points must be checked or the fault relates to no voltage/drive from the controller. This means the controller is a suspect.
So a voltage check is most important to find the fault and must be probed.
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor. The water pressure must be good and the spraying must be seen to be good. If there is low pumping or pressure then the spray arms will not turn around to inject with pressure. If so the pump must be checked for clogging.
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the drain valve/pump activated so as to drain off all the water.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
http://www.espares.co.uk/advice/dishwashers/a/3
Thank You for using Fixya
Aug 19, 2011 | Dishwashers
Driver side wind sheild wiper not working - passenger side wiper okay. driver side moves a little.
You have an assembly of arms that hook to motor one for each side sounds like your left one has come loose or is at least slipping you will have to remove the crowl panel at the wipers to check .The wiper is held on by a nut. The nut is under a plastic cover at the pivot point of the wiper. Loosen the nut then align the wiper blade where it's supposed to be then tighten the nut.Its not adjusted right, remove the nut that holds your left wiper on, then pry it off the shaft, lift the wiper up all the way then just pull up straight off the shaft, then put it back on so it starts at the left lower edge of the windshield.---- First, start by checking the nut at the base of the wiper arm, if it is good and tight, then you have to remove the cowl and check the wiper linkage.If the linkage has come apart then you will have to replace the piece that has come loose.------
Getting, this possibilities checked will help.Thanks.Helpmech.
Aug 14, 2011 | Kia Sportage Cars & Trucks
3 point linkage cant lift anything sometimes works ok then for no apparent reason stops working and wont lift anything
Jun 13, 2009 | Garden
I have 2003 f350 super duty hickups when driving down the road
Okay, Thanks.
The diesel engine runs on air and fuel. The hick up is from air getting into the system. The injection timing is off. or the fuel injection pump is starting to go. The fuel pump in the tank should be okay because you are getting fuel up to the filter replaced in the engine. I would have the fuel injection pump pressure checked. IF the fuel pressure is good then I would check the fuel injectors and the linkage. The slightest leak in the fuel system from an o ring or filter makes all the difference in the world.
Good luck
Mar 15, 2009 | 2005 Ford F 350 Super Duty
Garden Logo
37 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
