Question about Transmission & Drivetrain for Chevrolet R10
1987 chevrolet r10 transmission and shift module problems
I believe my shift module is out i replaced my transmission and it's still like the transmission is out. what could it be and how can i fix this?
    Problem Solver:
  • 11 Answers
When worked with Hertz corporate I had major problem with Ford and similar condition on one Chevy - added one routine maintenance check - the vacuum line that drives the transmission - Ford had a metal tube that was pinched where it went over the transmission and Chevy had a problem that vacuum line was against heated item and burned to point it was hard and had leak. Both missed by mechanics and specialists. I traced line above and then elevated vehicle to continue the trace - modified with combination of flex and metal connector.
Posted on Apr 07, 2014
Suburban troubleshooting
Check the wires in the diagnostic connector. Especially in the A & B slots. I believe the B slot wire is a ground wire-check it for integrity-may be broken.
Apr 06, 2014 | 1987 Chevrolet R10
Trans will not shift i have to let off the gas to get it to shift is the relay bad and were is it
Which transmission? My 87 with a Turbo 400 uses a vacuum modulator. In that case it's a vacuum line or the modulator that's the problem. The modulator is a little "mushroom" on the passenger side of the ******. Pretty obvious with a vacuum line going to it.
Oct 06, 2012 | 1987 Chevrolet Suburban
I was wondering if a 1986 400 transmossion would fit a 1987 chevy silverado r10?
is it a electronic transmission, or manual! this makes the difference! call a ****** shop to get more info on this. good-day!
Oct 04, 2011 | 1987 Chevrolet R10
I have a 1987 Chevy R10 Custom Deluxe with a 305. When I put the truck into reverse or drive it dies.
sounds like a TCC problem (torque converter)
could be stuck valve or defective converter
May 28, 2011 | 1987 Chevrolet R10
My 1987 Chevy r10 cranks but wont start. i was driving and it just shut off like you switched the key off. i have no spark and injectors don't energize as well.
It is most likely the ignition module,have it tested,if it test good,replace the pick up coil in the distributor,this pulses the injectors.
Jun 26, 2010 | 1987 Chevrolet R10
1987 chevy truck the ignition module keeps burning out what could be causeing this.
need more input, how often do you change it how many miles on motor, are you appying the grease on the bottom of it, are there any cracks on the wires to it
Apr 25, 2010 | 1987 Chevrolet R10
1987 Chevy R10 project truck won't start
check the float on the carb is stuck shut not letting fuel in
Aug 17, 2009 | 1987 Chevrolet R10
Transmission Control Module
Before condemning the transmission, I would check the shift cable for proper operation. Look at the side of the transmission where the shift cable attaches. Have someone shift the transmission from PARK to FIRST. The engine should not be running. If the operating lever on the transmission moves, then you probably do have an internal transmission problem. 78151957.gif
If the operating lever does not move, you have a broken shift cable or it has popped of it's attachments at the operating lever or gear shift handle.
A bad Transmission Control Module (TCM) would not keep it from shifting. In the event of a bad TCM, the transmission would go into fail safe mode and you could continue driving the vehicle.
Apr 28, 2009 | 2005 Chevrolet Suburban
After market power module for a 1987 Chevy Sprint
You might be able to find a turbo or purchase it from chevrolet. 1987-1988 there was actually a turbo chevrolet sprint it came in two colors red and white it boosted horsepower from 44 to 70 this doesn't seem like a lot but when you put it in a light car its gives it a boost. I do believe the turbo option was only available with the 5-speed transmission.
May 15, 2008 | 1985 Chevrolet Sprint
Vehicle Parts & Accessories Logo
61 people viewed this question
Top Chevrolet Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Mike
Are you a Chevrolet Vehicle Part and Accessory Expert? Answer questions, earn points and help others
