Question about Kitchen Appliances - Others
Bizerba mci-w Failed to open MCI device, error code: feler 034 20
2 Suggested Answers
  • 161 Answers
SOURCE: Failed to open MCI device. Error Code: 348745
Click on this link: -
http://support.microsoft.com/kb/142731
Posted on Jan 14, 2010
My Parents Have Been Without Phone Home Service Since The Last Cold Freeze Mid January,They are Elderly and Need The Phone also My Younger Brother has Seizures and The Phone is a Necesity,They Got MCI
You should contact a trusted friend, local municipality social services, or church, and ask for help.
FIXYA is a question and answer site, and has nothing to do with MCI phone service.
Feb 22, 2018 | Brother Cell Phones
My 73" mitsubishi dlp WD-73827 turns off and has a red status light blinking. I have replaced the bulb and the heat sensor... any answer to what else could be the problem?
It is helpful to have the sequence of the blinking red light. This may help:
MODELS: WD-52627 / 52628 / 62627 / 62628 / 62827 / 62927 / 73727 / 73827 / 73927
Page 43
3. Error Code Operational Check
Note: The TV must be in "Shut Down" and not have been switched Off, to perform the Error Code Operational
Check. When the TV is switched Off, the code automatically resets to "12" No Error.
Pressing the front panel "DEVICE" and "MENU" buttons at the same time, and holding for 5 seconds,
activates the Error Code Mode. The LED flashes denoting a two digit Error Code, or indicating no problem
has occured since the last Initalization.
Note: The front panel buttons must be used, NOT those on the Remote Control.
• The number of flashes indicates the value of the MSD (tens digit) of the Error Code.
• The flashing then pauses for approximately 1/2 second.
• The LED then flashes indicating the value of the LSD (ones digit) of the Error Code.
• The Error Code is repeated a total of 5 times.
Example: If the Error Code is "23", the LED will flash two times, pause, and then flash three times.
4. Error Codes
The Error Code designations indicating malfunction, or no malfunction, are listed below:
POWER
LED
STATUS
LED
LAMP
LED
Power
Status Condition
Off Yellow Off Low
Power Excess heat. Check Lamp Filter
Off or On Off Yellow No
change
120w usage time over 7000 Hrs.
150W usage time over 3500 Hrs.
Off Off Blinks
Yellow
Low
Power Lamp Cover open
Off Blinks
Yellow Off " Filter Cover Open
Off Off Red Stby Lamp did not turn On
Off Blinks
Red Off Low
Power Fan Stopped
Off Red Off " Circuit failure (short or DVI
connector unplugged)
Abnormal LED Indications
Error Codes "DEVICE" & "MENU"
Error Codes Description
12 No error detected
22 Recovery from Reset
32 Lamp cover is Open
34 Lamp abnormality
35 DM Fan failed (Chassis Fan)
36 Exhaust or Lamp Ballast Fan failed
37 DMD Engine Fan failed
38 Lamp temperature abnormally high. Remove Lamp to check filter.
39 DMD temperature abnormally high
41 Short is detected (Standby Power Supplies)
42 Lamp Fan failed
44 DVI cable between Format and Engine disconnected
46 DMD Temp. Sensor not detected (check DT connector))
47 DM Temperature too high
48 Engine power supply short detected
51 Speaker Drive circuit short detected
52 HDD excess temperature (V30+ & V31 only)
55 HDD Fan Stopped (V30+ & V31 onlyt)
Jul 18, 2014 | Mitsubishi WD Televison & Video
Device open
Try restart the whole machine or restart the installer, if its a problem or frozen try hold Control+Alt+Delete and the go on "Task Manager" right click the installers name displayed on the Task manager and click End Process
Oct 04, 2013 | Microsoft XP Computers & Internet
Error # 57=usb port not working
I will be happy to assist you with that.
You get this error code if there is an issue with the drivers.
One of the drivers controlling the device notified the operating system that the device failed in some manner.
I would suggest that you run a hardware troubleshooter.
Open the Hardware and Devices troubleshooter by clicking the Start, and then clicking Control Panel. In the search box, type troubleshooter, and then click Troubleshooting. Under Hardware and Sound, click Configure a device.‌ If you're prompted for an administrator password or confirmation, type the password or provide confirmation.
Refer the link: Open the Hardware and Devices troubleshooter: http://windows.microsoft.com/en-us/windows7/Open-the-Hardware-and-Devices-troubleshooter
Refer the link to learn more about the error codes: Explanation of error codes generated by Device Manager in Windows XP Professional: http://support.microsoft.com/kb/310123
This article is also applicable for Windows 7.
I would also suggest that you manually download the drivers for the device from the manufacturer’s website and install the latest drivers and check
May 15, 2010 | E-Machines eMachines Desktop PC
Kitchen Appliances - Others Logo
47 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
