Question about Microsoft Windows XP Professional
How to solve stack overflow at line 207 - Microsoft Windows XP Professional
    Master:
  • Microsoft Master
  • 561 Answers
Re-install
Posted on Feb 12, 2014
Stack overflow over line 207
  • Start IE
  • Settings/Internet Settings/Advanced
  • Tick the " Disable Code Debugging "
  • Uncheck "Display a notification about every script error"
  • Go into control panel Add or remove programs or Programs and features at the top put a check in the box before show updates or upper left side put a check in the box before show updates double click on Internet Explorer (your version) This will uninstall Internet Explorer (your version) then reboot your computer. When it is all up again search google for Internet Explorer (your version) download
    Download it and install it then reboot again and see if that fixed your problem.
Mar 04, 2014 | Microsoft Windows XP Professional
How to solve stack overflow line 207?
every time coming stack overflow at lin207
Feb 07, 2014 | Microsoft Windows XP Professional
Error message stack overflow line 207
Terry
Feb 03, 2014 | Microsoft Windows XP Professional
"Stack overflow at line 0"
b> A stack is a section of memory where a program stores its variables, calculations, option states and program parameters. When started, a program is allocated some memory to use for the stack; a stack overflow happens when a program exceeds its allocation. The offending program may attempt to write into adjacent memory sections, causing conflicts with other programs. Stack overflows are common with Java, C++, Perl and other runtime environments, which assist in running programs. A stack overflow at line 0 indicates that the offending program tripped up from the start; however, stack overflows can occur on any line number.
Click "Start," "Control Panel, then "Internet Options." Click on the "Advanced" tab. Check "Disable Script Debugging (IE)" and "Disable Script Debugging (Other)" under the "Browsing" options. Uncheck "Display a notification about every script error." Check "Enable Automatic Crash recovery." Click "OK." Download and install a Java update from the Java website. http://www.java.com/en/download/manual.jsp Download and install a Windows update. Hope this helps.
Dec 24, 2012 | Microsoft Windows XP Professional
Stack overflow at line 3400?how to help that?
What is a stack overflow?
In software, a stack overflow occurs when too much memory is used on the call stack. The call stack contains a limited amount of memory, often determined at the start of the program. The size of the call stack depends on many factors, including the programming language, machine architecture, multi-threading, and amount of available memory. When too much memory is used on the call stack, the stack is said to overflow, typically resulting in a program crash.(http://en.wikipedia.org/wiki/Stack_overflow)
Please Note: Since the website is not hosted by Microsoft, the link may change without notice. Microsoft does not guarantee the accuracy of this information.
Mostly, this issue is caused by software conflict. Please take following steps to check if it is a add-ons issue.
1. Open Internet Explorer by clicking the Start button, and then clicking Internet Explorer.
2. Click the Tools button, and then click Manage Add-ons.
3. Under Show, click All add-ons.
4. Click the add-on you want to disable, and then click Disable/Enable.
5. Repeat step 4 for every add-on you want to disable/enable. When you are finished, click Close.
Jul 03, 2011 | Computers & Internet
Stack overflow is created by BAD SOFTWARE. When it occurs not only does the
program crash, but depending upon other situations, special code may get called in
such a way as to literally 'take over the system'.
Stack overflow is an exploit that is used by many virus'. As most of these are
intentionally induced by buffer overflow, software updates are the typical fix to
avoid the condition.
1) make sure you have the latest fixes for your browser
2) stay current with MS Update
3) install Spywareblaster to avoid bad ActiveX *.ocx files
Jan 18, 2011 | Sierra Online, Inc. You Dont Know Jack 2
Computer pop up
IE: stack overflow at line: 0 Today, I noticed the following issue (IE only, of course). Running a page that does some comet (via “XHR GET” for long-polling), I got the following warning: “stack overflow at line: 0′ and the application stopped working…
I did some google-searches and found some “hints” that said I should disable my third-party tools for IE etc. That sounds strange…
In fact the problem was the odd cache behavior of the IE. The XML (from the “long-polling servlet”) was cached and its JS was executed; also the application itself started the polling too, so I (no IE) ran into this odd issue…
Changing the server-side code – that is responsible to render the XML – to have no cache rules (e.g.”Cache-Control”:”no-cache”) did the trick. It worked again. Of course, on your “comet output” you potentially don’t want cache to be present…
So fixing the cache solved the issue. There was no need to disable Norton or any other third-party tool… icon_smile.gif
Mar 28, 2010 | Microsoft Windows XP Home Edition
Hello i have a toshiba 1555cds and i got a
Changing the stacks setting can be done by editing the config.sys with any editor such as notepad. However, I doubt doing this will solve anything. A stack overflow error is usually a CPU chip problem.
Aug 14, 2009 | Toshiba 10GB NOTEBOOK HARD DRIVE KIT...
Microsoft Windows XP Professional Logo
309 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
