Question about Xerox Office Equipment & Supplies
U3 error in xerox 5016
Xerox 5016
  • 239 Answers
SOURCE: i have a xerox 5016 copier ,
On this model, yes it can be the fuser thermistor, fuser relay, driver board, main board, especially the fuser fan turning very slow not up to speed.
Any of these combination can be a problem.
Also, there can be bad fuser rod connections that can cause this type of problems, and can only be repaired by a Xerox Service Representative.
Posted on Oct 16, 2009
  • 239 Answers
On this model sometimes the plugs on the connectors go bad.
They arc and will not connect good. Sometimes the ends have to be clipped and new pins male and female have to be crimped back on, replacing them on the machine part wiring connectors and fuser rod ends. this fuser kit is a part that is availiable at xerox.
A bad thermistor can cause this type of problem. If the machine overheats, the fuser triac pack can cause over heat problems as well.
On overheats the fuser fuse needs to be replaced. Do not replace with nothing else but a Xerox fuse, this is a safety device. Very important.
Otherwise place a service call to have this area repaired by xerox.
Posted on Oct 26, 2009
SOURCE: I have Xerox 5016 model
Enter into the diagnostic mode.Press 50 then green button,press 20 then green button,press 00 then green button.Switch off the machine & Switch On.
Posted on Feb 14, 2011
ZJLimited
  • 17970 Answers
SOURCE: xerox 5016 error code u70
Error U7, U7-1 (Photoreceptor Belt Drive)
Appears when the Copy Cartridge has Not Been Replaced.
Posted on Apr 27, 2011
SOURCE: xerox 5016 copier error j6
error no.j6 asking how to swallow prablam
Posted on Oct 16, 2012
Xerox 5020 u3 code reset
como resetear o resolver el problema del codigo error u3 xerox wc5020
Jan 29, 2013 | Office Equipment & Supplies
Xerox 5016 error code u70
Apr 27, 2011 | Xerox Office Equipment & Supplies
I have Xerox 5016 model Photocopier , I am getting Error U4 ,some technican from Xerox advised that it can be solved by pressing some button ..? If anyone can support would be a great help.
Jan 15, 2011 | Office Equipment & Supplies
Xerox 5016 copier error j6
Dec 27, 2010 | Xerox WorkCentre XD100 All-In-One Laser...
I have a xerox 5016 copier ,
All U4 codes on Xerox machines relate to the "fuser".( That's the hot bit on the way out) You will find the rollers fail to warm up, or reach correct temperature .
Most often the heater rod inside has burned out, or sometimes the overheat thermostat goes open circuit.Both problems will require the fuser unit pulling out of the machine and a test meter to check continuity of the components
Jan 07, 2008 | Office Equipment & Supplies
62 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
