Question about Microsoft Windows XP Professional
Error message stack overflow at line 207 - Microsoft Windows XP Professional
    Master:
  • Microsoft Master
  • 561 Answers
During what?
Posted on Feb 12, 2014
2 Suggested Answers
potek18
  • 528 Answers
SOURCE: Computer pop up
IE: stack overflow at line: 0 Today, I noticed the following issue (IE only, of course). Running a page that does some comet (via “XHR GET” for long-polling), I got the following warning: “stack overflow at line: 0′ and the application stopped working…
I did some google-searches and found some “hints” that said I should disable my third-party tools for IE etc. That sounds strange…
In fact the problem was the odd cache behavior of the IE. The XML (from the “long-polling servlet”) was cached and its JS was executed; also the application itself started the polling too, so I (no IE) ran into this odd issue…
Changing the server-side code – that is responsible to render the XML – to have no cache rules (e.g.”Cache-Control”:”no-cache”) did the trick. It worked again. Of course, on your “comet output” you potentially don’t want cache to be present…
So fixing the cache solved the issue. There was no need to disable Norton or any other third-party tool… icon_smile.gif
Posted on Mar 28, 2010
Testimonial: "Very helpful. Thanks for the information."
Stack overflow over line 207
  • Start IE
  • Settings/Internet Settings/Advanced
  • Tick the " Disable Code Debugging "
  • Uncheck "Display a notification about every script error"
  • Go into control panel Add or remove programs or Programs and features at the top put a check in the box before show updates or upper left side put a check in the box before show updates double click on Internet Explorer (your version) This will uninstall Internet Explorer (your version) then reboot your computer. When it is all up again search google for Internet Explorer (your version) download
    Download it and install it then reboot again and see if that fixed your problem.
Mar 04, 2014 | Microsoft Windows XP Professional
How to solve stack overflow line 207?
every time coming stack overflow at lin207
Feb 07, 2014 | Microsoft Windows XP Professional
Error message stack overflow line 207
Terry
Feb 03, 2014 | Microsoft Windows XP Professional
Stack over flow at line 195
This comes directly from Microsoft web page.
"If you try to open multiple modal dialog boxes in either of the following programs, you may receive a stack overflow error message:
  • Microsoft Internet Explorer 6 on a Microsoft Windows Server 2003-based computer
  • The Mshta.exe HTML program"
They say they have a hotfix so go to this page.
Jan 12, 2014 | Microsoft XP Computers & Internet
"Stack overflow at line 0"
b> A stack is a section of memory where a program stores its variables, calculations, option states and program parameters. When started, a program is allocated some memory to use for the stack; a stack overflow happens when a program exceeds its allocation. The offending program may attempt to write into adjacent memory sections, causing conflicts with other programs. Stack overflows are common with Java, C++, Perl and other runtime environments, which assist in running programs. A stack overflow at line 0 indicates that the offending program tripped up from the start; however, stack overflows can occur on any line number.
Click "Start," "Control Panel, then "Internet Options." Click on the "Advanced" tab. Check "Disable Script Debugging (IE)" and "Disable Script Debugging (Other)" under the "Browsing" options. Uncheck "Display a notification about every script error." Check "Enable Automatic Crash recovery." Click "OK." Download and install a Java update from the Java website. http://www.java.com/en/download/manual.jsp Download and install a Windows update. Hope this helps.
Dec 24, 2012 | Microsoft Windows XP Professional
A message just "popped up"
It has to do with memory. When you make requests of your computer programs it puts those requests in a stack (or pile) and then works on them in a predefined order. There's a certain amount of memory reserved for the stack and when you exceed it you get a stack overflow error. These errors usually either kill the request or result in a program crash.
Jan 28, 2011 | Microsoft Computers & Internet
Shows up stack overflow at line 46 when on the net
A stack overflow is a program error.  If you're not a programmer, the only thing you can do is replace whetever program is giving you the error....it's broken.
http://en.wikipedia.org/wiki/Stack_overflow
Mar 09, 2010 | Computers & Internet
Stack overload at line 48
You hav run out of stack space. This means you have gone into too many levels of subroutines for example and have insufficient storage allocated for the return vectors and variables.
You will have to increase memory available for the stack, or have less levels of subroutines.
You may also hava a re-entrant subroutine that keeps calling itself until the return stack overflows.
Jan 02, 2010 | Computers & Internet
Microsoft Windows XP Professional Logo
101 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
