Question about Pelikan Pelican 2000 Super Sabrelite Dive Flashlight - Yellow
O-ring lubrication How can I lubricate the o-ring if I don't have silicone grease?
Brine tank fills but doesn't draw it back into the water sosftener
Your injector is stuck. Your manual should show you, at the least,
a diagram; you'll need to clean out the center of the injector and lubricate the seals or o rings with silicone grease. You cannot use Vaseline; it'll attack the rubber. You should bail out the excess water from your salt tank. After you've got rid of the particle of dirt from the venturi in the injector and lubricated the seals or o rings with silicone lubricant, reassemble. Three manual regenerations over the next three days should bring your softener back to full function.
Mar 01, 2015 | Kenmore 350 Series Water Softener
Tip
Slow wipers
Try lubricating the linkages as these become quite stiff and slow or stop motor.
Under the bonnet there should be a cover over the scuttle between the engine compartment and the windscreen.
Remove the plastic cover, usually fixed by a rubber seal that seals the engine compartment against the bonnet.
Lubricate and clean the joints on the linkages with silicon spay. As the linkages move freely finish up with a grease spray to provide continuing lubrication. Copper grease spray is probably best.
Reassemble cover.
Probably best to repeat after a few weeks and/or if the wipers slow to ensure that there is continuing lubrication
on Mar 12, 2015 | Audi Cars & Trucks
Audi allroad winscreen wiper motor
Hi
Reassemble cover.
Feb 25, 2015 | Audi Cars & Trucks
DOORS DONT CLOSE TIGHT HEAR ROAD NOISE
While it is not common for a vehicle of that age, it is possible the rubber seals around the doors are aged enough to allow small amounts of air and noise to enter. If you can see physically the door isn't closed fully, check the closing points for lubrication as in 10 yrs the lubrication can collect rain, dust, silt, etc causing it not to function as it once did. Often times you may need to use a silicon spray to help remove the old lubrication and apply fresh. Silicon spray by itself will not provide proper lubrication for long. A local auto parts store should be able to recommend something for this. I most often use marine bearing grease as it stands up better to moisture.
Dec 03, 2014 | 2004 Ford Freestar
The "O" ring seems to be leaking
Most softener heads are tightened to a minimum of 20 ft. lbs. to seal and not leak. If yours leaks after you tighten it (a quick sharp clock-wise twist will do fine) you should see your brand's local dealer and buy a new tank O ring. This must be lubricated with silicone grease. Petroleum based lubricants will degrade rubber. If you are looking for a new dealer or a more knowledgeable dealer visit wqa.org and find your local Certified Water Specialist.
Sep 03, 2014 | Water Dispensing & Filtration
Need to lubricate an o-ring
Silicone lubricant is far ahead as the recommended stuff, but OK.... Vaseline is out as it is petroleum based, although yours is not a critical application. So try lanolin, hand cream, KY jelly or similar, soap, wax or spit.
Feb 07, 2014 | Cars & Trucks
Just replaced o rings in kitchen faucet but where do I put the silicone grease? Thanks
you put the silicone grease on ever rubber part, the o rings washers and stops
Oct 24, 2010 | Moen & Replacement Cartridge
Is there a grease fitting or a way to lubricate the mechanics that raise and lower the top?
use silicon spray with a cloth behind to stop overspray,do not use grease.(wd40 is another lubricant you could use....)
Jul 04, 2010 | 1999 Porsche 911 Carrera
I have a mega max 3001 multigym do i need to grease the cables and bar that holds the weights.
The only thing that needs lubrication is the guide pole that hold the weight plates with silicone Napa or Pyrol brand is good and apply depending usage at least once a week. Procedure is use a cloth spray lubricant into cloth and rub cloth onto poles this clean and lubricate.
Apr 26, 2010 | Ironman Exercise & Fitness
I have parker super o lube for o-ring lubrication silicone base. Please advise may i using this silicone oxygen cylinder O-rings.
No. Silicone is not approved for O2 use. Can ignite under high O2
concentration/pressure. If approved for O2 use, the MDSS or labeling on the package will indicate so.
Oct 23, 2009 | Oxygen Lubrication Technology Christo-Lube...
Pelikan Pelican 2000 Super Sabrelite Dive Flashlight - Yellow Logo
Top Pelikan Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a Pelikan Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
