Question about Karcher Garden
Karcher k500 Attachment head not spinning
Karcher surface cleaner attachment does not rotate.
This video maybe helps you. Try to watch the video very carefully. Otherwise, you have to buy a new pressure washer surface cleaner. Before buying a new surface cleaner plz read buying guide of pressure washer surface cleaner
Sep 28, 2013 | Karcher Garden
Karcher paatio cleaner attachment cleaning in suiggly lines
Squiggly lines are sign of nozzles being partially clogged. Try using a needle to clear nozzles. You will need to remove the nozzles to do this. When re-installing the nozzles make sure they are in line with the pressure bar.
Mar 13, 2013 | Karcher KE302007A Classic Series Pressure...
Ryobi weed eater head won't spin
Sounds like the clutch has taken a long trip south. If the clutch pads are not wore out, try some wd40 on the pad hinges.
Apr 27, 2010 | Ryobi Garden
I am trying to clean my block paving using my pressure washer Karcher 3.99, which I used successfully last summer, however, it is not cleaning well. I have used the high power nozzle but the power seems...
Hello Sue, you don't say where in the world you live, but if you are attempting to clean dirt and algae off pavers, you need to add a solution to the water jet via the inbuilt attachment. Mix a fairly mild solution of bleach and detergent, pus a dash or deodoriser to the cantainer. Put your karcher on low pressure and give all the blocks a good wetting. Do this in the morning so the solution doesn't dry. After 20 ~30 mins, Claen off with the Karcher on normal high pressure (not the tubo lance). HINT: Leave the trigger on all the time and don't stop and start using it. This will prevent hayraulic hammer which can split the pump head.
Apr 11, 2010 | Karcher Garden
When the patio cleaner is attached,the Karcher 5.68 pressure washer now keeps stopping and starting.It works fine on high pressure lance.It worked fine when bought from new a few days ago. We tried...
None of these fixes works for me and the original poster, like me what he's saying is when he swaps the high pressure lance for the patio attachment it pulses on and off, but when that happens, you can swap back to high pressure lance and it's fine. This means it's the patio attachment not any valves or power source, I have the same problem
Mar 09, 2010 | Karcher Garden
Troy Bilt 4 cycle weed eater - trimmer head doesn't spin
rotate attatchment head slightly while inserting driveshaft
Jul 30, 2009 | Garden
ONE OF THE SPRAY HEADS IN PATIO ATTACHMENT SEEMS BLOCKED
simple. find the smallest drill bit to fit the hole and run bit thru it. wala.
Aug 04, 2008 | Karcher 2500 PSI Pressure Washer
I purchased the karcher for kids washer and can't connect to garden hose...is there some attachment neded??
there should have been an adapter from the factory on it. if not you can go to the dealer and get one.
Jun 28, 2008 | Karcher 2500 PSI Pressure Washer
Garden Logo
14 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
