Question about Samsung Cameras
How to repair DA-F61 Samsung - Samsung Cameras
F61 Error on SA-HT930 Panasonic
As sugested by many experts.I replaced the ic no rsn311w 64d,still the error code f61 appears.Now where is the fault.?
this is for the Panasonic sa-ht 880.
Aug 28, 2012 | Panasonic sa-ht930 Home Theater Audio...
MY MUSIC SYSTEM PANASONIC AK88 THIS SYSTEM ERROR IS F61 PLEASE DIOGRAM OF REPAIR IN MY SYSTEM
As far as the fan is concerned, please reject it as ak-88 is not equipped with 1. the f61 is the errror code for blown power supply ic, you have to get it changed.I have the same system and 2 times i had the same problem. IC is stk 470 0405_28_2012_9_55_21_am.jpg
Feb 27, 2012 | Audio Players & Recorders
What does f61 mean?
F61 is an error code.
It will automatically shuts down your unit.
This is very common on your unit.
Try to checked if the fan is working or not.
I have repaired some unit before, this is the caused why f61 appeared.
The symptom is shutting down the unit after a few minute.
If the fan is not working it will shuts off automatically to avoid further damaged to your output I.C.
If confirmed that the fan is working then I've suspect that your output I.C. is shorted.
This is quit technical and need to send to repair shop to isolate the faulty parts.
The output IC of your unit is RSN series and quite expensive.
Pls rate my help.
Thaks for using fixya...
Jan 16, 2011 | Panasonic SC-AK18 CD Shelf System
Error F61 Panasonic SA-AK240
am o combina muzicala marca panasonic modelul sa-ak240 si imi da o error f61,dupa ce o aprind la nici un minut imi da error f61 apoi se stinge.din ce cauza ma puteti ajuta??veri.nice78@yahoo.com astept un raspuns
Sep 08, 2010 | Audio Players & Recorders
Error F61 on Panasonic Stereo System SA-AK80
HELLO
As far as I can know, F61 means your output IC is dead. Contact a service centre in your locality for repair!
May 12, 2010 | Panasonic Home Theater System System
F61 is showin up on my system ,an it wouldn stay on
It is the digital amp IC damaged.
Need replacement.
Nov 14, 2008 | Panasonic Home Theater System System
Error message F61
Si es un panasonic tu IC amplificador de audio esta dañado hay que remplazarlo.
Apr 03, 2008 | Audio Players & Recorders
F61
Output IC is defective.Not much to do except have the main unit serviced.Output IC is rather costly.Before taking it for service, disconnect all speakers and power on.In F61 comes up IC is definetly bad.If unit works reconnect 1 speaker at a time(with power off) and retest each time.Repair bad speaker .
Nov 27, 2007 | Panasonic SC-HT740 System
Cameras Logo
16 people viewed this question
Top Samsung Cameras Experts
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
