Question about Asko Washing Machines
ASKO model W6444 won't spin after washing - I have checked and the 'no spin' option is not selected
  • 3 Answers
SOURCE: Asko W620 washing machine not spinning
Sounds like the motor brushes need to be cleaned or replaced. Take the back off the washer, remove the motor and gently scrape the excess carbon or debris off the brushes with a pocket knife. I did this and it ran well for about 50 loads before building back up. I am ordering new brushes now because when I checked the brushes last week they were obviously worn more than 4 weeks ago.
Posted on Jan 21, 2008
SOURCE: Asko Washer W6021 Problem
CHECK THE BRUSHES ON THE MOTOR, FOR BEING WORN DOWN!
REGARDS........TREVOR. FLEETWOOD UK.
Posted on Mar 09, 2009
SOURCE: asko 10625 will not spin
it is probably the belt, take off the back of the machine and look at the black rubber belt that spins the cleaning drum. The belts break after about 5 years, you can get a replacement belt at you local Asko dealer, I recall that is was pretty easy to change, like doing a bike chain, Talk to you Asko dealer about how to change it.
Posted on Jul 13, 2009
SOURCE: lg 801 3f washing machine. 15 seconds after selecting any cycle a
I had the same problem. Redistributing the clothes inside the machine seems to do the trick. Even though the clothes seemed evenly distributed and I had far less than maximum capacity in the machine- it seemed to think that something was out of sync- simply moving the clothes around did the trick!
Posted on Oct 05, 2009
Jahn27
  • 1554 Answers
SOURCE: I have an Admiral Capacity
This symptom characterizes a problem with the water level pressure switch which is not tripping from the empty to full position. Either the pressure switch contacts are stuck or has welded together or the pressure hose is detached or has air leaks preventing pressure build up to trigger the tripping of the pressure switch.The pressure switch is located behind the console and directly attached to the water level selection switch with a small clear hose connected to it.
Roll the console in the service position to access the pressure switch. Disconnect the pressure hose then blow air forcefully down through it to clear for possible clogs. Do the same with the pressure switch inlet to free any possible stuck or welded contacts. Replace the pressure switch, part number 21001882, if the problem persists.
Posted on Aug 15, 2011
W6444. What causes it to make gentle rattling sound while running, washing?
after the machine has finished , try removing the agitator and check for a button, bra wire or coins
Jul 15, 2015 | Asko Washing Machines
Asko washing machine won't turn or spin
Check the belt, its possible that the belt came off or broke. Get me a model number and I can find the belt for you.
Aug 04, 2014 | Asko Washing Machines
Asko w6444 front loader drum vibrating quite loudly. Feet are level. Any suggestions.
Check the 3 transit bolts on the backside of the machine. Should be removed. Could also be a problem with the balancing spring on the top of the drum, so the drum tilts a bit forward, and cause noise
Aug 11, 2013 | Asko W6761 Front Load Washer
W6444 washing machine door won't close
Try some WD40 spray on the door and lock. Just a bit. Try closing and opening the door. The machine should be in the <off> position.
Mar 16, 2013 | Asko W6021 Front Load Washer
My Asko washing machine model w6021 won't spin, At
It very well could be a programming issue. You would have to know what version of software each board had in it. Boards can be used in different machines where some functions just are not used as they are in the better models. There should be a stamp or something indicating the software version on the board, a chip, something. I would not run it like it is or something else is going to go.
May 19, 2012 | Washing Machines
Asko 10505 washer will not spin
Hi, 2 things to check for. Obstruction in the drain pump or faulty drain pump, brushes in the motor worn out. The easiest way to determine the pump issue is answer this question. Does it drain ? Next, turn the timer to the drain/spin cycle, obviously it should drain & spin and advance to "off". The next thing with these 10505 asko is to see if the drum rotates in both directions in the wash/agitate portion of the cycle. You can just select the short wash for this (I forget if it's #4 or #5) If not, it's worn brushes. However, you'll have to make sure the armature isn't damaged before simply installimg new brushes. We can cross that bridge when we get there. Let me know. Hope that helps, though those are just the most common problems there could be others. Good Luck
Nov 01, 2009 | Asko W6021 Front Load Washer
Mar 09, 2009 | Asko W6021 Front Load Washer
Dec 11, 2007 | Asko W620
Washing Machines Logo
Top Asko Washing Machines Experts
Gerry Harvey
Gerry Harvey
Joseph Hoffmann
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
