Question about Apple MacBook Pro Laptop Computer with Intel Duo Core 15.4 Inch PC Notebook
Macbook heats up a lot
After only 30 mins of use
  • Apple Master
  • 1,087 Answers
A frequent cause of over heating is blocked air vents or a clogged fan. Use vacuum cleaner nozzle not too close to air vents and try and suck out surplus dust. Obviously don\'t then use it flat on your lap or bed, air needs to get to it all round!
Posted on Feb 07, 2014
98 Malibu 3.1 v6 can drive it for about 30 mins than it stalls and dies been through 5 fuel pumps 2 motors and still has the problem let it sit for 30 mins it will start again. Also found out if heater is...
5 fuel pumps and 2 motors? id say that whoever is diagnosing your car needs to be fired. toggle switches, over heating, stalling after 30 mins, new motors....you need to get this to a shop. no way someone can diag this cars serious problems and over internet.
Jul 27, 2014 | Cars & Trucks
Mower blades will not engage when hot
overheating safetybsprings are wore out. they either got over heated or reached their limits
Jul 24, 2014 | Cub Cadet Garden
How fix motherboard after water get inside MacBook Pro A1425? dont startup!
Dammage caused by water only can be limited by a special service centre. By heating the system only will have more damage. And even with a scheme you won't be able to repair the macBook. You could try to order the part that is damaged. To see how to open an macbook and how to replace parts, goto ifixit.com. They did lots of repairs. There are moors sites where you can see how to opener (and close) a Mac, but star with them.
Jun 18, 2014 | Apple Macbook Pro Retina 13" A1425...
MacBook Pro 17'' Mid 2010 HEAT
if it doesn't get very hot, then everything's fine. Yes, you may try unplugging and see if it works.
Of course, it's better to call the Apple Support. Ask them about the problem and see if it is normal/not.
Jun 04, 2013 | Iomega eGo Portable 35814 1 TB External...
The DeLonghi PACA130HPE 13000 BTU Portable Air Conditioner unit will not function. Unit displays the Alert symbol only and no other designation as identified in the product manual. The unit was in heat...
I had the same problem, you have to empty the water pan in the rear of the unit. In the heat mode it will NOT evaporate the water like in the air conditioner mode. If you use it a lot in the heat mode and have a lot of moisture in the house you will have to modify the water outlet to have it constantly draining in a pan or out of the house.
John
Oct 09, 2012 | DeLonghi PACA130HPE 13000 BTU Portable Air...
Why does my grasshopper diesel 928D G-2 keep overheating while mowing?
I have looked through a lot of
Post about the same mower n grasshopper diesels altogether and didn't find an answer . I went to the repair shop in the months to follow the overheating and I figured the problem out after seeing the engine cover missing of off the majority of grasshoppers . The cover holds the heat in . Our mower no longer gets out of the green . I m sure u will figure it out after u testy theory
May 19, 2012 | Garden
I would be playing with my amp and after about 30 min there will be a a lot of crackling and then the amp shuts off
You are driving the amp too hard and the thermal protection in the amp chip is cutting out.
Either reduce the volume on this small amp or get a larger unit.
The heat sinks for the amp chip will overheat if you drive it hard and that takes a bit of time to happen, hence the 30 minute delay.
Jun 10, 2010 | Line 6 Spider Iii 15 Modeling Guitar...
Gas dryer runs for 30 mins then shuts off.
This is a common problem that is not a good one. But the motor is goin bad. If you try to start it you will hear like a hum then start. Motor is going bad and over heating and shutting down on overload. Sorry. Hope this helps.
Jan 31, 2010 | Kenmore Dryers
Kitchenaid Model KGST307HBS5 intermittent will not heat up
the gas leak can be the safety valve. in side the oven where the burner sits on you have to remove the burner to get to it.
Dec 09, 2008 | KitchenAid KGST307 Gas Kitchen Range
Shuddering/jerking on highway, pull over, wont start for 30 mins
Last time I had that happen in a car everything blew. I found out the root of the problem was my timing chain, but I can tell you, you don't want to wait to get that checked out in any case or you will end up with a lot more problems.
Jul 13, 2008 | 1992 Buick LeSabre
Apple MacBook Pro Laptop Computer with Intel Duo Core 15.4 Inch PC Notebook Logo
88 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
