Question about Acer Emachines E725-4520 Laptop T4400 2.2g 15.6" 3g 250gb Dvd
Emachines cd/ dvd driver
I inserted windows 7 formatting dvd in disk drive for formatting after some process the system wdisplays the message cd/dvd device driver missing what is the solution
  • Acer Master
  • 7,733 Answers
CD / DVD cannot be formatted. Dont waste yout time just buy some new ones.
Posted on May 06, 2015
exspert
  • 55 Answers
SOURCE: cd dvd writer not working
ok " I would get a dvd/cd cleaner disk, has a tiny brush on it that cleans the lens in your drive.
Posted on Jan 27, 2008
mspcrepair
  • 169 Answers
SOURCE: Acer 5100 lost dvd/cd drive
Is the DVD drive listed in device manager under CD/DVD drives at all? If so, remove it and reboot. Windows might be able to re-detect and reinstall the drivers for it, but odds are the drive is bad. You can try removing the drive from the computer, and use compressed air to blow out the area where it connects to the laptop. Also check the connection on the DVD drive to make sure there isn't any physical damage, bent pins, etc.
Hope this helps - remember to rate!
Posted on Sep 30, 2008
cpenzes
  • 1102 Answers
SOURCE: Unknown cd-dvd rom driver for Acer Aspire 5100
control panel add new hardware
follow instructions choose yes already installed if a box appears scroll and see if your cd drive is there if so highlight then next.
If not showing scroll highlight add new then next choose option automatically install.If still not installed then go back and if you know your cd type choose option select from list then highlight what your looking for then next choose type and model from the list and next
how old is the system maybe you need a new cd rom.
Have you made any changes to your system when this start to happen
Posted on Jan 28, 2009
  • 40 Answers
SOURCE: get an error message that windows would not start missin or corrupt windows\system32\config\system
you can use system restore to solve this problem .
try to restore your system to an earlier working restore point.
this will fix your problem.
Posted on Apr 22, 2009
  • 10 Answers
SOURCE: PIONEER DVD-RW DVR-K17RS ATA DEVICE VISTA HOME EDITION MISSING
you have to upgrade the firmwear
Posted on Aug 13, 2009
First boot of Win 7. New PC build
Hi.
First of all when you are in the BIOS and have set the DVD/CD drive as the first boot device make sure you save the settings before you restart the computer as it will not remember the changes if you don't.
Make sure that the lens on the CD/DVD drive is clean and also make sure the Windows 7 install disk is clean and free of any finger prints.
make sure that you keep tapping a key when the drive spins up as sometimes people miss the "Press any key to boot from CD/DVD" message.
If you still can't get the disk to boot then try the install disk in a working PC and see if that reads the disk. If it does then the optical drive could be faulty or does not support DVD format.
Regards.
Feb 04, 2013 | Microsoft Windows 7 Home Premium 64BIT...
Tip
How to create a bootable USB using Vista or Windows 7
Having a bootable USB is very essential, especially if you are a Netbook user. Using bootable USB to install an operating system (OS) not only makes the installation faster, but also saves a DVD.Creating or using an USB drive to install Windows operating systems is very easy if you follow the below mentioned steps.
Here we assume that you are using either Vista or Windows 7 to create a bootable USB.
1. Insert your USB (4GB+ preferable) stick to the system and backup all the data from the USB as we are going to format the USB to make it as bootable.
2. Open elevated Command Prompt. To do this, type in CMD in Start menu search field and hit Ctrl + Shift + Enter. Alternatively, navigate to Start > All programs >Accessories > right click on Command Prompt and select run as administrator.
3. When the Command Prompt opens, enter the following command:DISKPART and hit enter.LIST DISK and hit enter.Once you enter the LIST DISK command, it will show the disk number of your USB drive.
4. In this step you need to enter all the below commands one by one and hit enter. As these commands are self explanatory, you can easily guess what these commands do.
SELECT DISK 1 (Replace DISK 1 with your disk number), CLEAN, CREATE PARTITION PRIMARY,SELECT PARTITION 1ACTIVE,FORMAT FS=NTFS(Format process may take few seconds),ASSIGN,EXIT.
Don't close the command prompt as we need to execute one more command at the next step. Just minimize it.
5. Insert your Windows DVD in the optical drive and note down the drive letter of the optical drive and USB media. Here I use "D" as my optical (DVD) drive letter and "H" as my USB drive letter.
6. Go back to command prompt and execute the following commands:
D:CD BOOT and hit enter. Where "D" is your DVD drive letter.CD BOOT and hit enter to see the below message.BOOTSECT.EXE/NT60 H:(Where "H" is your USB drive letter)
7. Copy Windows DVD contents to USB.You are done with your bootable USB. You can now use this bootable USB as bootable DVD on any computer that comes with USB boot feature (most of the current motherboards support this feature).Note that this bootable USB guide will not work if you are trying to make a bootable USB on XP computer.
on Dec 18, 2010 | Computers & Internet
Tip
How to Install windows 7 by using usb flash drive, pen driver or usb harddisk.
Friends i have seen thousand of laptop cd/dvd rom stops working very soon. then the quesion is how you do intall your os if it was corrupted.
follow my tip and install windows7 or vista in very simple way.
a) first insert your usb flash drive or hdd in usb port
b) then open commandprompt from accessories with rightclick run as administrator
c) you must know what is drive letter of your usb flash drive.
d) type DISKPART in command prompt and press enter
e) then type LISTDISK in command prompt
f) Next type all the below commands one by one. Here I assume that your disk drive no is “Disk 1”.If you have Disk 2 as your USB flash drive then use Disk 2.Refer the above step to confirm it.
So below are the commands you need to type and execute one by one:
SELECT DISK 1
CLEAN
SELECT PARTITION 1
ACTIVE
FORMAT FS=NTFS
ASSIGN
EXIT
g) Next insert your Windows7/Vista DVD into the optical drive and check the drive letter of the DVD drive. In this guide I will assume that your DVD drive letter is “D” and USB drive letter is “H” (open my computer to know about it).
h) Maximize the minimized Command Prompt in the 4th step.Type the following command now:
D: CD BOOT and hit enter.Where “D” is your DVD drive letter.
i) Type another command given below to update the USB drive with BOOTMGR compatible code.
BOOTSECT.EXE /NT60 H:
J) Copy your Windows 7/Vista DVD contents to the USB flash drive.
Eject the usb drive and select first boot device usb drive or usb hdd in motherboards bios.
enjoy... and please rate this trick.
on May 11, 2010 | Computers & Internet
How can i reformat my laptop?
  1. First format all the other partitions in your system except the Drive in which the OS is installed.
  2. Most probably the OS drive is C: Drive.
  3. Then get an operating system CD/DVD Windows XP/Windows Vista/Windows 7
  4. Then on start up insert the OS cd and select the option to install the OS.
  5. When you click next there will be an option to specify the Drive in which you will be installing the OS.
  6. Select the Drive in which the previous OS had been installed.
  7. Now in the next stage there will be option whether to install the OS with or without formatting Drive.
  8. Select the Format Drive Option and click Next.
  9. Congratulations you have formatted all the partitions in your System/Laptop/PC
Apr 05, 2010 | Computers & Internet
EMachine T2778 new hard drive, restore disk aren't working, how do I format?
1st Option: Go to BIOS level and select the CD/DVD device is the first device for boot option and then insert the recovery CD/DVD to format or install OS.
2nd Option: If recovery CD/DVD got curropted and you are having the other OS CD/DVD, then try to load and format or install the OS. Also try to download the recovery image from vendor website.
Revert back for more assistance.
Jan 31, 2010 | E-Machines eMachines Desktop PC
How do i format my laptop off of the partition on the hard drive. I've managed to hit f 10 and get into the bios but no format option was given
Formatting the hard drive is not a function of the BIOS. You will need to boot the machine from either the Windows CD and do a fresh setup (which will give you the option to format the hard drive) or boot from a bootable CD or floppy disk that has the format command on it. From there you execute the format command and follow the directions.
Jan 05, 2010 | Sony VAIO Notebook
How to format the desktop,which is affected by a virus(trojen)?
Boot from your system disc and do windows over again,and then go to format selected partition. First go to your bios and go to boot disk priority then select first boot device on boot from disk. Then exit and safe with changes. Put your system disk in and there you go
Oct 06, 2009 | HP Compaq Presario SR1830NX PC Desktop
My daughter amilo 2727 crashed, i had to order the media set from siemens but nothing is happening when i insert the recovery disc
Caution: The entire contents of the hard disk including any partitions will be lost.
Note: The following message may appear when disks (CDs/DVDs) are inserted:
"An unidentified program is attempting to access the computer"
"Unidentified publisher"
Confirm this message with "Allow Access" if you are certain of the source
and its origin. This query is intended to protect your operating system and is
generated prior to system files being accessed. For example, it appears
during the installation process for programs and drivers.
4.2.1 Restoring the operating system
1. With the machine turned on. Insert the Product Recovery CD/DVD into the optical
drive.
2. Turn the machine off, wait a moment and then turn it back on.
3. When the prompt "Press any key to boot from CD or DVD …" appears on the
screen for the first time, press any key on the keyboard.
.Caution! This message will appear after each restart during the installation
process. Please ignore this message in these cases as the
computer is only booted from CD/DVD once.
4. In the "Install Windows" menu select "Installation Language", "Time and
Currency Format
" and "Keyboard or Input Method", click on "Next" and then on
"Install now".
5. Accept the "Windows Licence Conditions" and click on "Next" to proceed with
the installation.
6. In the "Type of Installation" menu select "User-defined".
7. In the "Where would you like to install Windows" menu, select the partition on
which you would like to install your operating system.
If you would like to install Windows on a specific partition with sufficient storage
capacity, select it and then click on "Next".
If you wish to create a new partition or extend, delete or format an existing one,
click on "Drive options (extended)", select the desired option and click on "Next".
The installation process will start. The hard disk will be wiped and reformatted.
Files from the CD/DVD will copied on to the hard disk and expanded, and functions
and updates installed. This may take a few minutes. The machine will
automatically report a restart.
8. Now follow the on-screen instructions until the "Welcome Screen" appears.
9. Remove the Product Recovery CD/DVD from the optical drive.
To install the drivers, additional software and to restore the online documentation, insert
the Drivers & Utilities CD/DVD supplied into the optical drive.
4.2.3 Restoring additional software onto notebooks (drivers, documentation, hot
fixes)
The Drivers & Utilities CD/DVD allows your system's drivers, software and hot fixes to
be installed and restored. The installation and restore can be performed without having
to shut down Windows.
Proceed as follows:
hope this helps- here is the manual address if you need to look at it---please feel free to post more questions as you proceed..
Oct 07, 2008 | Computers & Internet
Format disk message evertime i insert a disk (cd or dvd)
sounds like you are driver deficient, eh? go to the HP website(through this printer driver link, if you wish) and give it a go
Mar 16, 2008 | HP (346789-001) CD-RW/DVD-ROM Combo Drive
Acer Emachines E725-4520 Laptop T4400 2.2g 15.6" 3g 250gb Dvd Logo
59 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
