Question about Dell Inspiron Mini 1012 Netbook (IM1012799OBK)
Not booting media failure system not found - Dell Inspiron Mini 1012 Netbook (IM1012799OBK)
3 Suggested Answers
  • 16 Answers
SOURCE: Pxe-e61: media test failure, operating system not found
First, take out any CDs/DVDs and try to boot again. If that doesn't work, your hard drive may be defective.
There will be a cover on the bottom of your laptop that holds the hard drive (easy access). You can try removing and reinserting the hard drive and then booting the PC afterward.
If that doesn't work, you will likely have to replace the hard drive, but best advice would be to take it to a computer technician for further analysis.
Posted on Sep 02, 2009
Testimonial: "I knew it migth be the hard drive, but I was hoping it was not. Thank you."
computerdeb
  • 323 Answers
SOURCE: Message saying media test failure, exiting PXE ROM
Sounds like your hard drive died. If hard drive is dead you wont be able to get into anything but the bios. Hold down the CTRL key when computer starts and dont let go and try to force it into going into bios for you.
Posted on Mar 04, 2010
Testimonial: "thank you for verifying what I already thought. CTL key does nothing. purchased new hard drive and hope its easy to install and set up. thank you"
E-E61 media test failure check cable pxe-mof exiting pxe rom. operating system not found. how do i find it
Hard drive lost communications with motherboard. Remove it and reseat it. Check BIOS if it sees the HD.
Disable PXE boot in BIOS or remove from 1st boot option. This is a LAN (network) boot option. It can't find a DHCP server, that's why the media test failure is displayed. It's usually used to load an OS image from network.
Oct 05, 2012 | Acer Aspire 9410z Laptop Computer 17"
Broadcom base code PXE-2.1 v1.1.0 Operating system not found
Go to your laptop's bios and select first boot device as your hard drive. and also disable the other boot devices and boot from network must be disabled. that's all.
Sep 22, 2012 | Acer Aspire 5536-5224 Notebook
Booting problem, screen message: Intel (R) Boot Agent FE v4.1.18 Copyright (C) 1997-2005, Intel Corporation PXE-E61: Media test failure, check cable PXE-MOF: Exiting Intel Boot Agent. Operating...
HI there,
The "Error" texts saying:
Are completely normal. This simply states that there is no external cables plugged into the specialty inputs on your toshiba laptop.
The "operating system not found" is stating that your existing hard drive is either A) dead or B) been erased.
Try to re-install your operating system, if it finds no hard drive, you'll need a new one!
May 04, 2011 | Toshiba Satellite M105-S3041Notebook
When i start my lapt top i get black screen that reads intel undi,pxe-2.1 (build 082) for real tek rtl8101e/8102e pci-e enthernet controller v1.07 (080320)pxe-e61 media test failure,check cable pxe-mof...
If the sound you are referring to is a clicking sound, then it is a hard drive failure.
Your computer is trying to boot up the operating system from the hard drive, but when it fails to access the hard drive, it tries to boot up from other devices configured on the BIOS. Apparently, your next choice for booting the operating system is set to the LAN card. Hence, you get the message "PXE-E61 Media test failure", which means that the computer tried to boot up the operating system over the network but it found out that your network cable is not connected to your computer's network interface card.
Dec 07, 2010 | Toshiba Satellite Laptop
Acer travelmate 4010 model zl1 ; pxe-e61: media test failure , check cable; system won't boot; operating system not found
clean filesystem with a scan disc if it isnt a mother board failure reinstall OS from external drive
Sep 06, 2010 | Acer TravelMate 4010 Notebook
Boot error PXE-E61: media test failure, check cable followed by, PXE-M0F: existing Broadcom PXE ROM followed by, Operating System not found
Hard drive has been coruppted. Hold alt f10 on statup to format and reinstall. If that dont work you may need to try install from cd's provided when you purchased laptop. If that dont work buy new hard drive and restore from cd's. Good Luck.
Nov 23, 2009 | Acer TravelMate 800LCi Notebook
PXEE61:media test failure, check cable PXEM0F:exiting PXE ROM operating system not found
You didn't ask a question. I assume this is an error on boot-up? If so, then the system is reporting that no pxe server was found to boot your system over the network. To correct this you should enter the BIOS setup upon power-up (via hitting the delete, f1, f2 or f10 key - depending upon your computer) and disable the boot from network setting. Save configuration and restart. You should probably set BIOS boot order to 1st device = cdrom, 2nd device = harddrive.
Jun 19, 2009 | Computers & Internet
Media test failure,check cable, exiting bordcom pxe rom os not found
check connections of hard drive. 2nd check boot order in Bios, remove Lan or network boot from top order. 3rd choice if not solved reset bios by removing cmos battery and putting back in to clear it.
Char S.
May 24, 2009 | Computers & Internet
Operating system not found media test failure will not reboot aspire 3680
Installing an operating system from one computer and inserting it into another computer will not work specially when they are from different manufacturers because the components in them are different.
The Windows install has to be done on the intended computer.
The media test failure error message refers to a faulty disk controller or a faulty hard disk.
Apr 13, 2009 | Compaq Armada 6500 PC Notebook
Dell Inspiron Mini 1012 Netbook (IM1012799OBK) Logo
12 people viewed this question
Alun Cox
