Question about Cuisipro Foam Pump 837579
Screw on at top has broken and will not hold on to container
Disassemble Krups XP 7245
Pull the drip tray out
Whack the silver surround on the front (see photo) upwards with the heel of your palm, it clicks up and off.
Remove beans lid, it clicks up when open
Undo 1 or 2 screws holding beans container in
Flip open or remove front top panel
Undo I think 3 screws holding top cover, 2 out wide on the top front and one down a tube in middle back.
Lift front edge of top cover up and wrack it about a but to release the clips
Undo 2 screws at the back covered by the water tank, down tubes
Remove side waste bin and sliding drawer thing
Remove 2 screws from the front through to the the sides (2x total not 2 each side)
Sides and back assembly now slide backwards, that's it, you are inside now.
Oct 01, 2015 | Krups Compact Automatic Espresso XP 7245
Hotpoint dryer won't stay on
The belt is probably broken. Their is a broken belt switch which keeps the main wire winding from working if the belt is broken. To check for broken belt open the door and remove the screws holding down the top. Remove the top, then take the front off and inspect that puppy. Here is my crappy video:
Apr 27, 2013 | Dryers
Giottos MT-8170 center top plate 3/8" screw broken, can the screw or plate be replaced?
You unfortunately can replace the screw; however you can find a new plate at www.tripodquickrelease.com. They carry Giotto quick releases.
Dec 25, 2012 | Giottos Photography
I have the beaumark juice extractor BM-473 it worked then i washed the removable parts now it wont work
the first solution is half right ... there are 2 hidden switches on the machine which are activated by shafts on the pulp container and on the top lid .if either is not on then machine will not work. possibly broke plunger on the pulp container ....or broken clip that holds the container in place
Jan 04, 2011 | Champion G5NG853S Household Juice...
My delonghi esam5500 coffee bean grinder part is not working. seems to be blocked, can see beans moving when it goes to grind but no beans are taken in and it comes up with fill beans compartment? what...
In our case we were lucky. Grinder was blocked by the beans. This is what I have done with our Delonghi 5400. It looked fiddly but was quite simple really. I started from the back panel. Once back panel was removed I had access to 4 corner screws that remove both side panels. Now that give me access to 4 corner screws that hold top of the machine. I l also had to unscrew 5 screws that hold coffee container in place. 4 are visible once the coffee beans container is open, but the 5th is hidden in the middle of adjustment arm with a black cap on top.(adjusting how fine you grind). I used small sharp screwdriver to lift the cap. Once all are out I removed the top of the machine and then the funnely coffee container too. That exposed grinder assembly. Top of the grinder is actually loosely sitting in the lower part of grinder. Twisting it counter clock should release it I Think. Our was not budging, and I had to completely remove the grinder and detach motor but that is quite obvious too, and probably not needed. I just wasn't sure what I was doing. Our machine was out of warranty so... Would be nice if we had some schematics.
Nov 26, 2010 | DeLonghi Perfecta ESAM5500 Fully Automatic...
I want to remove the cover to clean the mechanical
Remove the waste bin..inside there will be 4 screws holding the cutting head onto the container..remove those then you can lift the cutting head off the container.
Turn the cutting head over and remove the screws you see..normally 4~6 and the top will then lift off to allow access to the inside of the machine.
May 11, 2010 | Royal 1610X Shredder
Belt on my Kenmore series 70 dryer broke. How do
broken belt......simple fix.......remove lint filter from top 2 screws remove.........insert screwdriver between top & front push down to pop top......1 screw on each side holding front on at top remove them....front will then pick up off the 2 remaining clips at the front bottom.....spin door around to the side belt should be laying in the bottom of the dryer or around the tub but broken.......hope this helps......check back.......
May 05, 2009 | Kenmore Dryers
1996 Firebird
there should be 2 screws holding it in place.
Aug 16, 2008 | 1996 Pontiac Firebird
Cd drive
Yes, I have done this.
Step 1: With the laptop closed, unplug the power cord. Remove the battery by pushing open the 2 little locks on the bottom of the unit.
Step 2: Unscrew the three screws in a single row across the back of the unit. They are on the same plain as the serial port connector. These are the screws that hold down the on/off switch plate. Save the 3 screws in a container.
Step 3: Now, with the laptop (upright and opened) on a table slowly and carefully lift off the switch plate, located between the keyboard and the screen. Be very careful because it has tabs on it that can be broken. Slowly and carefully work the plate loose and remove it.
Step 4: Remove the two screws that hold down the keyboard and carefully, slowly lift the keyboard. Save the screws in a seperate container. There is a ribbon connector under the keyboard connecting it to the motherboard. Don't stretch it tight and don't disconnect it. Loosen and remove the screw in the middle of the keyboard recess under the keyboard.
Step 5: With that screw removed you will be able to slide out the cd drive. If it hangs up part way out, jiggle the battery lock next to it and gently pull it the rest of the way out.
Oct 19, 2007 | Acer Aspire 5004WLMi Notebook
Cuisipro Foam Pump 837579 Logo
20 people viewed this question
Top Cuisipro Dishwashers Experts
Are you a Cuisipro Dishwasher Expert? Answer questions, earn points and help others
