Question about LG U880 Cellular Phone
Vibration intensity low vibration
Galaxy instruction manual
you can turn your volume down which will then only work the vibrate motor or in settings go to "sound" change sound mode to either mute or vibrate instead of sound. you can set vibration intensity to low for notifications. also under "ring and notifications" change your notification tone silent at the top of the list.
I hope this was useful
Aug 21, 2014 | Samsung Galaxy BBSPHP1 Tablet PC
On my Samsung Intensity II the vibrate for text messaging will not work, any suggestions?
Have you cheked sound settings ? does it ring/vibrate when you recieve calls ? you could always try entering this code in the dial screen:
This code can be used for a factory data reset. It'll remove following things:
  • Google account settings stored in your phone
  • System and application data and settings
  • Downloaded applications
It'll NOT remove:
  • Current system software and bundled applications
  • SD card files e.g. photos, music files, etc.
PS: Once you give this code, you get a prompt screen asking you to click on "Reset phone" button. So you get a chance to cancel your operation.
Nov 19, 2012 | Samsung Intensity II U460 Verizon
Could you tell me how to turn off keypad tones when texting on a samsung Tocco
Adjust the volume of the key tones
In Idle mode, press [up /down] and adjust the key tone
volume.
Adjust the vibration intensity on the
touch screen
You can adjust the intensity of the vibration when you
tap the phone screen.
1. In Idle mode, press [up /down].
2. Select Vibration and adjust the intensity of the
vibration.
Jan 13, 2011 | Samsung Tocco F480 - Pay Monthly Cellular...
Touch screen is not sensitive on touch
You can change the touch screen vibration settings:
press
-Menu
-Settings
-Phone
Press Vibration Feedback
Set the desired Vibration Intensity setting
Press Save to keep the Vibration Feedback settings
www.usedcellphoneshop.com
May 18, 2010 | Samsung SGH-A877 Impression Cell Phone
Vibration problem in gamegube gamepad
Hi!
I have solved the problem on my Gamecube controller now.
The vibration is working again as usual.
Thanks for assisting me, I have solved the problem after all.
Dec 10, 2009 | Logitech Cordless Rumblepad 2 Vibration...
Brake light problem Corolla 97
the tail light and brake lights are working from double contact bulbs. check the grounding, you dont have enough ground from one of the bulbs
May 30, 2009 | 1997 Toyota Corolla
Vibration Intensity?
Most cell phones don't allow you to control the intensity of the vibration... you can only turn it on or off. However, if you get a rubber case for the phone that might help, because it will absorb some of the vibration.
May 27, 2009 | Samsung Propel A767 Cell Phone
How a cd drive works
A intense laser burns "micro-holes" in the film to represent the data...
A low intensity laser reads the spaces the high intensity laser left behind because the film casts back a reflection
DVD's work very similar; one low intensity layer and one high intensity layer. Furthermore, the laser makes much better use of the surface space so the DVD can hold more data
Nov 28, 2008 | Computers & Internet
LG U880 Cellular Phone Logo
11 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
