PC Laptops
Problem for PC Laptops
Generic problem for all PC Laptops
Acer Aspire Notebook 3694 wlmi
By NickyE on Oct 26, 2007
I am looking for the location of where the modules are located so that I can add more memory. Can't see any covers on the base of the unit. Wondering if located under keyboard? If so how to remove keyboard?
Best Solution
posted on Oct 26, 2007
Helpful)
sandrew
Rank: Wiz
Rating: 83%, 5955 votes
there is normally atleast 3 panels underneath held in with screws, and there is usually a small picure on the panel to tell you what is underneath
Was this helpful?
Yes
No
Solution #2
Somewhat Helpful)
eagle338
Rank: Wiz
Rating: 84%, 1631 votes
First thin you have to remember is if you want to have to memories in parallel...Then the new one should be of the same size and frequency(ex:133Mhz,533Mhz..etc.,)Then folow these steps:
  1. Turn off the computer and remove all power cords from the computer system.
  2. Locate the panel used for access to the memory modules. This is generally located on the bottom of the laptop computer. Refer to your laptop instruction manuals for locating the panel.
  3. Remove any screws that the panel in place and place somewhere safe to prevent losing it.
  4. Remove the panel from the laptop and set aside.
  5. If replacing or upgrading an existing memory module, remove the memory modules by undoing and module clamps and gently lifting the edge of the module to a 45-degree angle and then pulling the module out of the slot.
  6. Align the notch of the memory module with that of the memory slot and gently insert the module into the slot at a 45-degree angle.
  7. Once all the pins are in the slot, gently rotate the module down flat until the clamps lock into the module into place.
  8. Replace the memory access panel onto the laptop computer.
  9. Replace any screws or fasteners that hold the panel in place.
  10. Replace the power cord and power up your computer system.
Step 1:
Step 2:
Step 3:
Step 4:
Step 4_1:
Step 5:
Step 6:
Step 7:
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #3
posted on Jun 13, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
BLUETOOTH
Popular Solutions for PC Laptops
Questions and Unsolved Problems for PC Laptops
Answer
No message.
Answer
the best site i have ever visited,,, thanks fixya guys
Answer
Hi, where can I find the IDT high definition audio codec driver for the panasonic toughbook cf51?
Answer
i an not connect advent laptop to thomspson router tried 2 other pcs and they connect ok,can you... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top PC Laptops Experts
Top Computer & Laptop Repairmen
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(168) 454-4153
QABastards
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
