Question about Double Power 7 inch Tablet with 8GB Memory
Em63 android system recovery 3e what is this and how do i use it
My Haier 9 inch tablet will not reboot. It is stuck in Android System Recovery 3e. I have done everything that I was advised to do however I can not get past this mode. It will not turn off. Thanks.
HI again the back will come of just check around the edge & look for any screws there might not B any if u can find something plastic to pry around the edge of back cover it will come of if u can't find any thing plastic try a a small pen knife blade good luckHAVE U TRIED HOLDING DOWN THE POWER BUTTON for aprox 1 minute....if this does not work u might have to remove back cover & disconnect the battery lead ...then connect it up & hope it fixes youre problem...good luck
Aug 05, 2016 | Tablets & eReaders
I forgot my pass word, how do I get in back in
How did you try to reset? Please tell me as much as you can, as a full reset will delete everything on the unit.
Jun 23, 2014 | Ematic 4GB EM63 7" HD Dual-Core...
How to do a hard reset on an ematic 9" edan XL
check the back they my be a small holl or when the power buttom hold down for 3 should
May 16, 2014 | Ematic 4GB EM63 7" HD Dual-Core...
My ematic 4gb EM63 7" is stuck in trying to complete turn on process, cannot get p.ast the logo and blinking lights. I simply cannot turn it on. I've only been using it since Jan 2014. Been trying to
So I guess nothing else to do but to get it to boot from a SD card with Android 4.1 on the SD Card, It appears your's is corrupted, there is a number of sites where you can download along with directions to make an Android boot card. Hope this gets you up and running.
Apr 22, 2014 | Ematic 4GB EM63 7" HD Dual-Core...
Can't reset ematic dual core tablet em63
A hard reset is a last resort, by doing a hard reset you will start all over (pending your skills) you will loose all aps/ data you may have had. Remember the basics on a soft reset you need to hold volume up button and then hold power on button it takes some time for the unit to boot, this is intentional.
Mar 22, 2014 | Ematic 4GB EM63 7" HD Dual-Core...
Stuck on loading, won't go pass loading even after resetting
First thing to do is try a soft reset. Hold volume up button and whilst holding it, hold power on button till it boots up. Really hope this works for you.
Unfortunately goggle play store has stopped and the keyboard
I have an Em63 doing the same thing with Google Play Store and YouTube etc. How do we fix this problem? Any help out there?
Thanks for your input. Jammer
Mar 09, 2014 | Ematic 7" Tablet Computer
Help how do hard reset my proscan tablet plt7035 i for got my pattern to unlock it
1. Power the Tablet off.
2. Press and hold the Volume Down button of the device, then press and hold the Power button.
3. Continue to hold both buttons until a bootloader screen appears.
4. Wait for the prompt that says to "Press <VOL_UP>" then press the Volume Up button to start the process.
5. Navigate to Erase content.
All info on tablet will be deleted but not the info in the SD card
The tablet will complete the hard reset process and reboot into a factory default state.
Oct 19, 2013 | Proscan Recertified - PLT7035 4GB NAND...
Tablets wont boot up just shows arnova on screen and shuts down
I had same problem looping startup just showing Aenova screen, i tried the pin thing ended up doing a factory reset IT WORKED WAHEY!!
How can I do a Factory Reset on my tablet? If your tablet freezes often or if you get error messages during the start up of your tablet, you can use the recovery mode to reset your tablet to its factory settings, removing all installed applications as well as any data or content.
Your tablet must be up to date with the latest firmware - downloadable from the downloads area of this website.
To access Recovery mode on the ARNOVA 10bG3
To access to the recovery mode:
1. Hold down the volume button + and press the ON/OFF button.
2. Once the boot logo ARNOVA is displayed, release the volume button +.
The ANDROID green robot is displayed.
3. Once the ANDROID green robot is displayed, press simultaneously the volume button + and the ON/OFF button.
The Android system recovery screen is displayed.
a. Use the volume buttons to navigate
b. Use the ON/OFF button to select an option
To restore the default parameters of your tablet:
1. In the Android system recovery, select Wipe data/factory reset;
2. Select Yes -delete all user data.
3. Select Reboot system now.
Your tablet reboots. Redefine your parameters through the wizard.
Your tablet is restored to its default settings.
To access Recovery mode on the ARNOVA 9G3
1. Hold down the Home button and press the ON/OFF button.
2. Once the ARNOVA boot logo is displayed, release the Home button.
To access Recovery mode on the ARNOVA 8cG3/8bG3
1. Hold down the volume button - and press the ON/OFF button.
2. Once the boot logo ARNOVA is displayed, release the volume button -.
Sep 16, 2012 | Tablets & eReaders
Double Power 7 inch Tablet with 8GB Memory Logo
81 people viewed this question
Top Double Power Tablets & eReaders Experts
ka4iup
ka4iup
jeff5may32
Lawrence Oravetz
Are you a Double Power Tablet and eReader Expert? Answer questions, earn points and help others
