Question about Panasonic KX-FL511 Plain Paper Laser Fax
Junk fax on Panasonic 442 - Panasonic KX-FL511 Plain Paper Laser Fax
Ricoh Aficio MPC 2500 error SC 442
image transfer belt contact sensor is dirty clean it
Feb 17, 2014 | Ricoh Office Equipment & Supplies
Unwanted faxes
you should use junk prohibitor if it's panasonic u can use
Feb 25, 2010 | Office Equipment & Supplies
How can i block a junk fax number in a hp j3640 thanks in advance
Set the junk fax mode
By default, Block Junk Fax mode is turned On . If you do not subscribe to a caller ID service through your phone provider, or do not want to use this feature, you can turn off this setting.
To set the junk fax mode
Press Setup .
Press the right arrow to select Basic Fax Setup , and then press OK .
Press the right arrow to select Junk Fax Blocker Set Up .
Press the right arrow to select Block Junk Fax the press OK .
When prompted, press 1 for Yes or 2 for No .
Add numbers to the junk fax list
There are two ways to add a number to your junk list. You can select numbers from your caller ID history, or you can enter new numbers. The numbers in your junk list will be blocked if Block Junk Fax mode is set to On .
To select a number from the caller ID list
Press Setup .
Press the right arrow to select Basic Fax Setup then press OK .
Press the right arrow to select Add Number to Junk List , and then press the right arrow to select Number and then press OK .
Press the right arrow to scroll through the numbers from which you have received faxes. When the number you want to block appears, press OK to select it.
When the Select Another? prompt displays, do one of the following:
If you want to add another number to the list of junk fax numbers , press 1 to select Yes , and then repeat step 4 for each number you want to block.
If you are done , press 2 to select No .
To manually enter a number to block
Press Setup .
Press the right arrow to select Basic Fax Setup press OK .
Then press the right arrow to select Junk Fax Blocker Set Up and then press OK .
Press the right arrow to select Add Number to Junk List press OK , and then press the right arrow to select Enter Number .
Use the keypad to enter a fax number to block and then press OK . Make sure you enter the fax number as it appears on the display, and not the fax number that appears on the fax header of the received fax, as these numbers can be different.
When the Enter Another? prompt displays, do one of the following:
Remove numbers from the junk fax list
If you no longer want to block a fax number that number can be removed from the junk fax list.
To remove numbers from the junk fax list
Press Setup .
Press the right arrow to select Basic Fax Setup then press OK , and then press the right arrow again to select Junk Fax Blocker Set Up then press OK .
Press the right arrow to select Remove Number from Junk List .
Press the right arrow to scroll through the blocked numbers. When the number you want to remove displays, press OK to select it.
When the Delete Another? prompt displays, do one of the following:
If you want to remove another number from the list of junk fax numbers , press 1 to select Yes , and then repeat step 4 for each number you want to block.
If you subscribe to a caller ID service through your phone provider, you can block specific fax numbers, so the HP Fax does not print faxes received from those numbers in the future. When an incoming fax call is received, the HP Fax compares the number to the list of junk fax numbers you set up to determine if the call should be blocked. If the number matches a number in the blocked fax numbers list, the fax is not printed. (The maximum number of fax numbers you can block varies by model.)
Thank you.
Sep 17, 2009 | HP J3680 Officejet All In One Printer
BLOCKED CALLS
specific fax numbers so the device does not print faxes received from those numbers.
When an incoming fax call is received, the device compares the number to the list of
junk fax numbers to determine if the call should be blocked. If the number matches a
By default, Block Junk Fax mode is turned On. If you do not subscribe to a caller ID
off this setting.
▲ Some models have a Block Junk Fax button. Depending on the model you have,
Block Junk Fax button: Press the Junk Fax Blocker button, select the Block
Junk Fax option, and then select On or Off.
Color display menu: Press Setup, select Basic Fax Menu, select Junk Fax
Blocker Setup, select Block Junk Fax, and then select On or Off.
your caller ID history, or you can enter new numbers. The numbers in your junk list are
blocked if Block Junk Fax mode is set to On.
Feb 11, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
Trying to cancel incoming fax on panafax uf-8000
there is a feature called junk fax that will stop all incoming faxes
Jan 08, 2009 | Panasonic PanaFax UF-8000 Laser Fax
Der Videotyp is not PAL - code 442-E-100
install the software in ntsc mode...it was my solution
User "aldof" said it in other post...
Thanks to him
Dec 02, 2008 | Panasonic Palmcorder SDR-H18 Camcorder
Laserjet 3330 is resulting in fax Comm Errors 327, 232, 442, 356, 421 Comm Error 327 is always with fax # 780.467.6516. i can not fax to this number and when i receive from it, it always prints a Fax...
232-A communication failure has occurred between the two machines.
327-*Reattempt the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve.
356-The remote user has pressed the Stop key, causing the session to be aborted.
442-An error occurred during transmission after one or more partial pages had been sent. The transmitting machine was unable to restart the control channel (handshaking) before sending more data. This error typically occurs when the receiving fax disconnects after receiving part of a page but can also occur if the receiving fax is using a fax format that is incompatible with the HP fax machine (usually during color faxing).
Aug 15, 2008 | HP Computers & Internet
Paper jam
sounds like you have a problem with the mechanicals, have it check by a certified tech. or junk it....hehehe!!!!
Jul 24, 2008 | Panasonic KX-FP101 Plain Paper Thermal Fax
MSDS FOR BROTHERS TONER CARTRIDGE
Material Safety Data Sheet,
It is the form that tells you all of the components that make up a product, the chemical break down, what to do in an emergency, such as ingestion, getting in eye, etc.
Hope that helps, Mikey
Apr 04, 2008 | Office Equipment & Supplies
Panasonic KX-FL511 Plain Paper Laser Fax Logo
27 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
