Konica minolta c451 error code c3102 - Office Equipment & Supplies
Patrillica
  • 141 Answers
SOURCE: konica-minolta error code c0012
What is the model ????
Posted on Apr 15, 2008
  • 3 Answers
SOURCE: c451 Bizhub Konica Minolta printer
press utility. press metercount. press metercount details. press stop 0 0 stop 0 1 to access service mode in service mode look for admin initialialation function
Posted on May 22, 2008
jqsababa967
  • 145 Answers
SOURCE: Konica Minolta c451: Tray 1 is not available
look behind the tray for paper....
if not do the folowning
power machine off from main switch sould be on the side or open the front door it;s on bottom left side.hold down the utility botton while powering on keep holdin untel prompted with message ...TROUBLE RESET press it should say ok than powr machine off wait 20sec power back on
hope that help
keep us posted
Posted on Mar 18, 2009
herminio_hal
  • 210 Answers
SOURCE: Bizhub Konica Minolta - Error Code C1183
First check the alignment front and rear of the finisher, check the finisher exit guide rollers if the paper is exiting properly, open both rear and the front cover and check the lower gears attach is the up/down drive belt. that lower gear one might be broken by the pin slot.
Posted on Jul 09, 2009
  • 7 Answers
SOURCE: need written instructions on how to reset Ip code Konica bizhub C451
there are two ways you can rea\set the ip address you can press utility counter administrator password is 12345678 the go to network ip address and you can chane it there if you know the ip address you can browse to the machine and log in as administrator and go to network and reset there
Posted on Aug 22, 2009
I have a problem with my konica minolta bizhub c451 giving error Code C 3102
c3102 for Fuser Unit abnormality.
Check Fixing Unit and its Gears , also the drive gear on body.
Reset by Switch On Holding Utility/counter Button for 10 seconds.
Touch TROUBLSHOOT and restart by Power off and on
Jul 07, 2017 | Konica Minolta Office Equipment & Supplies
P7 error code in Konica Minolta c451 how to solve
replace the magenta (Red ) image unit.
Sep 14, 2016 | Konica Minolta C451
How to solve error code c-2553
The toner abnormality you have to clean toner hopar and clean senser and again OFF and ON
May 23, 2015 | Konica Minolta C451
What is error code C3102 in Konica Minolta bizhub 552 printers
Fusing roller failure to turn remove the fuser unit check orange rollers bad replace the fuser unit
May 09, 2015 | Konica Minolta Office Equipment & Supplies
What does error code c3102 0n a konica minolta bizhub 6500 mean
problem with Fusing release home sensor and or fuser motor. Fuser is the Hot Part of the machine
Jun 16, 2014 | Konica Minolta Office Equipment & Supplies
Error C3102
The Fuser is not turning... follow these steps
1. Turn OFF the main power switch.
2. Turn main power switch ON while pressing the Utility/Counter key. Keep holding it till the T reset appears
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. After turning off the main power switch, wait 10 seconds and turn the machine back on, this should reset the service code and with any luck the machine will run!
May 03, 2014 | Konica Minolta Bizhub C451 Copy-print-scan
Errore Trouble code C-C172
Refer to Konica Minolta Bizhub C451 Printer/Scanner/Finisher's User Manual or Call Service Center.
May 01, 2014 | Konica Minolta Bizhub C451...
Error code c2152
good to
Imax Konica Minolta C451 Bizhub
I have a problem is the cod C2151 what to do Thanks
Sep 24, 2009 | Konica Minolta bizhub C450P Laser Printer
jasbo
jasbo
