Question about Freezers
Where is the temp control on a E308 freezer FISHER AND PAYKEL
Where is the temp control located on a FISHER AND PAYKEL E308 freezer
Fix-ya
Find the water drain hole/pipe and clean it thoroughly with a pipe cleaner or other softish flexible rod. That should allow the water to drain away. Make sure back of the unit is clear and clean so water drains and evaporates off properly.
Jul 31, 2014 | Fisher Paykel ActiveSmart Fridge - 17 cu....
Fisher and paykel xrss 267BB fidge freezer
The system is either blocked or you have a gas leak but i would expect it is blocked and the only way to find out is to get a refrigeration engineer to check it for you, but explain the problem to him first and make sure he can help before you spend money.
Jul 19, 2014 | Engel Freezer 22 Qt. Fridge/Freezer
Frigidaire freezer ce error
That is the temp sensor and should be hooked up to the board.
Oct 10, 2013 | Freezers
Where is the thermostate(sensor) located that controls the compressor - or is it the same as the sensor located by the door which show the temp on the outside indicator Thanks
The thermostat sensor is located in the top rear of the interior of the unit, if you locate the dial to change temps on the inside of the unit, the sensor is attached to it, you may have to pull your fridge apart to get to it, but it can be done.
Regards Russ
Mar 07, 2011 | Nor-Lake Freezer Norlake Refrigeration 6'...
Hi i have a E5221 rt d fisher and paykel fridge freezer, freezer at top, the freezer always gets a build up of ice that collects on the slats and has a slightly swollen back wall witch seems to have ice...
try to clean the drain of your unit maybe it is clog up declog it to avoid drip. u said that ther is a build up of ice this means auto defrost not activate try to chek the defrost heater or defrost timer if have the unit this. or try to allign the door gasket possible theres a gap entry of outside air cause of build up of ice. bec it is came from moisture of air out side or avoid to much door opening.goodluck.
Feb 27, 2011 | Fisher Freezers
How do I start my 13-986-144A isotemp plus, I have no manual and I don't know how to access the control menu... help...
The first thing that you should do is plug the AC cord of the freezer and open the upper portion on top of the two doors and insert the key on the slot and turn it on. Open the freezer door and locate the temperature adjustment panel inside and adjust it to your desired temperature.
Nov 17, 2010 | Fisher Scientific Freezer Isotemp* Plus...
Problems with an older Fisher Isotemp plus 98 model, the defrost circuit is not working correctly. The temp is normally around -20 degrees celsius and the temp is now at -08. I have manually defrosted the...
Noah had one of these in the ark...he did a full defrost(left it for 24 hours with the doors open then cleaned the vents/drains)and his was fine after that,hope this works for you.....also check door seals for tight fit all round.
Apr 06, 2010 | Fisher Scientific Freezer Isotemp* Plus...
Kenmore Freezer Temp. Alarm
You should get a thermometer to be sure the temp is what it should be. With out it is very hard to tell correct temp.
Aug 05, 2017 | Freezers
Fisher and paykel vertical freezer N308 model
bec,
Sounds like you are freezing up! The coils are so frost-laden that they will not allow the unit to function. The unit will need a complete defrost. I'm not familiar with the exact layout of this unit but I can tell you that it needs to be shut down, have warm air blown into the fan area and completely freed of ice. If you just leave it open and turned off, this takes about 2 days.
Possible causes: humidity in the air is condensing...very humid area, too much 'window shopping', not closing the door completely, possible damaged door gasket.
Others: (on older units)
Possible defrost timer problem...or low gas. Try the defrost route. We'll go from there.
Dec 03, 2007 | Freezers
Freezers Logo
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
