Question about Whirlpool Washing Machines
I changed the sensor still it is giving same problem i.e. PE displayed on screen machine 650s
    Scholar:
    New Friend:
  • 111 Answers
Need complete model # to help
Posted on Feb 08, 2014
Lg wf-t1022tp gives a PE error code.
Try this first before replacing any parts or disassembling your LG washer:
- Unplug the washing machine for 1 minute.
- Plug the washing machine back into power.
- Restart the wash cycle.
- The washing machine may now have cleared the PE error code, if not see below...
You will need to check the wiring harness that connects the water level pressure sensor to the main control board.
- Check for a loose wire harness, a damaged wire harness, or a burnt faulty wire.
- Check that you get continuity through the wire harness by checking it with a multimeter.
- If the wire harness from the water level pressure sensor to the main control board is found to be faulty, replace it.
- If you get continuity and the wiring harness is securely connected to both the water level pressure sensor and the main control board, then proceed to the step below...
LG WASHER PE ERROR CODE - FIX METHOD #2
Water Level Pressure Sensor Switch Is Faulty And Needs To Be Cleaned Or Removed And Replaced.
Most commonly, if the wire harness is secure, tight, and not damaged, the part that needs to be checked is the water level pressure sensor.
- First check to be sure the water level pressure sensor is not caked with hard water or other debris.
- If the water level pressure sensor is not clean, the PE error can display.
- Remove the water level pressure sensor from your LG washer and clean off any hard water or debris.
- Clean out the tube that connects to the
- If you found the water level pressure sensor was caked with debris and you have cleaned it, replace it back into the washer and run a test.
- If the washer runs without the PE error code displaying, the washer is fixed and the PE error has been cleared.
- If you find that the water level pressure sensor is faulty, remove it and replace with a new OEM part.
lg-electronics-washing-machine-water-level-sensor-pressure-switch-hth0u4ums0hor52ud1sodlv4-2-1.jpg
Replacing the water level pressure sensor simply involves locating the sensor in your LG washer. Remove it from the washer and replace it with a new genuine LG washer part. Test washer to be sure the PE error code has cleared and the washer is now working properly
Mar 20, 2017 | LG Washing Machines
I have whirlpool 650s top loader washing machine.it shows PE error when switched on.so please tell me what to do to get rid of this error message in the board
the PE error relates to the fill level of the washing machine. The fill level sensor is a pressure operated device. There is a sealed air line that goes from the bottom of the tub to an air pressure sensor. As the tub fills, it compresses the air in this air pressure sensor. When the tub is filled to the level selected on the dial, the sensor stops the fill cycle.
This air line can be plugged or the sensor itself can be faulty. This air pressure sensor is usually located near the top of the tub just under the top cover. If you can locate it, disconnect the air line from the pressure sensor and blow through it - it may be blocked by lint and soap from several washing cycles. There may be a filter in this line to help prevent this blockage. But the filter may have become blocked itself.
Oct 14, 2016 | Whirlpool Washing Machines
Fault PE....How do I replace the pressure sensor on an LG fuzzy logic 5kg wf-t502 top loader and where can I purchase this part?
PE Means pressure sensor error this spares is very rare to defect 1st check full pressure sensor the wiring harness any damage or wire cut means the error will show in display
Mar 26, 2015 | LG Washing Machines
Getting pe error
Whirlpool Washing Machine Displaying Fault Code PE The part(s) or condition(s) listed below for the symptom PE - PRESSURE SENSOR ERROR // Water level pressure switch error are ordered from most likely to least likely to occur. Check or test each item, starting with the items at the top of the page.
per https://www.repairclinic.com/RepairHelp/How-To-Fix-A-Washing-Machine/408-5--/Whirlpool-PE-PRESSURE-SENSOR-ERROR-Water-level-pressure-switch-error
b2kjqj
Dec 09, 2017 | Whirlpool Washing Machines
Washing maschine runs for 5 sec and trip
PE code stands for "Pressure sensor Error" check the sensor and the small tube that is connected to the outer tub for debris.
Dec 18, 2013 | LG WM-2277HW Front Load Washer
White Magic 650H. Why is error code PE displayed and water reuse LED blinking?
In my research, the PE error relates to the fill level of the washing machine. The fill level sensor is a pressure operated device. There is a sealed air line that goes from the bottom of the tub to an air pressure sensor. As the tub fills, it compresses the air in this air pressure sensor. When the tub is filled to the level selected on the dial, the sensor stops the fill cycle.
Sep 29, 2013 | Whirlpool Washing Machines
I have a LG WD-1018C that won't work and has PE on the screen and I can't find the manual to fix it. Can you please tell me what PE means. Thanks
The error code "PE" stands for pressure sensor error. This is typically caused by a malfunctioning water pressure sensor switch.
Mar 09, 2011 | LG Washing Machines
How to reset eprom for PE error
Hi, PE error code means there is an pressure sensor error in your machine .You need to check pressure it will be giving incorrect indication . Pressure switch is faulty you need to change it . Procedure for changing is : 1.Power off the machine remove backcover and top cover. 2.The pressure switch is a round item about 3 inchesacross with several wires and a thin rubber pipe attached. 3.It generallysits just under the top cover.
Apr 08, 2010 | LG WFT1071TP Top Load Washer
Washing Machines Logo
Dan Webster
Dan Webster
Sal De
