Question about Mitsubishi Heating & Cooling
Mitsubishi error code UOE9
Please explain the meaning of error code UOE9 which appears on digital display of my mitsubishi aircon
notsomot
  • 67 Answers
SOURCE: Error code E39 for Mitsubishi Heavy Industry Ceiling cassett type
E39 Fault is thermister, Mitsubishi way of saying im not going to start because there is something wrong. Generlly it is compressor fault or short of gas. Im guessing if you turned the power out. Waited twenty seconds, turn it back on. Now if you go to the outdoor part. Wait exactly 3 mins. If you hear the compressor try to start and fail then it would more then likely be your compressor if you dont hear anything and the unit faults out it will either be a board or short of gas.
Either way If the unit is under five years old get a warrenty agent out to look at it.
Sorry I couldnt tell you for sure but MHI are very vague when it comes to fault codes
Posted on Mar 05, 2009
SOURCE: MITSUBISHI ELECTRIC'S AIRCON REMOTE CONTROL ICON
lock out controllers
Posted on Oct 20, 2009
SOURCE: ERROR CODE E33 ON A MITSUBISHI FDC304HEN. The
The high speed fan not kicking with High head pressure.
Model Mitsu FDC304 HEN
Posted on Nov 01, 2010
hvac1960
  • 2133 Answers
SOURCE: I have a Carrier Aircon.
E5 Outdoor activation of compressor over heatprotection or motor lock
Please clean the condenser coil. And also check out door fan motor rpm. Rpm may be less due to weak capacitor. Replace it.If motor locked you have to replace new motor only.
If helpful, please write.
Posted on Dec 20, 2010
hvac1960
  • 2133 Answers
SOURCE: Hi I have mitsubishi aircon with an E6 error code.
E-6 Indoor unit heat exchanger sensor [ThIR] defective (resistance is open circuit or closed circuit).
• Poor connection of sensor connector on the indoor PCB.Rectify.
Posted on Jan 01, 2011
My Beko BK5200 AirCon has error code E6 displayed. What does it mean?
Barry, check link below.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
1 Time Flash E6 error troubleshooting part 3 of 3 for Mitsubishi Electric...
http://homeappliance.manualsonline.com/manuals/mfg/beko/beko_air_conditioner_product_list.html
Mar 04, 2016 | Computers & Internet
Display error code E6
E6 is a comms error try turning the power off at the isolator and reset everything. if it comes back you might have a lose interconnecting wire between the indoor unit and outdoor unit
Apr 15, 2014 | Mitsubishi Heating & Cooling
What does p4 means flashes in screen of remote of mitsubishi aircon.
That means "Abnormality in drain sensor" so perhaps a blocked condensate drain.
Nov 19, 2011 | Mitsubishi Heating & Cooling
Hi I have mitsubishi aircon with an E6 error code. How do I fix it?
Dec 05, 2010 | Mitsubishi MS12TN Air Conditioner
How to enter security code on car stero
if u dont have owners manual give a call to ur local mitsubishi dealer they can explain it over phone
Oct 31, 2009 | 2000 Mitsubishi Eclipse
Mitsubishi Lancer 2004 Radio Code Not Working
Use the first four radio station preset buttons to enter the code.
1: Push radio preset#1 until first digit of your code appears.
2: Push radio preset#2 until second digit of your code appears.
3: Push radio preset#3 until third digit of your code appears.
4: Push radio preset#4 until fourth digit of your code appears.
5: Push either tape or cd button.
What to do if your radio says OFF instead of CODE
(Courtesy of mittech)
If your radio says OFF it means you entered the wrong radio code three times. To get it to say CODE again do the following.
1:Turn the key to on or accessory.
2:Push the power button so that the radio display says OFF.
3:Let the car sit for 1 hour.
4:The radio display will go blank.
5:Turn the radio on and it will say CODE again.
Sep 04, 2009 | Infinity Reference 1211a Car Audio...
Radio displays off after three separate attempts to put in code
radio has a four digit code to be able to work,if you do not have the code,you will need to pull radio out and copy serial # on radio to get code from dealership,after you get code turn ign.switch to on position(do not start car)for about an hour or until code appears on display ,enter each code number with ind. station buttons it should come on if it does not enter code again but after last entry hit cd button,you will get 3 attempts before radio goes into failsafe again
May 26, 2009 | 2000 Mitsubishi Mirage
Error E3 on Mitsubishi HS-U795
Try this :
If your VCR malfunctions, try the following steps prior to contacting your Mitsubishi Dealer:
1 Check the Trouble Checks below to see if there is a solution to the current problem that you are
experiencing.
2 If the problem is not addressed on the Trouble Checks, the safety circuits in the VCR may be in
operation, thus please try the following: (the clock setting and the timer recording will be deleted.)
1 If possible, press EJECT on the front panel and remove the tape.
2 Press TIMER RESET on the rear panel with a pencil or a ball point pen.
3 If a tape is not loaded, press POWER to turn the power on. If a tape is loaded, wait about 1 minute
until the tape protecting function is completed, then press POWER.
3 You may also try the following procedure if the above steps did not resolve the problem (All settings will
be reset to the default settings.).
1 Press POWER on the front panel continuously for about 8 seconds until the current time display on
the front panel shows "- : - -."
2 If a tape is not loaded, press POWER to turn the power on. If a tape is loaded, the tape protecting
function will work and "99" will appear on the front panel display to begin count down. Wait about 1
minute until it reaches "00" to show the tape protecting function is completed, then press POWER.
If the problem with your VCR persists, contact your Mitsubishi dealer for assistance.
Im looking for error codes.
Mar 10, 2008 | Televison & Video
Ducted aircon error code
1. check cirkit board.
Nov 30, 2007 | Heating & Cooling
Heating & Cooling Logo
26 people viewed this question
Top Mitsubishi Heating & Cooling Experts
D. E. Hev
MightyMikeJr
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
