Question about Mitsubishi Heating & Cooling
Error Code UOE9
Indoor unit of Mitsubishi Air-con Ceiling Cassette w/ model No. FDT100VD is keep on blinking and automatically turn off. The suction charge is 125psi while the discharge is 120 psi. what does it mean since the unit is not functioning well.
burzerko
  • 254 Answers
SOURCE: air-conditioning; error code: 425
Try Samsung.com
Posted on May 30, 2008
notsomot
  • 67 Answers
SOURCE: Error code E39 for Mitsubishi Heavy Industry Ceiling cassett type
E39 Fault is thermister, Mitsubishi way of saying im not going to start because there is something wrong. Generlly it is compressor fault or short of gas. Im guessing if you turned the power out. Waited twenty seconds, turn it back on. Now if you go to the outdoor part. Wait exactly 3 mins. If you hear the compressor try to start and fail then it would more then likely be your compressor if you dont hear anything and the unit faults out it will either be a board or short of gas.
Either way If the unit is under five years old get a warrenty agent out to look at it.
Sorry I couldnt tell you for sure but MHI are very vague when it comes to fault codes
Posted on Mar 05, 2009
relaga58
  • 158 Answers
SOURCE: p8 eroor code
P8 error is abnormal pipe temperature indoor. If you are running it on heating P8 error will appear because the disc pressure is too high. It could be overcharged.
Posted on Jun 01, 2009
  • 400 Answers
SOURCE: Error code CH 02 for a ceiling cassette model
CH02- Means "Indoor coil sensor is faulty or not connected"
Posted on Nov 19, 2009
Testimonial: "thanks for help i will keep you posted when ever I have a problem"
SOURCE: Mr. Slim MXZ30TN Air Conditioner: Indoor unit blinks on and off what is the problem?...
continuous flash is frost prevention ...clean the filter & switch fan to high
flashes once every 2 sec could be room air sensor contact loose/short...call dealer
flashes 2x every 2 sec is indoor coil sensor contact loose/short...call dealer
flashes 3x / 2sec sensor contact problem, or compressor overload protection trip or gas leak...call dealer
Posted on Jun 02, 2010
Mitsubishi timer light 6 times blinking
Indoor unit indicator
RUN lamp = 6 time flash
TIMER lamp = Comes on
Outdoor unit indicator (LED5) = Stays off
Description of trouble = Indoor fan motor error (2)
Cause = Defective fan motor, Connector poor connection
Conditions of flashing = When air conditioner is operating and indoor fan motor is turned ON, indoor fan motor speed of 400 rpm or under continued for more than 30 seconds. (Air conditioner stops.)
May 29, 2016 | Mitsubishi Heating & Cooling
How to fix lg code ch51
What is the model of your air conditioner. With out that information i cant help you with your ac repair problem.
Check us out online at AC Service Delray Beach Fl
Apr 23, 2016 | LG Inverter Flex Multi Indoor - 4 Way...
Error code e4 unit airconditioner
Not sure about E4 , but 4 blinks or flashes usually means the compressor isn't starting properly. It could be a faulty start capacitor or wiring or faulty indoor PCB (Board)
Oct 18, 2013 | Mitsubishi Mr. Slim MXZ30TN Air...
My split unit air con will switch off automatically every 10 minutes and the lights will blink. It can only be turned on again if the power is switched off from the mains.
May be in indoor screen there is some error code. Don't worry. I try to solve it. Normally after 3 minutes compressor will start. If compressor amps gradually increase due to condenser block or less rpm of fan motor. Please ensure with amps meter for increasing ampere It will run just 10 minutes or up to the maximum running amps and get tripped. Service your indoor and out door and check. . Is it helpful?
Dec 28, 2010 | Electrolux Heating & Cooling
P8 eroor code
May 31, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
Panasonic casette air conditioner-display error temp 'CHECK'
Check that your water pump is working and not blocked up as the unit will keep swicthing off if it can not get rid of the water.
Nov 24, 2008 | Panasonic CW-C60RU Air Conditioner
Mitsubishi wall unit srk50zg condenser src50zg air con not heating new install
Double check your wiring .if the indoor fan is not blowing then you either have an electrical issue OR bad blower motor .
May 24, 2017 | Refrigerators
Heating & Cooling Logo
55 people viewed this question
Top Mitsubishi Heating & Cooling Experts
D. E. Hev
MightyMikeJr
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
