Sharp al 1216 code flashing l - Office Equipment & Supplies
  • 61 Answers
SOURCE: Sharp AL 1010
Hi, to reset drum light follow this sequence: press cancel, exposure, cancel, exposure. Display goes blank, enter 24, print, 07 print, cancel cancel. Cheers
Andy
Posted on Jan 26, 2008
Opelmanz
  • 62 Answers
SOURCE: SHARP AL-1216: HOW TO REMOVE H4 ERROR CODE
www.tinli.com.hk/PDF/AL1216.pdf
Hope this helps.
paul
Posted on Nov 02, 2008
claudiomn
  • 10 Answers
SOURCE: Sharp Al-1216 Laser copier/scanner but doesn't work on my new Lap
www.sharp-usa.com
Posted on Jan 17, 2009
  • 125 Answers
SOURCE: Sharp AL 1631 is flashing 1 L. What does that
Hi:
This might refer to your scanner assy being locked. The scanner assy is the unit under the glass that scans your document prior to copying it. Look inside the cavity where you pick up your completed copies. Look at the upper left corner and see if there is a knob there. If there is, make sure it is in the completely unlocked position.
Andrew
Posted on Aug 09, 2009
  • 257 Answers
SOURCE: H 4 FLASHING, MANUAL LOST, AL-1220 Sharp Photocopier
Try to press #, Interrupt, C, Interrupt in that order and enter 14 then press copy key.
Posted on Jan 07, 2010
What is the causes of h4 error in sharp al-1216 photo copier
The h4 error code isn't complete. There should also be a "sub-code" which defines more precisely where the problem is.
May 22, 2015 | Sharp Office Equipment & Supplies
I HAVE SHARP AL-1216,I DONT KNOW HOW TO REMOVE H2 ERROR CODE
H2 deals with the fixing unit.... You need to fix the problem before it can be rest. It may just be the fuser lamp is blown. You have to take it out and if it looks like a candy cane that is the problem. Good Luck
Jan 15, 2013 | Office Equipment & Supplies
How do I get a driver for Sharp AL-1216 to print on my PC
go to the sharp site and download the appropriate driver for your operating system.run it and that's it
Aug 15, 2011 | Sharp AR-5316 Advanced Digital Imager...
What Error H4 for Sharp AL-1216?
It is the fuser temparature error, may be with the heater rod, thermistor or thermostat, or with the mcu pwb. rate this and vote for this
Apr 06, 2011 | Sharp AL 1631 Copier
Can you help me for may copier sharp AL 1216 with the error code H4
Press C, Auto, C, Auto keys in that sequence whole process should be within 5 sec, enter 14 print.
Nov 12, 2009 | Sharp AL-1217 Copier
Sharp AL-1340 Scanner hangs up, grinding sound, with E-7 code
The scanner rails will dry out. Try a drop of oil on the rod the scanner travels on. There are two bushings that slide along the rod/rail. Good luck.
Nov 10, 2008 | Sharp AL-1000 Copier
Hope this helps.
paul
Nov 01, 2008 | Office Equipment & Supplies
22 people viewed this question
k24674
jasbo
jasbo
