Question about 1990-1993 MERCEDES BENZ 300SL 300 SL CARBON FIBER VINYL WRAP SHEET / FILM 60 X 180 5FT X 15FT 1991 1992 90 91 92 93 MERCEDES-BENZ R129
Headlights wont turn off
The car sat for about a month in cold weather and now the headlights won't turn off unless the battery is unhooked. Any advise would greatly be appreciated thanks
    Filmmaker:
    Uploaded 5 video answers.
    Scholar:
  • 74 Answers
Check fuse box for corrosion. Have definitely heard of corroded fuse boxes shorting and allowing power to continue through the circuits
Posted on Feb 07, 2014
    Genius:
  • Trimworks Master
  • 1,013 Answers
Wont be fuse box if a fuse is corroded it wont make any difference this would not make the lights turn on and keep on the switch can only do this there is a comon fault with the light switches try taking the switch out and remove the rear wires if the lights go off its the switch could also be a relay if the relay has shorted or rusted over then this could cause the lights to stay on only other thing is the lighting circuit has a permanent live which will cause the lights to stay on but this is unlikley
Posted on Apr 03, 2015
97 firebird, won't turn over by key, headlights going up and down like crazy
look at the battery first.. there are two connections.. one a plus and one a minus,, check and clean both of these first make sure they are snug not loose and somewhat clean..check for a good charge also. these batteries go dead quickly in cold weather..usally when the headlights go dead the battery is dead also..(need to charge or jumpstart) if you have a charger connect it and let charge for a while(if not a second running car connected for a while will do) see if the battery is good, if not replace it.. repost findings..
Jan 27, 2013 | 1997 Pontiac Firebird
Gave a jump start and now headlights don't work on a 2005 yukon denali
sound like battery has weak or battery terminals and post need cleaning. have battery charged and checked, if battery good. alternator not charging battery. if battery over 5 years old more likely battery is bad.if battery too weak head lights wont turn on battery dead this time of year if battery old. cold weather will finish it out.
Nov 28, 2012 | 2005 GMC Yukon Xl Denali
Why wont my headlights turn on in cold weather
Could be the relay. relays tend to act up in cold weather.
Feb 09, 2011 | 1991 Dodge Ram 350
Want start in cold weather?
the car won`t start in cold weather even when plugged in alternator was changed 4 months ago just changed battery thinking it was the battery but seems like something is draining the battery overnight? Maybe its a bad connection??Plz help!!!
Jan 22, 2011 | 2004 Saturn ION
I'm also having the same problem, got my breaks down 1 month ago, then the car wouldnt start last wednesday, got a new battery. And now my car wont shut off! I'll have the key in my hand. Has something to...
throttle kit update is a possibility....it's a bulletin that came out. supposedly cold weather and/or high humidity causes this problem to surface and then you have to get the update.
Dec 19, 2010 | 2005 Chevrolet Aveo
Installed new battery yesterday, drove fine. Sat in parking lot while at work. After work drove home, car stalled and died in very cold weather. Restarted after 10 min. Drove home another 2 minutes. Two...
All lights are supposed to turn off when a subaru key is off right? No! There is a switch on top of the steering wheel column that will turn on lights for warning when parked. You somehow have hit that switch.
Jan 08, 2010 | 1991 Subaru Legacy
2001 ford 250 s/dv-10turns over fine. wont start sometimes.when it starts it runs fine.seems like cold weather makes it worse.if it starts it wont die.started about a month ago and getting worse.
Make sure the battery doesn't have a dead cell or is over two years old first. Then depending on usage I would definately think about getting a new starter. I would suspect your battery first, due to the cold weather corrolation.
Jan 04, 2010 | 2002 Ford F250 Super Duty SuperCab
My windshield wipers and radio haven't worked since the jeep sat around for about 3 months in cold weather. I checked the fuses. Any advice what to do next?
Check the ignition key. When you start the engine, the key must go back by itself but because the cold, it get stuck so, just turn back the key a little.
Oct 12, 2009 | 1988 Jeep Cherokee
Have cobra 29wxnwst radio. Truck sat for 3 months
Turn up the RF gain all the way and leave it.
RF gain is basically how open your receive is. There is really no reason ever to have it down unless you are trying to hear only close stations to you.
If you RF gain is up, your mic pins my be oxidized, or mic bad.
Try a different mic, and or clean the contacts in the connectors.
Sep 18, 2009 | Cobra 29 WX NW ST 40-Channels Base CB...
Nissan max. 1995 wont start during cold weather
I had the same problem for years until I cleaned the throttle body, Complete instructions can be found here http://www.motorvate.ca/mvp.php/517. It's easy and it worked for me. Good luck.
Sam
Feb 25, 2009 | 1995 Nissan Maxima
1990-1993 MERCEDES BENZ 300SL 300 SL CARBON FIBER VINYL WRAP SHEET / FILM 60 X 180 5FT X 15FT 1991 1992 90 91 92 93 MERCEDES-BENZ R129 Logo
138 people viewed this question
Top Trimworks Vehicle Parts & Accessories Experts
Timllfixit
 AEpittsburgh
AEpittsburgh
ivan whisker
ivan whisker
Are you a Trimworks Vehicle Part and Accessory Expert? Answer questions, earn points and help others
