Question about 2004 Mustang Factory Wiring Diagrams
Where does the engine no sits on the block - 2004 Mustang Factory Wiring Diagrams
    Habit-Forming:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 113 Answers
Depends of the Make and Model. Sometimes stamped on a machined pad near where a distributor would attach.
Posted on Feb 14, 2015
  • Speedracer70 Feb 14, 2015
Engines starts well, then I run the car a few blocks then engine turns off
Check yr fuel pump , it mite be foulty or on the way to go. It a bit comen 4 that kind of problem. it usialy situated in yr fuel tank posbly under yr back sit, under a round lid that is screwd under the sit on top of yr fuel tank. hope that helps. G/luck
Tony
Jan 28, 2014 | 1999 Ford Expedition
2004 Sunfire block heater
The element does sit in the coolant. It will be immersed in the engine's water jacket. The block heater is mounted in a freeze plug location.
Jan 21, 2014 | Cars & Trucks
Does coolant sitting in the combustion chamber cause damage? if there is gunk from backfiring in the combustion chamber will that damage my engine?
It depends.
If liquid coolant is sitting in a cylinder, and it is more than say a tablespoon full, and you start the engine, it could damage the cylinder wall or the piston. Liquid will not compress, so as the piston comes up to the top, something would have to give and that would usually be the piston or the connecting rod.
A constant leak could scratch up the cylinder wall.
I would not expect any residue from an engine that backfires since it is merely firing the fuel in the intake or exhaust manifold rather than in the cylinder.
Feb 10, 2013 | Cars & Trucks
Wher is the crank sensor located in 1999 grand cherokee laredo located
Hi there:
Check Grand Cherokee Jeep Limited 1999/2000, the CKP sensor is located on the right side (driver side) at the end of the engine block when you open the hood and facing the engine block..the sensor sits on the bell housing..It has its cable connector end pulled all the way to the left side of the engine block and connected there, so you may have to first locate and grab that connector cable end, near the oil filter at that left side at the end of the engine block , and then you feel and trace the connector cable all the way through the back of the engine block back to the CKP sensor on the right end side of the engine block in order to easily locate the sensor.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Sep 14, 2012 | 1999 Jeep Cherokee
99 tiburon over heating
condensor sit in front of radiator if condensor damaged to badly it will block air flow through cooling fins which will block off air from radiator cooling fins when vechicle moving it will overheat if condensor or radiator damaged.your cooling fan need to be working because it will turn on when engine get to certain temperature if not engine will over heat.
Feb 12, 2012 | Cars & Trucks
If a diesel truck sits to long could it damage the fuel pump
Well,
It depends upon the enviroment the truck is stationed in. If you did not drain the truck before parking it for a long time. It tends to block intake valves etc.
Proton
Jul 12, 2009 | 1985 Ford F 250
Engine Block heater instalation
If you are useing one that goes where a frost plug is i usually put it in the center on the right side of the engine.(right side of engine is while you are sitting in truck). The left side has the starter in the way.
Jan 26, 2009 | 2001 Dodge Ram 1500 Truck 2WD
Won't start in cold weather, the battery dies if it sits 2days
WELL UR BATTERY HAS DEAD CELLS Y ITS DYING AND WHEN UR BELOW 0 A BLOCK OR OIL HEATER I A GOOD IDEA TO HAVE.A DIPSTICK OIL HEATER CAN BE BOUGHT AT AUTO STORE .
Jan 16, 2009 | 2005 Dodge Sprinter 3500 Standard Roof
2004 Mustang Factory Wiring Diagrams Logo
Top Ford Vehicle Parts & Accessories Experts
xxxxxx xxx
Thomas Perkins
Thomas Perkins
Colin Stickland
Colin Stickland
Are you a Ford Vehicle Part and Accessory Expert? Answer questions, earn points and help others
