Question about Bunn GRX-B
Replacement parts Filter basket
Do you have a replacement filter basket for Cook's brand coffee maker #780-2403
Hello, Kramer82074 -
Fixya.com does not sell any type of replacement part for anything.
If you have the owner's manual for your coffee maker, there may be a Customer Service phone number given. If so, I suggest you call that number and ask about a replacement filter basket.
In the meantime, I will keep on looking for a source/s for a replacement filter and add the information which I hope to find to my answer.
Added: From articles I have found online, it appears that Cooks is a proprietary brand name of J. C. Penney. However, aside from calling the general J. C. Penney Customer Service number, I still haven't found a source for purchasing a replacement filter for your coffee maker.
This is the general J. C. Penney Customer Service number:
800-322-1189
More: If you call the J. C. Penney Customer Service phone number and do not obtain information on a replacement filter, you may find a replacement filter basket through Amazon.com. Look at this Amason.com link showing replacement filter baskets:
https://www.amazon.com/s/ref=nb_sb_noss_1?url=search-alias%3Daps&field-keywords=coffee+maker+filter&rh=i%3Aaps%2Ck%3Acoffee+maker+filter
(copy and paste the above URL into the search box of your favorite browser)
One of them shown there may fit your coffee maker.
Jan 06, 2018 | Coffee Makers & Espresso Machines
Dyna-glas filter basket replacement
You can find those baskets at many pool stores both online and brick and mortar stores.
Rod
US Parts Center
Mar 30, 2014 | Polaris Pool & Spa
How do i clean my cuisinart grind and brew coffee maker? i can't find my instruction booklet and it needs to be cleaned. thanks!
From the manual I found online here.
CLEANING AND MAINTENANCE COMPLETELY CLEAN AND DRY ALL PARTS AFTER EVERY USE. Always turn coffeemaker OFF and remove the plug from the electrical outlet before cleaning. Open the reservoir lid*. Remove the grinder basket lid by using the recessed area on each side of the lid. Then remove Grinder Basket. Open Filter Basket Door. Remove Filter Basket Cover, Filter Basket and Filter Basket holder. The grinder basket, grinder basket lid, filter basket and filter basket cover can be washed in warm soapy water and rinsed thoroughly, or cleaned in the upper rack of the dishwasher. Dry all parts after every use. Do not put any water in the unit once the grinder basket has been removed. Wipe the area under the grinder basket with a damp cloth. If water gets into the grinder motor, the motor may become damaged and may malfunction.
DECALCIFICATION Decalcification refers to removing the calcium deposits which form over time on the metal parts of the coffeemaker. For best performance from your coffeemaker, decalcify the base unit from time to time. The frequency depends upon the hardness of your tap water and how often you use the coffeemaker. To clean, fill the water reservoir to capacity with a mixture of 1/3 white vinegar and 2/3 water. Turn the coffeemaker on by pressing the ON button. One cycle should be sufficient to adequately clean the coffeemaker. When the cycle is completed and the five beeps sound, turn coffeemaker off. Repeat operation, this time using fresh cold water.
Sep 09, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
I have a grind and brew and can't get the grinding basket out to wash.
Open the reservoir lid. Remove the grinder basket lid by using the recessed area on each side of the lid. Then remove Grinder Basket. Open Filter Basket Door. Remove Filter Basket Cover, Filter Basket and Filter Basket holder. The grinder basket, grinder basket lid, filter basket and filter basket cover can be washed in warm soapy water and rinsed thoroughly, or cleaned in the upper rack of the dishwasher. Dry all parts after every use.
Sep 01, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Need to replace filter basket drip spout rubber ring
After searching for the replacement basket on web took whole coffee maker back to jcp and they replaced the 12cup coffee maker with a new item.
Jul 28, 2009 | Coffee Makers & Espresso Machines
Missing the black filter basket to my coffee maker
I would suggest calling Kitchenaid Customer Service. They may be able to send this part out at no charge or low cost to you as a replacement.
Their toll-free telephone number is 1-800-541-6390.
Mar 30, 2009 | KitchenAid PRO LINE KPCM100 Coffee Maker
Cuisinart DGB-300 coffee maker brew pause valve
No one has just the individual part, but you can get the whole brew basket with the part included on Cuinart's website, or by calling them.
Feb 03, 2009 | Cuisinart DCC-100 Coffee Maker
Pod filter basket
I can not this machine, sorry
I do service on Saeco, Kenwood, LaPavoni, Spidem, Cuisinart, Breville.
Have a nice day
/Mirran
Oct 04, 2008 | Nemox Caffe NEM 205 Espresso Machine
Bunn GRX-B Logo
62 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
evans_lloyd
Level 1 Expert
gbob59
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
