Question about ASUS M51 Computers & Internet
Turn wireless - M51 ASUS Computers & Internet
Turn on wireless
start button
control panel
wireless icon
reset it there
Jun 19, 2012 | HP Computers & Internet
Turning on wireless
Maybe you don't have your wireless turned on. Look onboth sides and in front for the Wireless Switch and turn it on.
Also once the wireless switch is turned on there are keystrokes that can togglethe wireless on or off. Normally you would Press and Hold the FN functionkey located at the lower left of the keyboard, then hit the correct F1 thru F12key that toggles the wireless. The correct F1 thru F12 key to hit willhave the wireless signal icon )))) on it. Or it might have the icon of a towerwith the wireless signal icon )))). Normally the screen will displayWireless On or Wireless Off when you toggle the wireless.
On some laptops there will be a button just above the keyboard or on the side or in front of the laptop..
Jun 09, 2012 | Toshiba P000413700 QOSIMO G10 G15 SERIES...
Where is the wireless radio switch
Jun 05, 2012 | HP Computers & Internet
Wireless capability won't turn on
Make sure you Press and Hold the FN function key then hit the F2 key.
Maybe you don't have your wireless turned on. Look on both sides and in front for the Wireless Switch and turn it on.
Also once the wireless switch is turned on there are keystrokes that can toggle the wireless on or off. Normally you would Press and Hold the FN function key located at the lower left of the keyboard, then hit the correct F1 thru F12 key that toggles the wireless. The correct F1 thru F12 key to hit will have the wireless signal icon )))) on it. Or it might have the icon of a tower with the wireless signal icon )))). Normally the screen will display Wireless On or Wireless Off when you toggle the wireless.
Some laptops might have a wireless button instead of a wireless switch located above the keyboard or on the front or sides.
Jun 02, 2012 | ASUS K40IN Notebook
I have a HP pavilion entertainment PC laptop.The wireless button of my laptop has turnedd off and not getting on.Please help me.
hpweb_1-2_minus.gif Wireless device is turned off or disabled The power to the wireless network and Bluetooth devices is controlled by a switch or button on most computers. It is possible to accidentally bump the button and turn off the wireless service. c02230159.jpg On most computers, there is an LED light that glows blue when the wireless device is turned on and enabled, and glows orange when off or disabled. Some newer models use different a different color scheme, see the user guide for more information. To turn on and enable the wireless device, do the following:
  1. To turn on the wireless device, simply move the switch to the on position. On some computers, the switch is actually a touch point on the panel above the keyboard.
  2. To enable the wireless device, right-click the HP Wireless Assistant (disabled) icon c02448899.jpg and select Open Wireless Assistant . Click Turn On . The HP Wireless Assistant (enabled) icon c02448900.jpg will display.
  3. You can also try pressing the fn+ F2 keys simultaneously to enable the wireless device.
Apr 24, 2011 | Computers & Internet
I am having trouble connecting to the internet because my WLAN has been turned off, how do I turn my wireless back on?
From the HP website:
The power to the wireless network and bluetooth devices is controlled by a switch or button on most computers. It is possible to accidentally bump the button and turn off the wireless service. c02230159.jpg On most computers, there is an LED light that glows blue when the wireless device is turned on and enabled, and glows orange when off or disabled. Some newer models use different a different color scheme. To turn on and enable the wireless device, do the following:
  2. To enable the wireless device, right-click the HP Wireless Assistant (disabled) icon c02228164.gif and select Open Wireless Assistant . Click Turn On . The HP Wireless Assistant (enabled) icon c02228163.gif will display.
Apr 18, 2011 | HP Pavilion dv4000 Notebook
My wireless internet switch will not turn on.
Apr 17, 2011 | HP Computers & Internet
Wireless no longer works how do i turn wireless
Make sure it is turned on in your BIOS hit f10 or the toggle switch at startup and look under Devices. both wireless options should be set to ON.I found this to be an issue with the intel 2200bg wireless cards.
Nov 24, 2009 | Compaq tc1100 Tablet PC
Computers & Internet Logo
11 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
