Question about U-Line 75WC Wine Cooler
Unit not running; thermostat wires jumped and it runs. Replaced thermostat and it ran for 5 minutes then stopped. Jumped thermostat wires again and unit started running. Any suggestions?
2 Suggested Answers
  • 93 Answers
SOURCE: U-line 75R was not cold. Shorting the two wires at
This U-Line does not have defrost timer, check the wire connection on the thermostat or you may have a bad new thermostat.
Posted on Mar 02, 2010
1996 ford tbird fan runs at high speed once engine is started.
Have you tried changing the fan relays? Sounds like they may be stuck on.
Mar 11, 2014 | Ford Cars & Trucks
Transmission or altenator?
I would say change the alternator out. Start with the simplest and cheapest factor first. Without the alternator keeping the engine running its hard to put it any gear.
Sep 26, 2013 | 1995 Lexus LS 400
When you jump the car it runs for a little while and then lights dim and it dies. Alternator has been replaced and it still does this.
You could have a bad cell in your battery, autozone or advanced auto can test this for you free of charge. there are other things that can be causing this as well like an exposed power wire grounding out on the frame of your car or an amplifier that powers your subs going bad as well.. best bet is to start with the battery!
Jan 29, 2013 | Cars & Trucks
Had starting problems and cleaned terminal wires, car started. Yesterday same problem, adjusting wires did not work. Had battery jumped, car started. I warmed up car for 5 minuted before driving. Car...
I would say that you need to replace the alternator. The car was running on the batteries power. When you drove the car, it ran the battery completely dead.
Jan 14, 2011 | 1997 Ford Taurus
H100id induced pool heater runs for 4 minutes then stops heating
I just solved this about an hour ago. It's the connection from the circuit board to the ignitor. The same thing happened to me that it ran a long time and then it wouldn't. At some point it loses spark. The large wire from the board to thee= ignitor is the culprit. Take the ignitor out and press the two electrodes to about 1/4"-3/8max. Clean the surface plate where it meets the heater and also clean the brass piece on the othe end. Then clean the brass piece on the circuit board. Slide the 2 boots down a little and expose the receptacles. Press them a little with pliers, put them on their respective connections and then slide the boots back on. It started right up and has been running since! This after I bought a new gas valve $178! Let me know if this does it for you.
Jul 27, 2009 | Hayward H Series Induced Draft Abg 100,000...
My 2003 PT cruiser dies at a stop sign and then it won't start
You may need a new battery (alternator will keep it running once jumped but if you stop, the idle may not keep the car powered long enough). If you've never replaced the battery, its about time - they have a life of about 5 years.
Jan 02, 2009 | 2003 Chrysler PT Cruiser
Running really rough
Spark plugs, Ignition wiring, ignition coil, or high tension cord may be faulty. They must be inspected one by one and replaced if necessary.
Jul 06, 2008 | 1999 Hyundai Accent
U-Line 75WC Wine Cooler Logo
65 people viewed this question
Top U-Line Furniture Experts
John Tripp
John Tripp
Sal DeAngelo
Dan Webster
Dan Webster
Are you an U-Line Furniture Expert? Answer questions, earn points and help others
