Question about Kettler Giro P Programmable Upright Bike
Knocking sound when peddaling - Kettler Giro P Programmable Upright Bike
Passat loosing vacumm to the servo
have to check the vacume system firts also try pulling up on brake pedal wile the car is running listen for a change in sound by brake peddal hissing sound could be a bad booster
Feb 04, 2013 | 2003 Volkswagen Passat
To take off clutch master cylinder man tt zx
just go ahead to replace the cylinder.
Jan 29, 2012 | 1990 Nissan 300ZX
I have a 91 s10 2wd 5spd with a 2.5 4cyl... i bought the truck with the brakes not working, it had a bad rear brakeline that was cracked right in front of the rear driver tire. and since this truck is...
the master cyclinder is divided into diagonal wheels. meaning that each line from the master cyclinder provides fluid to a front wheel and rear wheel. on the front resevoir of the master cyclinder it would be perhaps the left front and right rear brake for example. you need to block the lines going to the rear wheels independently and then bleed the brakes again starting with the wheel furthest from the master cyclinder.
Dec 08, 2010 | 1991 Chevrolet S-10
How to bleed brake lines for a 1990 oldsmobile cutlass ciera
Two people, one to pump the peddal and one to open and close the bleeder valve....
Person 1 pumps the peddal 5-6 times, then holds the peddal, while person 2 opens the valve till the peddal hits the floor, then person 2 closes the valve.
you start on the Passenger rear and do this till you get no air and only fluid, then repete process on Drivers rear, then Passenger front, the Drivers front...
Make sure valve is closed when pumping or realsing the peddal, as this will allow air into the system.
Check fluid level after each wheel to ensure you don't run empty during operation.
Sep 15, 2009 | 1990 Oldsmobile Cutlass Ciera
How do i bleed the brakes on my 1998 gmc jimmy
it takes two people to do, one to pump and hold the brake peddal and one to open the bleeders....
One person pumps the peddal 5-6 times and holds, while the other starts at the Passenger rear tirer and opens the bleeder valve till the brake peddal hits the floor, and close it, do this till no air comes out but only fluid, then go to Drivers Rear, then Passenger Front, then Drivers Front.....
DON'T open the vlave while they are pumping, or allow them to let up on the peddal till you have the vlave closed again, as that will put air back into the system.
If you have any other probs, or questions, email me at dswenk@live.com
Sep 14, 2009 | 1998 GMC Jimmy
Stiff break peddal hot breaks
what are you referring to that is still heating up ? from the info that you have give it sounds like power brake booster is leaking or loosing vacuum
hope2help shack
Apr 17, 2009 | 1989 Peugeot 405
Kettler Giro P Programmable Upright Bike Logo
Top Kettler Exercise & Fitness Experts
Jim London
Jim London
ray gallant
Steven's...
Steven's...
Are you a Kettler Exercise and Fitnes Expert? Answer questions, earn points and help others
