Question about Kenmore Washing Machines
Calibrate washer how do I calibrate a Kenmore 11020022012
2 Suggested Answers
SOURCE: My Kenmore 11020022012 washer stops prior to
timer needs new electric motor to advance from rinse to spin cycle.
or alternately ,you can have your old timer taken out of your washer and sent out to be rebuilt or buy a new timer.
in any case , you will need a kenmore washing machine repairman to take out your old timer and send it away to be rebuilt and expect that to take 2 or 3 weeks
the timer rebuild used to cost$ 50.00 in 1993 and a new timer went for $110.00 to $129.00
for a sevice man to take out and reinstall a timer $60.00 to 100.00 labor
try to google.com or bing.com or ask.com-----and type in : kenmore washing machine,rebuilt timer. you will need the model number of the washer as well as the model number of the timer and the timer may have a different name that kenmore
also try typing in kenmore washer,new replacement timer
try call sears and see how much their service man wants to put in a new timer. I am sure prices have gone up since 1993
when I retired from the major appliance repair busness. i could do the timer remove & install, but I probably live 1000 miles from you.
another option: knowing that you will need to spend around $200.00 or more by the time you get a new timer installed
you might want to see how much lowes or home depot wants for their cheapest bottom of the line washer. that might be a good alternative as it allows you to get a new washer and buy an extended warantee so you dont get stuck with another 200.00 repair. I think they have washers starting at 289.95 only 90.00 morte that repairing your old washer which is going to run for how many more years before it again gives you trouble?
check out lowest prices on bottom of the line washers unelse you want to spend a lot on a fancy washer to make yourself happy.
you can shop on line by just google.com or bing.com and the name of the store. home depot, lowes, sears,walmart
and type in clothes washers.
Posted on Oct 08, 2013
Testimonial: "Thanks for the response. The model number is 11020022012 and is a kenmore top load. I have went through the parts list and cannot find a timer. The washer is just over a year old (naturally just over warranty) and I would hate to throw out an applicance if the part is affordable."
Calibrating whirl pool washer after repair
Linda. I know nothing about this washer, but I did get this info from the attached link, you may still have to call a tech.
Put into diagnostics (left, right, right, right, left, right) @ done you see errors, @ spin you run calibration(this will clear codes and reset board). good luck
http://forum.appliancepartspros.com/washer-repair/537059-whirlpool-cabrio-washer-not-completing-spin-cycle.html
Apr 18, 2016 | Whirlpool WTW5700XW 3.6 cu. ft. Cabrio Top...
How to calibrate samsung top load washing machine
there should be another 7 letters/numbers after wa14 maybe the full model number is on the back or in a manual
Sep 19, 2015 | Samsung WA5451ANW 4.7 cu. ft. Top-Load...
My Kenmore 11020022012 washer stops prior to spinning cycle. If I manually turn the dial to spin, it will spin fine. Need help troubleshooting..
Oct 08, 2013 | Kenmore Washing Machines
Kenmore washer model #21302 lock on light is flashing, will not start
Kenmore top load washer 21302, the sensor light is on and the lid lock light is on with a clicking noise. What could be wrong with it and how do I fix it?
May 21, 2012 | Kenmore Washing Machines
Kenmore Oasis Ld code
LD code is long drain one of 2 things the drain pump is frozen and need to be replaced or there is somthing in the pump. Pull the washer a way from the wall a bit and get a bunch of towels. Lean the washer back against the wall towards the middle in the back you will see the pump take it apart and find the clog.
it can be assessed through the bottom.
May 06, 2009 | Kenmore Oasis 27042 Top Load Washer
New replacement thermostat needs calibrating on my Kenmore oven
There is no real way to calibrate the thermostat. Most ovens have the same problem. By lowering the setting slightly will help get a closer temperature. Sometimes similar thermostats are substituted and may not be exactly the same as the original that came with your oven. Hope my trying to answer your question was helpful, Thanks, Sea breeze
Mar 27, 2009 | Kenmore Ovens
Kenmore Series 90 Washer dial isn't calibrated correctly
push the knob to off and turn knob only to you left...off is in..always unplug unit first
Nov 03, 2008 | Kenmore 15864/15862 Top Load Washer
Kenmore 24032 washer
when you reassembled the case you have pinched the clear tube that goes to the water pressure switch aginst the case and back panel, lift up the console remove the case clips and make sure that the pressure hose comes up through the curve part in the case if pinched off the pressure switch will not satisfy
let me know if you need any more help
May 19, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
37 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
