Question about SATO eSeries CL408e Label Printer
Setup problem I have a Visual FoxPro application which prints labels using CL408e printer.My problem is the following: If I choose : i want to cut every label and save this setup. Next time I can print the labels, but the printer does not cut them. Somehow the printer "forgets" the setup. Every time -when I check printer setup - it shows me: Never instead of Every time. ( I do not know exactly what the option name is in English, because I have a Hungarion version.)Could you please help me where I make a mistake in the setup option? Or my driver is not correct?Thank you very much for your help.Sandor
  • shajdu Nov 05, 2007
    Yes I did. DSW3-1 is ON, DSW3-2 is OFF. (Cutter mode)
    Renaissance:
    An user who is expert in 3 categories / brands.
  • SATO Master
  • 1,362 Answers
You can find the free manual here:
http://www.satoamerica.com/Operator+and+Technical+Manuals/98
Good luck
Posted on Oct 30, 2007
Sato cl408e - printing over perforations. I tried turning the Pitch(all the way to the right) and Offset(all the way to the left), and this helped a little, but still not right. Because of this, when the...
Reset printer sensor threshold setting.
Turn on printer whilst holding down line key untill printer beeps.
Use feed key to step to Gap in display.
Load label plus backing under sensor and not volts reading.
remove labels and place backing only under sensor and note volts reading.
use following formula
High reading + Low reading / 0.5 = Value to use
e.g 2.8 + 1.4 / 0.5 = 2.1.
use result to change value of input using line key once set press feed key to set.
To change label start position use the pitch menu.
Jun 02, 2011 | SATO CL408e Thermal Printer
I am using dos based foxpro application in widows xp. when ever i take print from epson Fx 2175. the print job is paused at last line until i close the application. please rectify.clarify,...
Many DOS programs were designed to write directly to the printer's buffer, rather than to a spooler like more modern applications. It sounds like FoxPro is doing exactly that - and isn't designed to release the job until being completely closed.
Mar 06, 2011 | Epson FX 2170 Matrix Printer
How to install foxpro
You can install this version of Visual FoxPro from a CD-ROM or anetwork to a local hard drive. You must install Visual FoxPro on alocal drive, not a mapped drive. There is no other preparation requiredbefore installing Visual FoxPro. You must have administrator privilegesto install Visual FoxPro. It is recommended that you run withpower-user privileges to use all the provided tools effectively.
Youcan safely install or uninstall using Visual FoxPro Setup. If you areupgrading Visual FoxPro, you must first uninstall the previous versionof of the program. Though both versions of Visual FoxPro can exist onthe same computer, you cannot install the current version of VisualFoxPro in the same directory as the previous version.
If you planto publish XML Web services using Visual FoxPro, you might want to setup Internet Information Services (IIS) on a Windows 2000, Windows XP orWindows Server 2003 computer. Refer to your operating systemdocumentation for instructions on how to set up and configure IIS.
030c41d9079671d09a62d8e2c1db6973.gifNote VisualFoxPro setup no longer installs any Windows operating system ServicePacks or versions of Internet Explorer. It is highly recommended thatyou install the latest versions of these components before installingVisual FoxPro. Additionally, Visual FoxPro 9.0 is supported only onWindows 2000 Service Pack 3 or later. For details about installing thelatest Service Pack, visit the following Microsoft Web page at http://www.microsoft.com/windows2000/.
Full installation includes all Visual FoxPro program files, online help, and samples files.
To install Visual FoxPro
  1. Quit all open applications.
    030c41d9079671d09a62d8e2c1db6973.gifNote Ifyou use a virus protection program on your computer, override it orturn it off before running the Installation wizard. The Installationwizard might not run properly with virus protection turned on. Afterinstallation, be sure to restart your virus protection program.
  2. Insert the Visual FoxPro CD.
    The Visual FoxPro Setup start page appears automatically.
  3. Click Install Visual FoxPro to launch Visual FoxPro Setup.
  4. To determine if you need additional components, click Prerequisites to display any necessary components.
  5. Click Install Now! to install any new components. If Visual FoxPro Prerequisites needs to only update components, click Update Now!
  6. You might need to restart your computer. When finished, click Done.
    Visual FoxPro Setup reappears.
  7. To continue installation, click Visual FoxPro.
  8. After accepting the End User License Agreement and entering the Product Key and your name, click Continue.
    030c41d9079671d09a62d8e2c1db6973.gifNote Visual FoxPro cannot be installed on a mapped drive. You must install Visual FoxPro on a local drive. Do not attempt to use the Map Network Drive functionality in Setup.
  9. On the Options page, select the features you want to install and click Install Now! to continue.
  10. When finished, click Done to return to Visual FoxPro Setup. Click Exit to return to the Visual FoxPro Setup start page.
Ifyou uninstall Visual FoxPro while the previous version of Visual FoxProexists on your computer, certain shared registry keys used by theprevious version of Visual FoxPro are removed. You must reinstall thesecritical shared registry keys.
If you run Visual FoxPro fromthe Start menu, Visual FoxPro Setup automatically reinstalls thesekeys. If you start Visual FoxPro using other means, such as running theapplication executable directly, the setup program does not startautomatically. You should use Add/Remove Programs in the Control Paneland the following steps to reinstall the registry keys manually:
To manually reinstall Visual FoxPro 9.0 registry keys
  1. From the Start menu, click Control Panel.
  2. Click Add/Remove Programs.
  3. Click Change/Remove for Microsoft Visual FoxPro 9.0.
  4. Click Visual FoxPro and Repair/Reinstall.
Good Luck
Jun 26, 2010 | Microsoft Visual FoxPro Professional...
Foxpro 2.5 Application can't direct print in xp cause in my print Dot Matrix with Epson LQ-2180 using USB to Pararel Port...
share the printer then search for your own computer and you should be able to open it and see the shared printer like. \\server\printer
then use net use command...
net use lpt2: \\server\printer /Persistent:yes
then tell foxpro to print out lpt2 and it will act like dos
you can add net use command to autoexec.bat or windows startup if you will do this often
Nov 08, 2009 | Electronics - Others
How to print to zebra tlp 2844 using vb6 through usb port
You need to use a printer driver or use ZPL commands to print.
Jun 23, 2009 | Zebra TLP 2844-Z Thermal Label Printer
Not printing in foxpro 2.6 dos to hp laser jet 1020
You write "type the above line at command prompt". I dont't know Where exactly to write? Can you tell me!
Feb 05, 2009 | HP PSC 1610 All-In-One InkJet Printer
Printronix
i have problem in winxp for printer proline sereis 5 printronix line printer driver not match
in custom size
so need for printer driver winxp supported
Sep 18, 2008 | Printronix Line Matrix P5005B Printer
Can't print from a Visual Fox Pro application with raw printer processor
The Report sent to printer should be in a recognised fonts and formats. If It work on other applications like word excel then you need to solve this through ur programmer of Visual foxpro reports.
Best Regsrd
Rafique
May 10, 2007 | Samsung ML 2010 Laser Printer
Printing
Have you tried using a SATO label Gallery? I think it's more compatible with SATO printer
Apr 13, 2007 | SATO CL408e Thermal Printer
SATO eSeries CL408e Label Printer Logo
192 people viewed this question
Top SATO Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
M_Butkus
Howard
Howard
Are you a SATO Office Equipment and Supply Expert? Answer questions, earn points and help others
