Question about Zoom Suspension Seatpost - 27.2mm x 350mm x 0mm Setback Silver
350mm=how many inches? - Zoom Suspension Seatpost - 27.2mm x 350mm x 0mm Setback Silver
My Samsung PS50A410 plasma TV has developed two vertical lines down the right side, one at 60 mm and the other at 350mm. Both are approx. 20mm wide with an indistinct picture behind.
vertical lines as apposed to horizontal indicate bad lowerr connections in the ribbon cables inside the TV at the bottom sometimes they can be fixed but most times your panel is failed
Feb 12, 2018 | Samsung Televison & Video
`an engine develops30kw of power at 1000rpm the is trasmited to drive shaft through a cone clucth having face angle of 12.5degree and amean diametr of 350mm the cooficient of friction is0.2and the no
You may have this posted in the wrong product category. Please select another category appropriate to the problem and re-post the problem so the correct expert will see and respond to the question..
This is for car and truck problems related to factory installed systems not add on aftermarket systems.
This post can't be removed or moved, please re-post the question in the correct product category. Thanks
Oct 18, 2012 | Cars & Trucks
Want a narrow ceramic cook top / hob
Look at Baumatic 90cm Slimline 4 Hyperspeed Zone Ceramic Hob. Dimensions are 350mm x 880mm
Apr 26, 2010 | DeLonghi Cooktops
What space is required to install this unit
Only the normal space behind the wc pan. If you go to the Saniflo website they will give the exact dimensions.The unit is approx. 350mm x 300mm x 100mm wide
Feb 27, 2010 | Saniflo SaniPlus-Round SaniPlus Macerator...
Chainsaw 34cc 350mm bar polun, tha adjusting
Did the cover crack? The adjusting screw is just a common metric screw; the nut has a special tang that engages one of the 2 large holes at the drive end of the bar. When reinstalling the bar and chain, the adjustment screw must be backed off a few turns so the the tang will readily drop into it's hole in the bar. Install the cover (new if old one cracked) and turn the nut(s) down finger tight. Turn the adjuster CW to tighten the chain so that the chain doesn't droop from the bar, but turns freely by hand. Tighten the cover nut(s) and recheck the chain again.
Sep 13, 2009 | Garden
Blade wanders away from guides
Tighten the blade, and readjust the guides to the blade.
Sep 10, 2009 | Saws
Mount for rollei pqs lense to nikon dslr body
The rollei 600x mount lenses communicate to the camera via the gold plated contacts. In addition, the 350mm PQS is a medium format lens. There is currently no such adapter.
Apr 06, 2009 | Rollei 350mm f/5.6 Zeiss PQS Lens
Zoom Suspension Seatpost - 27.2mm x 350mm x 0mm Setback Silver Logo
Top Zoom Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Zoom Cycling Expert? Answer questions, earn points and help others
