Question about Ford Vehicle Parts & Accessories
91 Ford Festiva steering wheel vibrating at speeds of 50+
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 107 Answers
23 years old!!! probably needs struts, alignment wheels balanced
Posted on Oct 09, 2014
My steering wheel is shacking at 35 - 50.
tires need balanced or wheel rims bent
Mar 10, 2015 | 2006 Toyota Sienna
Location of fuel pump relay on 91 ford festiva
they used to be under the steering wheel red in colour the problem is a dry solder joint in side we use to open them up and resolder them it cuts the fuel of when the engine stops to stop the fuel pumping
Oct 11, 2012 | 1991 Ford Festiva
Front end vibration
This is usually either wheel balance if you just feel the vibration in the steering wheel, or shock absorbers are worn if you can actually feel the front of the vehicle bouncing.
Aug 23, 2012 | Ford Cars & Trucks
Vibration in Cab of Truck
sounds like a bent wheel rim
May 14, 2012 | Ford F-150 Cars & Trucks
Does a Ford Festiva 1989 have a Power Steering Pump
It does if it has power steering. They came both ways. Power steering is pretty easy to tell if you have it or not. If you don't have it, you will need two hands for sure to park the car in a tight spot, the steering wheel is quite hard to turn compared to other cars with power steering.
Sep 20, 2010 | 1989 Ford Festiva
Headlights stay on in 91 festiva ! with switch turned off
The headlight switch is most likely defective. If you can get to the back of the switch you can do a continuity test to see if the switch is opening and closing.
Jul 09, 2009 | 1991 Ford Festiva
Vibration in a 91 Jeep Cherokee Laredo
is there any play in the transfer case output shaft
Jan 06, 2009 | 1991 Jeep Cherokee Limited
91 festiva wont start
First make sure that the battery is charged up all of the way and that a positive 12V current is reaching the positive terminal of the starter motor. You can test it with an inexpensive 12V test light available from any auto parts store for about $10. You need that for diagnosing any electrical problems if you have checked the fuses and they are all good. Its also possible that the fusable link got shorted out and that will stop the car from turning over. The fusable links are 3 wires sticking up from a small box on the drivers side shock mount in the engine compartment. Check that they are not burned. If all of that is good, then use your test light to see if 12V current is reaching the ignition switch under the plastic cover behind the steering wheel and on the opposite side of the key.
Nov 11, 2008 | 1993 Ford Festiva
Vehicle Parts & Accessories Logo
23 people viewed this question
Top Ford Vehicle Parts & Accessories Experts
xxxxxx xxx
Thomas Perkins
Thomas Perkins
Colin Stickland
Colin Stickland
Are you a Ford Vehicle Part and Accessory Expert? Answer questions, earn points and help others
