Question about Canon PIXMA MX522 Wireless Office All-in-One Printer
Mx522 losing wireless connection
My Canon MX522 connects to my wireless network fine (D-Link router) when I push the button on router. I can print from my PC running Windows 7 fine. After a few hours or a day, when I go to print again, my computer can't connect to printer any more. It's like the printer "goes to sleep". Is this normal? It doesn't seem right to me to have to turn the printer off and on and reconnect to print each time. Any tips? PC is connected with Ethernet cable to router, printer is on wireless.
3 Suggested Answers
brandonboyce
  • 84 Answers
SOURCE: wireless and wired connection fails with Toshiba laptop
Do you have a firewall turned on that might be preventing your computer from communicating with the printer properly?
Posted on Jun 27, 2007
  • 84 Answers
SOURCE: Wireless printing does not work
For an effective wireless connection, the printer should be connected to one of the LAN ports of a configured wireless router. This way, every pc(mostly laptops with wireless capability) can print to the printer. You will need a wireless adapter for desktop pcs to access any resource made available wirelessly ok. Good luck
Posted on Jun 02, 2009
How to replace printhead?
Hello, my name is Steve
The print head is part of the ink cartridge, it is not a separate component,
Steve
Aug 24, 2015 | Canon Pixma MX522
How do I get my name into the printer so I can scan to PC
Why does it need your name . I have owned several and none required a name or password .I would contact canon through their website and ask tech support , what gives
Aug 20, 2015 | Canon MX522 Network-Ready Wireless...
Will not answer or send fax
have you connect the extinction phone on the printer and change the fax setting to fax only model
Mar 07, 2015 | Canon PIXMA MX522 Wireless Office...
How do you open the back of this printer
Greetings Melvin,
If it is jammed paper, you can open the Transport unit per this graphic from MX520 series manual. 25325722-1eo3jqjer0ey1ys4atiltvns-3-0.png
Here's the link to the Canon manuals for your Pixma MX522: http://www.usa.canon.com/cusa/consumer/products/printers_multifunction/office_all_in_one_inkjet_printers/pixma_mx522#BrochuresAndManuals
Hope that helps.
Dec 17, 2014 | Canon Pixma MX522
Not printing straight lines
try replace new cartridge
Feb 08, 2014 | Canon Pixma MX522
Have a dlink print server dpr1040 and dlink wireless router how do i print wireless
DPR-1040 information - http://www.dlink.com.au/products/?pid=777
All of this is from the manual located at link above under the resources tab.
Wireless Setup
WPS (Push Button Configuration)
WPS simplifies the process of connecting to a wireless network to a touch of a button. To use WPS you must have a WPS compatible wireless router,if you do not then you will need to manually configure the wireless connection in the web configurator (see Web Configurator below).
1. After following the hardware installation steps in section 3, ensure your wireless network is operating normally. When ready, press the WPS button located on the side of the DPR-1040. The blue LED should start flashing repeatedly.
2. Within 120 seconds, press the WPS button located on the wireless router you will be connecting to. This button may also be located in the router's web configuration pages labeled "Push Button Configuration (PBC)".
3. If successful, a wireless connection will be established between the two devices.
This connection is secure and uses automatically generated encryption keys; you do not need to remember them.
Note: If you experience problems connecting to a device, please try again. If you still experience problems, the device you're connecting to may be incompatible with the DPR-1040. Also, make sure you are connecting to a router or access point (AP).
Web Configurator
1. After following the hardware installation steps in section 3, ensure your wireless network is operating normally. When ready, type the IP address of the DPR-1040 into your browser, the default IP address is 192.168.0.10. If this does not work, use the PS-Link utility to find out the IP address.
2. Upon accessing the web configurator, click Setup > Wireless Setup.
3. On the next screen, enter the wireless network settings as provided by your network administrator.
4. Click Apply Settings, the DPR-1040 will restart and the wireless setup is complete.
Note: If your wireless connection does not work, check that you have entered the correct network settings into the Wireless Setup screen.
May 18, 2012 | D-Link DIR-412 Mobile Broadband Wireless...
I have my Canon MX420 printer hooked up, my computer recognizes it's existence, and the printer prints fine by itself. However, every time I try to print from my computer via wi-fi, my computer says...
If your printer has the network cable plugged into it then your halfway there. Make sure that as well as having a hard line network cable plugged into your router, you need to connect the printer to the wifi signal as well. On your printer, push your settings button, scroll to your wireless lan setup, and connect to your router and if password protected, enter in the password and you should then be connected to you router, now try printing using your laptop or device through your wireless connection, and it should print. Please post back if you need further instructions or help!
Aug 24, 2011 | Canon Pixma MX420 All-In-One Printer
Jun 02, 2009 | Canon PIXMA MX850 Multifunction Printer
Network router printing issue
sure..you can put all the computers on the same workgroup, and form a network
we got fresh wireless drivers here too
Mar 17, 2008 | D-Link Wireless
Canon PIXMA MX522 Wireless Office All-in-One Printer Logo
29 people viewed this question
old marine
old marine
