Question about Dexter 30lb. Stack Dryer Belt
F5 code is on the display
Will not start and I don't know how to reset the timer
Kenmore model 790.96113403 F5 error code
it means that your oven is showing a restart code
Jun 13, 2012 | Kenmore 99123 Electric Kitchen Range
WOODS 59018 TIMER WIREING CORRECT INSTALLED WITH POWER OFF NETURAL GROUND UP TO CODE LOAD /LINE PROPER.NEW OUT OF BOX WON'T RESET. STEP 1 LAMPS LOAD SIDE GOOD. RETIRED CONSTRUCTION ELECTRICIAN
I don't have answer for defective timer. Buy another timer if everything below checks out:
59018 7-day timer has limited 1 year warranty, and appears to be made by Tork
Timer is for 120Volt single-pole only.
Rated for 1000 watt tungsten, 8A ballast, 1/4 HP
Push reset button with toothpick > not necessary to press-and-hold other button to accomplish reset.
After reset, 12:00 am Monday should display.
Programs are deleted. Reprogram timer.
To check, change and delete specific programming, press PROG key until selected program displays, and then set new programming >>> or press-and-hold MODE button and press PROG button again to delete selected program.
Timer has non-replaceable 30-day carryover battery and does not lose programming after power outage, and will retain programs until battery is depleted.
Review wiring:
Hot to timer black.
Neutral to timer white.
Load to timer red.
Ground to timer green.
Lights will blink if timer red and timer white are connected to load together.
Timer will not function if timer black and red wires are reversed. Display will not show.
http://waterheatertimer.org/Woods-timers-and-manuals.html#59028
Aug 07, 2011 | Woods InWall 7 Day Digital Programmable...
How do we clear out the timer settings
Timer is not identified.
Open following link to identify timer and download manual.
http://waterheatertimer.org/GE-timers-and-manuals.html#zilla
1) If you have zilla digital power strip, there is no reset button.
It appears you can reset timer by removing small battery located on back of timer.
Battery serves as a back-up for timer settings, and display will not show without battery.
Most battery-operated timers that do not have reset button are reset by removing battery.
Some battery operated timers retain programming forever even if battery is removed for months, and then programming is still there when new battery is installed. However this type of timer has a reset button, but zilla does not.
2) A second way to clear programming is to press PRG button to review each program, and set each program to another time. I don't know if this will work since you can't 'zero' out the settings.
Jul 30, 2011 | Coralife Power Center DayNight Timer or...
I pushed the auto clean button ,push the start button .but the door didn't lock instead after a minute ,I got a error code E1 F5. I had to unplug my range for 5minutes then replug it, push cancel to reset...
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.^&^%T
Sep 29, 2010 | Whirlpool RF368LXKS Electric Kitchen Range
Kenmore 95024 Electric Range The self clean cycle Door stuck shu
Jun 27, 2010 | Kenmore 95022 / 95024 / 95029 Electric...
Error code
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.T$%^%ETG
Dec 15, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
I need the user guide for the time Tracker countdown timer
SET AUTO TIMER 1. Press and hold START and ENTER buttons at the same time for 3 seconds. 2. Press buttons until SET AUTO appears on the display. 3. Press ENTER. 4. Total Time: (Enter the total amount of time. It will automatically split between green, yellow and red lights). Use buttons to scroll through numbers and ENTER to accept. 5. Sound?: Do you want a sound effect at the start of the green light? 6. Yes/No: Use buttons to move cursor and ENTER to accept. 7. If yes, use buttons to scroll through sounds and ENTER to accept. 8. Repeat steps 7 and 8 for yellow and red sections. 9. Press MENU.
Feb 03, 2009 | Learning Resources Time Tracker Visual...
Whirlpool Gold Electric Oven F5 E1 code on bar code
For some reason I get the same error code every time we have a power outage. If you push and hold the "lower off" button for about ten or 15 seconds it will unlock and reset. Hope this helps.
Jan 26, 2009 | Whirlpool GBD307PDS Electric Double Oven
Samsung rb1955sh
if you hold the two top buttons on the right and left side of the display for 4 to 5 seconds it will reset the control board and it should restart, if not check the door switch for a bad connection. I had the same problem and i cleaned the contacts on that switch and reset the controller and no problems since. (2 months and counting!)
Dec 20, 2008 | Samsung RB1955VQ Bottom Freezer...
Oven display problem
F5-E1 is a fault code denoting a failed door lock/latch mechanism. Before having it replaced, go outside to you main breaker box and turn the power off to it for a couple of minutes... try to reset the controller. If the fault code appears again, the door lock/latch mechanism needs to be replaced.
Jul 26, 2007 | Whirlpool RBD305PD Electric Double Oven
Dexter 30lb. Stack Dryer Belt Logo
55 people viewed this question
Top Dexter Dryers Experts
Are you a Dexter Dryer Expert? Answer questions, earn points and help others
