Question about Garmin GPS
Replace rubber seal on Garmin edge 305
The old rubber button seal is worn out and not moisture proof. Where can I buy a new seal?
  • 8 Answers
SOURCE: Garmin Edge 305 - Uncommanded Power Down
I moved the battery wires to the main board, bypassing the spring contacts. No doubt my warranty is voided but at least the thing works now.
Posted on May 28, 2008
SOURCE: garmin edge 305 heart rate monitor
I had the same problem, but it was unresolved using the above info. I finally went into the menu (Settings / System / Accessories) and selected Restart Scan. All is well now =)
Posted on Jul 03, 2010
SOURCE: Garmin Edge 305 completely dead
I found that switching the device on and/or off while connected to the computer can leave the screen blank, and won't give any sign of life when the ON/OFF button is pressed. In reality the device is on and the batteries will drain. Try a RESET in that case by pressing ON/OFF and MODE buttons, and briefly pressing the LAP button.
Posted on Aug 10, 2010
  • 81 Answers
SOURCE: My garmin 305 edge won't turn on. I had it for
Try soft reset first then hard reset if not solving.
Soft reset : hold lap/reset and mode key for some seconds
hard reset : hold on/off and mode, then pulse on lap/reset.
after soft reset, hold start button for 10 secs before device starts again.
Posted on Sep 04, 2010
  • 81 Answers
SOURCE: I am charging the Garmin Edge 305 for 24 hrs or
Discharge completely device then charge again for 8 hours.
If not working, then attempt Soft reset :
Hold mode and lap/reset for 10 seconds then release.
Start the device then by long press on start. DEvice should start and charge then
Posted on Sep 26, 2010
Used my garmin edge 305 today on the ride, it worked fine, powered off after the ride. Got home turned on to review my stats and then powered off and went to upload and wouldn't upload, so tried to turn it...
Edge 205 or 305 often crash, then impossible to power on again.
Here is the way to reset the Garmin edge :
Soft reset : hold mode and lap/reset buttons for 10 seconds
Hard reset : device should be powered down, hold start and mode buttons for 3 seconds then pulse press the lap/reset button.
After soft reset, you need to hold start button for up to 10 secs before it starts.
After hard reset, you will loose all your data, including profiles.
Jan 30, 2011 | Garmin Edge 305 GPS Receiver
Sorry but honestly...Since GARMIN launch the EDGE this problem is still not resolved by them. The EDGE 305 had the same problems. Just search the www and you will see. My 705 died on me after just 2...
Edge 205 or 305 or 705 or 605 often crash, then impossible to power on again.
Nov 01, 2010 | Garmin Edge 705 Handheld GPS Receiver
Can i order a new LCD for a garmin edge 305 and mount it myself?
Difficult to open it. If you do, warranty is over. There is a web site explaining how to open device :
http://blog.mtbguru.com/2008/11/06/surgery-on-the-garmin-edge-305/
Aug 10, 2010 | Garmin Edge 305 GPS Receiver
The mode button on my garmin 305 edge has stop working and there is a slight rattle - not sure if two issues are connected? Is it possible to open up and inspect button or could it be software related? Any...
yes you can open the unit by prising it apart between the rubber grey area and the black bottom half as it is glued together, take it easy and it will come apart, downside is that you have to glue it back together. as for the button you can access them as soon as you open the unit but take time to record where all goes...
Jan 26, 2010 | Garmin Edge 305 GPS Receiver
Edge 305
Try Holding the Lap + Mode, for a few seconds, release and then hit Power button. It worked for me.
Cheers
Sep 29, 2008 | Garmin Edge 305 GPS Receiver
Opening forerunner 305
Hi
I have a problem with my 305 whereby the mode button stopped working so semi pulled mine apart.
If you look at the 305 from the side you can see where the rubber bit covers the buttons. The bottom of the rubber bit is attached to the rear of the forerunner - don't try to detach it - I munted mine a bit detaching it. At the top of the rubber, nearest the face you'll see a small gap. Follow the gap anti clockwise from the power button down to bottom left corner of the face near where the wrist strap pin is. Here you'll see the gap is plastic on plastic on plastic. I believe a thumbnail or similar in here and worked around carefully will let you pry the face off. I stuck my thumbnail in there and got the face to lift 1-2mm before I backed off. Note I didn't go any further than that.
For my problem by the time I had munted the rubber cover and was able to operate the mode button with a paperclip I new it was dead so didn't bother going any further as I could still use the 305 in reduced mode without mode changing.
Aug 29, 2008 | Garmin Forerunner 305 GPS Receiver
Garmin 305 edge
Re-register it, Re-update it at Garmin
Should be good
Hope this helps
Regards.
Aug 14, 2008 | Garmin Edge 305 GPS Receiver
Edge 305
I'm taking a wild guess here but it sounds like your reset button seems stuck. Pressing mode+reset restarts the unit ... you can lift the buttons off. See if there is moisture underneath? Or maybe the button just needs reseating?
Jul 13, 2008 | Garmin Edge 305 GPS Receiver
Feb 17, 2008 | Garmin Edge 305 GPS Receiver
GPS Logo
29 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
