Question about Ricoh Aficio SP C410DN Laser Printer
Spc410 seating toner cartridge issues - Ricoh Aficio SP C410DN Laser Printer
  • Ricoh Expert
  • 393 Answers
The one of the contact spring is "down" on the toner that is not seen
Posted on Feb 07, 2014
Error 10.10.00
Hi leslie,
First, is to reseat the toner cartridge and turn the machine off and back on. Second, obviously is to check and replace the toner cartridge. Like every other toner cartridge error majority of the time it's related to a third-party or rebuilt toner cartridge so replace the toner cartridge. Lots of times these errors happen right after people replace their toner cartridge. For some reason they believe because it's a new toner cartridge that can't possibly be the issue. For me that's a dead give away they have a bad cartridge. Before you call a technician in for service make sure you replace the toner cartridge with a new one first. Preferably with a OEM HP toner cartridge. Third, is to check the memory tag assembly, RM1-6284-000CN. Make sure it's properly seated in the machine and the contacts that mesh with the chip on the toner aren't bent. Finally, make sure that the memory tag connector is fully seated at connector J1703 on the ECU. The connector is behind the main cooling fan so it might need removed to check the connector.
In case Still Having Problem Then Follow Us For Hp Printer Problems For On :
HP Printer Support
Feb 06, 2014 | HP LaserJet M5035 MFP Printer
Richoh spc410 printer streaking
Did you check that your toner is not damaged?
Jan 24, 2008 | Office Equipment & Supplies
Out of toner
Make sure that the toner ink cartridge is a genuine Lexmark toner cartridge. Try removing the toner cartridge and then shake the toner sideways. Re-seat the toner cartridges and check if the error persists. If it does, please contact our Technical Support Hotline.
Dec 03, 2012 | Lexmark T520/522 BLACK PREBATE TONER
Just purchased a used HP LaserJet 4 Plus -- when turned on and installed it is showing 14 no EP CART -- we do not use cartridges so need to reset to default settings. Tried Power On and holding online but...
Ensure that the Toner Cartridge is installed correctly (fully
seated into the printer). Try a new Toner Cartridge. If the
problem continues, try this
14 NO EP CART Message
The printer detects the presence of the Toner Cartridge and the
level of toner present in the cartridge through the condition of the
ANTIN signal. The ANTIN signal becomes part of the serial data
stream used to communicate with the DC Controller (see Figure
7-5 for cartridge components). Troubleshoot the 14 NO EP CART
(or INSTALL TONER CARTRIDGE) message as follows:
1 Reseat the Toner Cartridge. Try a new or known good Toner
Cartridge.
2 Check the High Voltage Contacts for damage. If the contacts
are dirty or damaged, clean the contacts after the repair.
3 Replace the High Voltage Power Supply.
4 Check and reseat the HVPS cable.
5 Replace the DC Controller.
Jul 05, 2011 | Office Equipment & Supplies
10.00.00 supply memory error
Memory Supply Error 10.00.00 The printer is unable to read or write to the print
cartridge e-label, or the e-label is not on the cartridge.
Basically what is happening is the printer cannot read the small chip on the toner cartridge. The chip is located on the toner cartridge as it is inserted into the printer. 1 - Make sure the toner is firmly seated into the printer. 2 - Power cycle the printer with the toner out of the printer. Install the toner back into the printer. 3 - Install another toner cartridge. 3 - Verify that the e-label connector is firmly seated in connector
Contact a local HP Authorized Service Center for further assistance.
Oct 14, 2010 | HP LaserJet 5200 Printer
Installed new ink cartridges and now the printer tics an only prints 2 pages at a time
Sometimes cartridges can be defective and cause a clicking noise especially compatible or after-market toners.I would first try re-seating all the cartridges. If you still have the old cartridges re-install and test them one at a time to isolate where the noise is coming from. It is vert unlikely but possible that the toner cartridge could be causing the printer to only print 2 pages at a time. That sounds more like a resource issue than a printer related issue.
Sep 10, 2010 | HP LaserJet 4700 Printer
10.00.00 supply memory error Unable to read cartridge data
Basically what is happening is the printer cannot read the small chip on the toner cartridge. The chip is located on toner cartridge as it is inserted into the printer. 1 - Make sure the toner is firmly seated into the printer. 2 - Power cycle the printer with the toner out of the printer. Install the toner back into the printer. 3 - Install another toner cartridge. 3 - Verify that the e-label connector is firmly seated in connector
Sep 01, 2010 | HP LaserJet 2420 Printer
SUPLY MEMORY ERROR
Basically what is happening is the printer cannot read the small chip on the toner cartridge. The chip is located on the front right of the toner cartridge as it is inserted into the printer. 1 - Make sure the toner is firmly seated into the printer. 2 - Power cycle the printer with the toner out of the printer. Install the toner back into the printer. 3 - Install another toner cartridge. 3 - Verify that the e-label connector is firmly seated in connector.
10.00.00 Troubles shooting Link GOHERE
Aug 17, 2010 | HP Hewlett Packard LaserJet P3005 Printer
Hi my machine has a 10.00.00 supply memory erro message can you tell me what is wrong with it please
Aug 03, 2010 | HP LaserJet 5550 Printer
Hi there i just replace the toner for my m5200 dell printer and the pages are coming really dark as if the pages are burnt.
Are you using Dell branded cartridges, or compatibles? I've seen issues with compatibles not properly seating when you install the toner cartridge, causing the cleaning blade to not properly wipe the drum (ghosting) or allowing too much toner on the drum (black pages, front and back). Re seating the cartridge should resolve.
Apr 16, 2010 | Dell M5200n Laser Printer
Ricoh Aficio SP C410DN Laser Printer Logo
41 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
