Question about Freecom 30570 320GB ToughDrive USB 2.0 2.5 Inch External Hard Drive
Freecom toughdrive 320g installer - Freecom 30570 320GB ToughDrive USB 2.0 2.5 Inch External Hard Drive
2 Suggested Answers
bronk50
  • 27725 Answers
SOURCE: what should i do when my freecom toughdrive does not recognize of any computer
click start control panel administration tools computer management device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
if this fails to fix the problem
you might have to install a usb 2 or 3 card they are cheap and easy to install you can buy these on Ebay very cheap
hope this helps
Posted on Feb 20, 2012
When turned on the harddrive does not make its normal startup noise and worse; the computer does not see the harddrive anymore! The blue light on the front pannel is lit though. Help...
Hi
Check all cable connections in firmly & correct way round, from motherboard & hard drive. Check in bios, make sure hard drive setting is set to Auto. Place you hand on the hard drive to feel vibration. Hard drive could bd faulty. Western Digital are renound for it.
Jun 26, 2014 | Freecom ToughDrive 400 GB USB 2.0 Hard...
Export saved emails from toughdrive, import to my laptop
A little more information. What email program are you using Outlook express? Outlook?
If you are using outlook express open it. go to File / Import / Messages.
select the type of program the emails are in when you saved them to the external harddrive.
click next select import mail from OE6 or whichever you had from above. and click ok.  then click browse. and find the drive the email was saved on. then click the folder you have the emails saved in. and click ok. ( it may be easier to save the email folder to your desktop of your computer and just browse to your desktop).
click next select your folder you want the emails to go to and finish the emails will be imported
Oct 26, 2007 | Freecom (24358) 160 GB Network Hard Drive
Computer doesn't recognise hardrive
It may seem obvious, but did you try a different USB port? Did you try a different computer? and did you try a different cable/cables?
Oct 03, 2012 | Freecom ToughDrive external hard drive -...
What should i do when my freecom toughdrive does not recognize of any computer
hope this helps
Feb 19, 2012 | Freecom Computers & Internet
How do I backup files to my Freecom external hard drive XS 3.5 ?? Ive installed it but cannot workout how to use it !! there are no manuals !!
you can open Computer on your screen and then there is C: drive and Freecom labeled to it. Open first the C drive, click Ctrl + A to highlight everything. Then click Ctrl + C. Then go back to Computer and click Freecom. Then click Ctrl + V. All the files will be transferred to Freecom. Then you may proceed for your next step. That is how you back up files.
Aug 10, 2010 | Computers & Internet
HD suddenly asks for Password, never set one!
The password-protection program is designed to protect your files, so that if in case your HD is stolen, any important files will remain intact in the HD.
You have to refer to the use manual of the HD and look for the default password. Since you mentioned that you never set any passwords, it means that the HD is still using the default or manufacturer's password or code. Check the manual and you should find it there.
Or you may want to contact the tech support of the manufacturer and see if they could give you the default password.
Thank you and good luck!
Jul 12, 2010 | Computers & Internet
Window 7 and Freecom Touchdrive
May be it does not have a compatible driver for the drive. Launch the Add/Hardware wizard and use it to search for a driver on the internet. If a driver is available windows will download and install it.These driver issues usually happen with new operating systems. Even Vista had these problems when it first came out.
Dec 05, 2009 | Microsoft Computers & Internet
No response at all from laptop regarding my toughdrive 160GB
Your files are safe on the HDD, the trick to retrieve.
You should have backup at the end of your sessions
If you have the setup disc, reinsert and run!
Nov 13, 2009 | Freecom Portable II External DVD Drive
Freecom 400gb Drive
Have you tried to connect those drive individually and checked if they get detected when stand-alone? If they get detected stand-alone, install the Freedom software happen. Cheers
May 23, 2007 | Freecom (24358) 160 GB Network Hard Drive
Open Questions:
Freecom 30570 320GB ToughDrive USB 2.0 2.5 Inch External Hard Drive Logo
14 people viewed this question
Top Freecom Computers & Internet Experts
John Anderson
John Anderson
bobwin
Are you a Freecom Computer and Internet Expert? Answer questions, earn points and help others
