Question about Car Audio & Video
Connection diagram of sony xmzr6022
How to connect the battery to positive12 and gnd and rem
5 Suggested Answers
flexion1
  • 737 Answers
SOURCE: after connecting my Sony XM-1252GTR Car Audio Amplifier it won't turn on
Hi. You should be able to turn the amp on by touching the remote wire to the B+ main power terminal. this will tell you if it is a problem with the remote from your head unit.
Mark
Posted on Oct 25, 2008
blueextc3221
  • 15935 Answers
SOURCE: blown amp, on circuit board, connecting fuse and power connect.
These amplifiers dont employ reverse polarity protection that most higher priced ones do.
The amplifier(s) are definately in need of repair - probably power supply - IF boss sells parts.
Chances are, however, the repair will meet or exceed the cost of a new (appropriately rated) entry level amplifier.
Just about anything can be repaired.... question is, are you willing to pay?
Posted on Jan 14, 2009
  • 74 Answers
SOURCE: 2 boss C450 chaos 2CH
open the amp and see if anything was blown inside, if not check replace the fuses, and re connect.
Posted on Jan 16, 2009
anymhz
  • 500 Answers
SOURCE: Is REM signal input on Caliber CA47 Series 3
it is a switched normally 12v to turn on equip
Posted on Dec 06, 2010
Testimonial: "Quick, helpful and accurate response."
Wiring Diagram For Usb flashdrive
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually ((red white green black)) make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts
or
PRODUCT NAME
FRONTX USB Type A Internal
PRODUCT CODE
CPX101-2
BAY USAGE
Half of large bay
CONNECTORS
USB type A female
1x5 header connector female
CABLE
USB cable (UL 2725)
Length - 2.5 feet (762 mm)
WIRE ASSIGNMENTS
Red: + 5V / Voltage + / VCC
White: D - / Data - / USB -
Green: D + / Data + / USB +
Black: GND / Voltage - / Ground
Black: S-GND / Over Current / Shielding
The S-GND wire is fatter and can be easily recognized. The connection of S-GND wire to the header pin is optional.
HEADER CONNECTION GUIDES
Diagram 1: On most motherboards, the USB header/pin-out consists of 9 pins arranged in 2 rows, which allows for 2 USB connections (i.e. USB1 and USB2). Normally, the pins for USB1 and USB2 are in seperate rows.
Diagram 2: Simply plug the connector onto the 5-pins row, and make sure that the pin assignments and wire assignments are matched correctly.
Diagram 3: Alternatively, you can plug the connector onto the 4-pins row, and leave the S-GND wire unconnected.
You might have to rearrange the wires to match with the pin assignments, or change the header connector if necessary, depending on the layout of the USB header.
On some motherboards, there is a NC pin in the USB header. You can connect the S-GND wire onto this pin. NC simply means "no connection" and NC pin is an "empty" pin.
2X5 PINS HEADER
Refer to the diagram below, for 2x5 pins header, simply plug the connector onto one row of the pins, and always make sure that pin assignments and wire assignments are matched correctly. You might have to rearrange the wires if necessary.
2X4 PINS HEADER
Refer to the diagram below, for 2x4 pins header, simply plug the connector onto one row of the pins. Please note that there is no S-GND pin in this header. You can leave the S-GND wire unconnected. You might have to rearrange the wires if necessary, in such that the wire assignments and pins assignments are matched correctly.
ACTIVE PINS NOT IN THE SAME ROW
On some motherboards, the 4 active pins are not located in the same row, as shown in the example below:
To connect to this type of USB header, you need to change the header connector to 2x5. Simply rearrange the wires within the 2x5 connector to match with the pin assignments. If the green wire is connected to the USB2+ pin, the white wire must be connected to the USB2- pin. The red wire can be connected to any +5V pin, and the black (GND) wire to any GND pin. If there is no S-GND pin provided, you can leave the S-GND wire unconnected.
hope it helps
Sep 23, 2012 | Lexar Media Echo ZX 32 GB Flash Drive
Kenwood amp worked fine yesterday when I went to start my jeep I noticed my sub was not working when I looked at the amp the blue light was not on, I looked at all the fuses they looked fine cant figure...
If the light is out, it's not getting power or is in protect mode to prevent further damage. If you have a voltmeter, measure the voltage between GND and 12V (BAT terminal) and also between GND and REM terminal (with the car and radio on).
If neither has voltage, your ground wire has come loose. If the bat terminal has no voltage, your fuse under the hood is blown (they can blow and still look fine sometimes) or your power wire is loose or broken. If the REM terminal has no power, your wire is broke or has come loose from the back of the stereo.
Jul 03, 2011 | Kenwood KAC8105D Car Amp
Won't turn on & don't know how to hook up to a 1963 pickup.
Don't get confused, it's very simple. +12v----direct supply from battery.
REM---also 12+ supplied from igntion switch. (when the key is turned on, this supply should have 12+ to on the amplifier.
GND--12- minus (negative)
Try it you will be able to set this up. REM can also be used with a single switch which can break the 12+ when amplifer is not in use, or else this will take all ur power battery. You can place a fuse on 12+. Thanks
May 15, 2010 | Crossfire VR302 Car Audio Amplifier
The red protect light is on what do I do to fix this. thank you
check that the amp is properly earthed and that the 12v, rem and gnd connections on the amp arnt touching
May 05, 2010 | Blitz 2 CHANNEL 2400 WATT CAR AMP Car...
How to hook up a kenwood amp.kac-5204
All amps are basicly the same. It should be plain as day where the speakers connect to.
The 12V screw connects to the main power from battery, be sure to fuse that wire and use a proper size wire, thicker is better,I suggest at least 8gauge with 40amp fuse. The GND is ground and should connect to car metal, file paint for soild connection. The REM is remote and connects to the remote of headunit or if you have a stock deck to the acc of car found in wire harness of headunit. Plug in the RCA's to head unit, or get a converter to plug into speaker wires from car if you have a stock headunit.
Mar 22, 2010 | Kenwood KAC-5204 350 Watt Max Power Stereo...
I need installation instructions for a MTX thunder 280
BATT = 12v positve constant
GND = 12v negative or ground
REM. = 12v positive switched or remote wire.
The remote wire is most commonly found on aftermarket CD players. It's typically in the main wire harness. The most common color of this wire is blue with a white stripe.
Jan 20, 2009 | MTX Thunder 2-Channel Amplifier 282 Car...
Blown amp, on circuit board, connecting fuse and power connect.
Jan 14, 2009 | Kenwood KAC-X501F Car Audio Amplifier
Sub making noise without input
Hi there guys, i dont have this problem ,but i do have the EN-AT1100 encounter 10" and cant get the thing to work at all. The six pin plug for the power (12V+), earth (GND) and accesories (REM) are all muddled up as i never bough it with the original leads. Can any of you help me out with the wiring on how to connect it? is there two wires for (12V+), two wires for earth (GND) and just one wire for accessories (REM)?
Hope you can help thanks.
Sep 13, 2008 | Fusion FEW12PK Car Subwoofer
Pioneer deh 236 install guide
i got one of these off my sister, but i didnt have a plug for the back. cutting up an old atx psu plug does the job, but then i had to find which wires did what, so i took it all apart and looked at the bottom of the circuit board, the plug has 12pins, 4 on each side are for speakers and the center ones are Acc, Bup (back up? constant power), Gnd, B. Rem (amp/auto antena remote)
i connected the gnd to negative of a power supply, and on connecting the bup to positive,, it seems to just short the powersuply.
i dont see what went wrong.
Aug 11, 2008 | Car Audio & Video
Car Audio & Video Logo
27 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
