Question about Mercedes-Benz Vehicle Parts & Accessories
Gas cap will not tighter and close after putting gas in the car of CLK 320
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 107 Answers
Broken buy new one. Rockauto
Posted on Oct 09, 2014
SOURCE:
My merceds clk 320 1999 wont pick up speed
give it a full tune up plugs wires and distributor cap
Dec 12, 2012 | 1999 Mercedes-Benz CLK
Jundi_Ahmed1 i'm having the same problem as well. I have a 2004 clk as well. Have you found a answer to this. If you have email me. Dennisjmoore@aol.com Thanks i have a 2004 clk 320 after driving...
Sound like the ISC actuator it part of the throttle body, and its a reversible motor, it maintains idle speed stability its a motor actuator,and is part of the throttle body but just dont condemd it sevice the throttle body this acuator motor sometime has a hard time moving to adjust RPM.Then there is the MAF(mass airflow sensor) even though this measures good or bad it does not set a code or Check engine light,
Here the most probable cause MAF they have problems on MBZ CLK 320 and only a fuel trim reading can detect problems with this sensor, dont be dependent on ck eng light it wont show, then there is the MAP manifold air pressure after coming to a stop sign the EGR may still be open and not close properly causing the stumble and this wont give a code. So here is the most probable cause the MAF mass air flow going out of range causing lean fuel trim or the EGR pintle not closing properly stumbing the vehicle , so I leave you with MAF or EGR either one or the other or both or just replace both
May 08, 2011 | 2004 Mercedes-Benz CLK-Class
Mercedes Benz CLK 320 1998 Radio Code
try asking here
www.ukbookshelf.co.uk
May 30, 2010 | 1998 Mercedes-Benz CLK
What is the proper wiring diagram for the car stereo system in a 1999 Mercedes Benz Clk 320
i put a new stereo in was working fine ater about 20 min speakers stoped working but the sub-woofer is still working
Jan 03, 2010 | 1999 Mercedes-Benz CLK
My check engine light came on and when i pushed my onstar button it said something about my gas cap. do you know what it may be? i did just put a locking one on my car
Your fuel system is a sealed system and part of the emission system also.If the gas cap is not tight or the seal has gone bad on the cap it will set a light.
Nov 10, 2009 | 2006 Saturn ION
Hi, I have a Mercedes CLK 320 and the radio doesn't work.
I purchased a MB CLK 320 and set the radio frequency and successfully put the freq in memory, however, the radio blinks tthe freq. Is this normal or do I have to enter another key to stop the radio from blinking?
Ed
Massachusetts
Sep 17, 2009 | 1999 Mercedes-Benz CLK
Where is the trnsmission cap for clk 320 model
Mercedes have purposely not put a transmission dipstick in their cars...to STOP any unauthorised persons from tampering with transmission fluid levels.
Electronic transmissions are extremely temperamental - if incorrect type, level is too low (or too high), this will accelerate premature wear and tear, not to mention erratic shifting behaviour.
For this reason, only Mercedes service agents have the required workshop tool (ie dipstick) which they insert into a tube in the transmission, to check levels.
If you happen to obtain the correct tool for your own use....please ensure you use only Mercedes specified fluids....and NEVER overfill the transmission case.
Cheers,
Aug 16, 2009 | 1999 Mercedes-Benz CLK
Need to find battery location: 1999 Mercedes CLK 320
Hi, The battery is located in the trunk, under the trunk mat.
Apr 08, 2009 | 1999 Mercedes-Benz CLK
Vehicle Parts & Accessories Logo
37 people viewed this question
Top Mercedes-Benz Vehicle Parts & Accessories Experts
Marvin
Marvin
Jonah Oneal
xxxxxx xxx
Are you a Mercedes-Benz Vehicle Part and Accessory Expert? Answer questions, earn points and help others
