Question about Maytag Jetclean Plus MDB6769PA Fully Integrated Dishwasher with 14-Place Settings, 6 Wash Cycles, Jet Clean Plus Steam Cycle, 6 Options, Steam Santize, 4-Blade Hard Food Disposer and 57 dBA
Water coming out small hole on left side
I have water running out of the vent hole intermittently and has ruin a few floor boards. I have a few of these machines doing the same. I was told water temp must be at 120 deg. Pressure is within spec.
4 Suggested Answers
catriver
  • 878 Answers
SOURCE: Water Leak at vent area in door...
On this model the vent is open and shut by a wax motor. The vent should be closed tight during the entire wash cycle and the first 6 minutes of the drying cycle. Check the operation, make sure there is not a bunch of gunk restricting it. If you are handy with a meter check the resistance of the motor. It should read approx. 2100ohms. Another reason for leaking at the base is oversudzing. Also check the upper spray arm for cracks or splits shooting water into the vent area. Catriver...post back.
Posted on Oct 23, 2006
SOURCE: maytag mdbh955aw
is vent cloged if not you got something loose
Posted on Feb 16, 2008
heatman101
  • 43501 Answers
SOURCE: water is not draining from dishwasher started
If you have a problem with your washeror dishwasher continuing to fillwith water after the valve has closed, then you this tip will help youunderstand why that is happening.
Here is a tip that will help you...
Washer orDishwasher Fills with Water when off
heatman101
Posted on Jun 17, 2011
My front passenger floor is always soaking wet it is not coming from the door..where else could it be coming from please
Not sure what vehicle you have, but this could be a few things. Here is where I would start to look:
Check to see if the liquid has any scent, specifically antifreeze. If it smells like antifreeze it could possibly be a leaking heater core.
There could be a leak in the windshield gasket, allowing water to run inside the vehicle.
There could be a leak in the seal for the cabin air vent, which allows fresh air from outside to enter the vehicle.
It could be a small hole in the floor board, allowing water up through the floor from the ground when driving. This is not common, but I have seen it in vehicles that are older, where salt is used on roadways for deicing and along coastal areas.
Jan 26, 2017 | Cars & Trucks
Water under dashboard passenger floor
If you have a sunroof, that may be your issue. I had a similiar problem when it would rain. After a good rain, water would pour from my front side pillars when making turns, which allowed me to see how water got on the floor.
SOLUTION:
1. Open sunroof, stand up so you can fully see sunroof tracks.
2. In the right/left front corners of the the sunroof tracks are small vent holes (locate them). All sunroofs have these holes in the event of minimal water leakage.
3. Take a 2-3 ft strand of solid wire approx 18ga, insert into vent holes to clear out any type of debris, or build-up. (the dealer wants to charge you $$$ to send your vehicle to another facility to do water test for leakage)
4. Last, take a decent sized squeezable cup filled with hot water (not too hot to hold cup), enough to slowly pour is into sunroof track/vent holes. This will ensure you actually pushed any debris down the vent tubing.
5. If you cleared any build-up from the vent holes, you should see water puddles on the ground, or just have someone watch for leakage near the back of the front wheel well.
Hope it works, I performed this same manuever on my wifes 2009 Jeep Patriot, and filled some corner gaps in the tracking with silicon ($2.89 small tube), when the dealer wanted $150 for leak diagnostics. "Really"
Good Luck
Gr00vie Lou
04 Dodge Durango HEMI
VaBch, VA
Feb 03, 2013 | 2004 Dodge Durango
Kenmore side by side. Noticed water dripping out
please do not use hot water.........only clean drain hole with copper wire with very small cloth on
end.sounds like you left door open? adjust feet to allow door to close itself..if left ajar.
fully defrost.clean drain hole.adjust feet. switch on ...
this freezer works best full....
Feb 04, 2010 | Refrigerators
2002 Mitsubishi Galant I am getting water accumilating on the passenger side floor board only when it rains. I can't find the leak....also water now travels from front to back passenger floor board....
It sounds as if the drain line from the vent is plugged. You'll need to get under the car (jack stands please ) to locate. In your forward vent where air comes in for your AC or just Vent rain will obviously get in to it. There is a drain hole at the bottom of this to allow water to flow out. With time from dead bugs, leaves, road dirt... this vent can plug. Under the car locate this vent line, place a small wire up within it to remove the blockage. After doing you may want to both test and flush by use of a garden hose. If there is a lot of accumulated debris it might plug back right away and you'll have to clear again.
I hope this may have helped,
Tom
Oct 22, 2009 | 2002 Mitsubishi Galant
Water Leak in Passenger Side Floor Vent Area after car wash
Unless this happens in the rain as well, I would not worry about it. Likely in the car wash, far more water is coming in than the normal drain system can handle, therefore causing it to overflow. If you do have a drain obstruction, find the drain hose (small right angle hose on firewall passenger side) and roll it in your fingers to clear it.
Oct 12, 2009 | 2003 Jeep Wrangler
Intermittant water leak under Kenmore side by side onto floor
Hi: Well, you have an inexpensive fix ahead. Your defrost drain is clogged. Look at the bottom of your freezer, the back wall. At the very bottom you will see a shallow funnel with a hole in the center. Usually a few slits in the metal above it for venting. This hole is not refrigerated and can also swallow a frozen pea or other morsel. Your defrost mechanism is also above it and uses it to drain the defrosted ice from the coils. Which it is not happening. Unplug and warm the freezer (put your food in a cooler) and you could pour some warm water and clorox bleach down the hole at the bottom. If it is just mold the clorox will eat it up. If its worse get a pipe cleaner (as in tobacco pipe) and work it in the hole. You have a cheap fix. Hope this helps, Jeff
Jun 01, 2009 | Frigidaire 26.0 cu. ft. Side-By-Side...
Water leaking from freezer
Check for a blocked defrost drain. Take the panel off at the back of the freezer section and find the small hole at the very bottom center below the cooling coils. Use hot (but not boiling) water and a turkey baster to flush it out until water runs through it. (it will go into the defrost drain pan, where it will evaporate)
This will prevent water from comming out the freezer door and leaking onto your floor and running down your copper pipe to the basement.
May 12, 2009 | Hotpoint HSS25GFP Side by Side...
Lg DISHWASHER INTERMITTENT WATER LEAK
I have this same dishwasher,and have had the same problems that have been described in this forum..
LG model#LDS5811.I bought it from Home Depot as a scratch and dent with no warranty available for about $400.00.
The problems I have seen on my own and have read online have been Intermittent leaks on the left side door,as well as both sides.And in some cases,even wiring and motor problems.
In my case,the water was coming from a leaking O-ring behind the evaporator housing in the door,as well as a small hole in the drain hose in the part of the hose on the left side where the hose loops up the side of the machine behind the panel before it comes out of the back.
You will need to take the left side panel off to undo the wire holding the hose in place as well as remove the bottom plate over the motor to gain access to remove the hose from the pump to get the hose off of the machine.Simply replace the hose.You can order online or buy a replacement at an Appliance Repair store as I did.
To repair the door leak,you will need to remove the lower outside panel that is under the control panel.Inside the door,you will need to turn the vent cover at the top of the door counter clock-wise one-forth turn and remove the entire evaporator unit as a whole.You will see a 1.5 inch O-ring.
I repaired this by getting G.E 100% silicone that you can purchase at a Home Repair store like Lowes or Home Depot and sealing around both sides as well as putting a good bead on top of the O-ring itself,and wipe off the excess after re-installing.
I performed these repairs over a month ago,and have had very good success.No leaks to be seen.I am a A\C,Refrigeration Tech by trade,and have done alot of Appliance repair/installation as a side trade from being a maintenance technician at some very large Grocery chains the last 20+ years.
I completely dissassembled this machine and have found it to be a decent product,but some shoddy materials and questionable assembly practices have created these problems,but good sound engineering.
I hope this helps someone with the problems with this machine so it wont be a total loss.
Nov 06, 2008 | LG 24 in. LDS 5811 Built-in Dishwasher
Refrigerator leak
the water fill tube for i/m is on the back of ref. the tube you have is to the water dispenser. look in freezer floor, is it full of ice? if so, remove all ice and clear drain hole for evap. if not, reassemble what you took apart and inspect tube under ref. while someone runs water dispenser. find leak and repair.
May 20, 2008 | Maytag MZD2766GES Side by Side...
Maytag Jetclean Plus MDB6769PA Fully Integrated Dishwasher with 14-Place Settings, 6 Wash Cycles, Jet Clean Plus Steam Cycle, 6 Options, Steam Santize, 4-Blade Hard Food Disposer and 57 dBA Logo
13 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
