Question about Electric Mobility 4 Wheel Power Electric Motorized Wheelchair Scooter
When i turn on the scooter it makes a loud beeping noise and wont move
When i turn on my scooter it makes a loud beeping noise and it will not move it doesnt run at all i am stuck
    Master:
  • Electric Mob... Master
  • 401 Answers
Put it in Drive mode (freewheel lever)
Posted on Jul 03, 2016
2 Suggested Answers
SOURCE: my scooter making loud beeping noise and wont move
take battery out and put it back in
Posted on Mar 24, 2012
The pet itself is emitting a loud beeping noise and wont move or respond to button presses
Take it back to the store where you got it and get them to either fix it or replace it.
Oct 16, 2014 | Toys
Why can't i get my scooter to move it has full power.
Even though battery meter is showing full voltage, does not mean the batteries are necessarily capable of propelling the scooter. Have you had the batteries capacity tested? When you press the throttle does it beep or flash to indicate a fault? Is the solenoid brake clicking is it making any noise at all?
Jul 21, 2014 | Invacare Lynx Lx-3 Scooter Model...
How to stop a continuing beep on my Cordoba scooter when I turn the key on? The scooter don't move at all.
Hi Mag,
I have this steps that might help you with beeping sound on your Scooter. Hope it helps.
UNIT LIGHTS UP/HORN WORKS BUT UNIT WILL NOT MOVE
Possible Cause:
  • This often occurs when the scooter is in free wheel mode and is not in drive mode. Re-Engage the free wheel lever which is located down near the rear wheels (normally a yellow or red lever).
  • If you hear a beeping noise, the beeping you hear is a fault beep indicating the scooter main control box has detected a problem. Contact your dealer who can diagnose the beep code.
  • Check batteries with load tester - If either battery drops more than 1 volt under a load, the battery(s) are bad. Replace "both" batteries.
I also find these additional steps on how to know beep alarm indicators:
This main control box has a self-diagnostics feature & cannot be tested with a volt meter. When a
problem is present the main control box will diagnose the fault, prohibit the scooter from being driven
and sound an alert beep. Each alert beep indicates a different issue which helps to determining the
problem by narrowing the fault into one of a few main areas of the scooter. Reference this information
below for the alert beep indications.
Very Rapid beep- Batteries are low. Charge & test batteries.
Medium Fast beep- Motor/brake wiring fault. Free wheel lever disengaged.
Solid beep- The charger is plugged into the scooter (some models may vary).
Very Slow beep- The throttle pot was not at center when you turned the unit on. Throttle pot off
center or wiring (yellow & orange wires) fault.
Apr 24, 2014 | Shoprider Health & Beauty
When the ignition key is turned on it makes a beeping noise and will not engage
hi, that can be because the throttle lever and pot has moved off centre slightly...you need to make sure the cross head located on the bottom of the pot , a metal stem that the throttle lever fix to is dead centre to you when sitting on the scooter...
Regards
Rob
www.gewizrepairs.co.uk
Mar 05, 2014 | Shoprider Scootie
Turn my scooter on everything working when try to move forward makes beeping noise and won't move
hi, i need the brand and model please ?
Regards
Rob
Feb 01, 2014 | Health & Beauty
Beeps continuesly wont move
more info, make model, are the beeps in clusters (3 fast bleeps gap 3 fast beeps etc) any lights?
Oct 30, 2013 | Electric Mobility Shoprider Electric Power...
We have a Fortress Scientific 2000 electric scooter that hasn't been used for several years. We put in new batteries, it shows fully charged, comes on and has a steady beep, but won't go forward or...
Your break release shifter is in the push the scooter mode. Put it back in gear and the horn doesn' beep and it should run..
The horn beeping is the alarm to tell you the break release is on.
It is usually located under the seat on the body of the top of the battery housing. Looks like a stick with a ball on it.
Oct 03, 2010 | Electric Mobility Mobility Electric Power...
Electric Mobility 4 Wheel Power Electric Motorized Wheelchair Scooter Logo
161 people viewed this question
Top Electric Mobility Health & Beauty Experts
Robin Hill
Robin Hill
Colin Taylor
wcdoc1953
wcdoc1953
Are you an Electric Mobility Health and Beauty Expert? Answer questions, earn points and help others
