How do i fix my Mitsubishi WD-C657?
Turns off after less than 30 seconds. Throwing a 38 code: Lamp temperature high. New lamp installed. All fans are operational. Ballast sounds like its working. Suspecting a light temperature sensor or thermal switch may be faulty. Unsure how to proceed at this point.
    Filmmaker:
    Uploaded 5 video answers.
  • 78 Answers
At this point it could even be a communication issue between the circuit boards themselves. Call around to various TV repair shops to get an idea of the problem and an estimate. Last time I came across a similar prob the person got charged several hundred dollars because of the type of TV it is and it may be worth it to just purchase new.
Posted on May 19, 2014
4 Suggested Answers
Slinteriors
  • 8617 Answers
SOURCE: green status light keeps blinking after lamp replacement
continuous blinking green light indicates that the capacitors have failed on the DM pwb. You need the V26 DLP DM repair kit which is available at the following link under their repair category.
http://servicemanuals.vstore.ca/
Posted on Sep 09, 2008
Slinteriors
  • 8617 Answers
SOURCE: Bad Bulb?
the pins that protrude into the lamp compartment have a tendency to get out of alignment where the lamp will only make partial contact. It sounds like what youre describing.
Posted on Jun 15, 2009
  • 52 Answers
SOURCE: Mitubishi WD 62725 - Ballast Problem??
Could be the FMT pcb or the Dm pcb board you should check the caps on them and replace any faulty ones.
Posted on Nov 14, 2009
We have a Mitsubishi TV model# WD-60735.. we have changed the lamp because it was flashing red but now its flashing yellow and the tv will not turn on..
Mitsubishi TV troubleshooting
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
Nov 18, 2015 | Mitsubishi Televison & Video
Flashing light mean yellow
Jan 15, 2014 | Mitsubishi WD-60737 60 in. HDTV
Starting light flashes green, and then red. Turn off and on several times.
Possible lamp but:
Nov 07, 2012 | Mitsubishi WD-65733 65" HDTV
Wd-60737 mitsubishi blinking yellow status light ?
Oct 25, 2012 | Mitsubishi WD-60737 TV
We have a mitsubishi WD-62525 tv and we turned it on and after a while it turned itself off and then we got a continiously flashing red status light! what does this mean & what do we need to do to fix...
Mitsubishi TVtroubleshooting
Here's something that might also be useful. After you turn on the set, and getthe regular red blinky lights, hold down the Device and Menu buttons togetherfor about 5 seconds.
33 = Air filtercover is open.
44 = DVI cablebetween FMT and Engine disconnected
Jun 11, 2012 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi wd-73739 turns on then turns off with a red constant led
The set has a self check--try this(posted by another expert here):
"Here's something that might also be useful. After you turnon the set, and get the regular red blinky lights, hold down the Device andMenu buttons together for about 5 seconds.
44 = DVI cablebetween FMT and Engine disconnected"
Jun 03, 2012 | Mitsubishi Televison & Video
Mitsubishi dlp tv model wd-62627 wont power on when i plug tv in green light flas then will stop then i try to power on tv after after green light stops flashiing after oabout 30 sec red lamp light co
Inspect the lamp first to see if shattered--set has a self check feature also:
May 30, 2012 | Mitsubishi WD Televison & Video
I have a mitsubishi wd-52631 and the red light is solid I just cleaned out the tv and got a new bulb but when I turn the tv on I get about 2 mins of picture and sound before it turns off. Does any one know...
It is possible either did not get all the dirty areas in front, and rear of set cleaned out or even that the ballast for the unit is this problem since it powers the lamp---lamp will come on and then turn off for a number of reasons.
The set does have a self diagnostic feature which usually is:
May 02, 2012 | Mitsubishi WD-52631 52" Projection HDTV
Mitsubishi WD-62526
Jan 13, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WD-52725 FAN?
Dec 24, 2007 | Mitsubishi WD-52725 52". Rear Projection...
Televison & Video Logo
37 people viewed this question
Top Televison & Video Experts
Electro Med Services...
