Question about Acer Aspire 4720 Notebook
Media test failure,check cable,operating system not found
    Problem Solver:
  • 15 Answers
Try Opening you BIOS at startup try configuring the boot preferences, make your disk containing os to first one....
Posted on Feb 07, 2014
4 Suggested Answers
zohail
  • 1223 Answers
SOURCE: PXE-E61: Media test failure, check cable Pxe-M0f: Exiting Broadco
PXE-E61: Media test failure, check cable (of the HARD DISK pls)
pls first check the hard disk seated in the bottom left side of ur notebook u have to take out the 7 or 8 screws first and then take take it out by pulling the connector gently and try to re seat or re fit the hard disk so connector can seat firmly in hard disk and then power up ur notebook if Error persists
then sorry to tell u my friend that ur Hard disk has CRASHED and not giving up files for OS loading kindly replace ur HARD DRIVE and restore ur OS thru backup disk u got
Pls take care of ur notebook from bumps and falls and hard impacts during operation and carrying bcoz the disk inside the HDD is very sensitive and gets damaged easily by impacts
pls rate me FIXYA for my diagnosis
Posted on Mar 09, 2009
babes_ganda0
  • 381 Answers
SOURCE: operating system not found media test failure will not reboot aspire 3680
hi..try to remove unplug or plug in the Hard Drive,, if cant work you or nothing happens you need to re-place the hard drive.about files theirs nothing ways to recover the files if the Hard Drive is totally defective..Thanks..and GOOD LUCK...^_^
Posted on May 13, 2009
bob_computer
  • 3153 Answers
SOURCE: aspire 3682 PXE-E61:Media test failure.check
PXE error means that it is trying to boot from an ethernet / lan connection.
check your boot order options first and set it to boot
1. Hard drive
2. CD rom drive
3. Floppy (or usb if you know how to do this)
4. network(aka PXE)
If it still fails then yes there MAY be an issue with your hard drive.
Check all hard drive connections before running off for a new one.
This can be especially true with SATA type drives most of which dont have any sort of true locking device to hold the connections secure.
Posted on Sep 28, 2009
Testimonial: "I found an internal disconectet cabel fixing it solved the bootproblem"
Booting problem, screen message: Intel (R) Boot Agent FE v4.1.18 Copyright (C) 1997-2005, Intel Corporation PXE-E61: Media test failure, check cable PXE-MOF: Exiting Intel Boot Agent. Operating...
HI there,
The "Error" texts saying:
Are completely normal. This simply states that there is no external cables plugged into the specialty inputs on your toshiba laptop.
The "operating system not found" is stating that your existing hard drive is either A) dead or B) been erased.
Try to re-install your operating system, if it finds no hard drive, you'll need a new one!
May 04, 2011 | Toshiba Satellite M105-S3041Notebook
Went to shut down comp. and screen said, and still is. broadcom undi pxe-2.1 v11.4.1 copyright [c] 2000-2008 broadcom corporation copyright [c] 1997-2000 intel corporation all rights reserved. ...
A "media test failure, check cable" means your hard disk failed. The bios can not locate the boot sector of the hard disk to begin loading the operating system.
"Operating system not found" means windows can't load because the Bios can not find the operating system (because the hard disk failed).
This is pretty much an unrecoverable error in terms of fast fixes. You can take the hard disk to a data recovery service if you need to retrieve important data or files.
Dec 05, 2010 | Acer Aspire 5610-2328 Notebook
Computer wont boot error msg says media test failure check cable operating system not found
problem in your boot device.check your HDD is properly connected and working properly.
if HDD is good,you must install your operating system again.
Hope this will helpful..
Nov 22, 2010 | Computers & Internet
Acer travelmate 4010 model zl1 ; pxe-e61: media test failure , check cable; system won't boot; operating system not found
clean filesystem with a scan disc if it isnt a mother board failure reinstall OS from external drive
Sep 06, 2010 | Acer TravelMate 4010 Notebook
Operating System not found
first checkout that your harddisk is detecting on startup or not.
May 08, 2010 | Acer Aspire One PC Notebook
When switched on it says media test failure,
It is not finding your hard drive, what type of laptop do you have? This is usually a corrupted bios or faulty BGA chip
Mar 28, 2010 | Computers & Internet
Media Test Failure, cheack cable. What exactly
This means that the "Media" CD, DVD, HDD has been "Tested" by the Window Operating System, for veracity, and has been found NOT to have passed the "Test", therefore windows WILL NOT USE IT, as it doesn't want the data corrupted. This usually means that the device is defective in some way. Replacement is the usual answer.
Mar 22, 2010 | Acer Aspire 5735 Notebook
Media test failure,check cable, exiting bordcom pxe rom os not found
check connections of hard drive. 2nd check boot order in Bios, remove Lan or network boot from top order. 3rd choice if not solved reset bios by removing cmos battery and putting back in to clear it.
Char S.
May 24, 2009 | Computers & Internet
Problem in PC
Operating system not found: Hard Drive is disconnected or broken.
You can't open what?
Nov 18, 2007 | Computers & Internet
Acer Aspire 4720 Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
