Question about Pierre Cardin Revolution 4-piece Spinner Luggage Set Burgundy
The luggage handle button is depressed and won't allow the handle to move up or down
The luggage handle is depressed and won't allow it to go up or down
Battery dead. how can I get trunk open.
You can't unless it has a key hole. If you put jump leads on the battery or connect a battery charger it will open straight away.
May 01, 2016 | 2008 Ford Taurus SEL
Isuzu 3ld-Tec 4x4 won't move out of park without depressing the shft-lock button
it is not supposed to move from park unless you press the button.
Oct 02, 2012 | Cars & Trucks
Power button stays depressed and does not start power menu. power is on, drum light is lit.
You will need to replace the control panel. The button is pressed in the down position and won't allow you to do anything else till this part is replaced.
Jun 12, 2011 | LG DLE2514 Electric Dryer
I have a circular saw that is locked and the blade won't rotate its brand new how do you free the blade?
Its sounds like the blade lock button is depressed.
looking from the rear of the unit, you should see a button between the left side of the handle and behind the blade shield.
check that. it probably is locked in the depressed position or it may be damaged.
I hope this helps.
May 18, 2011 | Dewalt DC390K 18v Cordless Circular Saw...
The shredder was paper jammed
Ensure the wastebasket is empty then move power switch to the REVERSE position. This will reverse the jammed paper out of the shredder. If shredder jams again, alternate control switch slowly between REVERSE and AUTO (l) positions to attempt to move jammed paper completely through the shredder. If the shredder jams in reverse mode, move the switch to AUTO (l), depress the manual forward button located on the center of the shredder head and allow to run for five seconds. If jam does not clear, move switch to REVERSE again and allow to run for five seconds.
Repeat this process until jam is cleared. If necessary, turn off shredder and use care to grasp the paper and carefully pull out to clear jam. Once cleared, move switch to AUTO (l) to continue shredding. The jamming may be happening because the cutting cylinder needs to be oiled.
Follow instructions to oil your shredder;
To keep your shredder in top condition, the cutting blades need to be oiled every so often (for frequency, please refer to your owner's manual). We recommend using Powershred® Lubricant or a vegetable-based oil (such as corn or canola) in a non-aerosol container with an extension nozzle.
Caution: Never use flammable synthetic oil, petroleum-based, or aerosol lubricants to oil the cutting blades. Some agents may combust, causing serious injury. NEVER USE WD40.
1. Depress and hold the reverse button down.
2. Put the tip of the oil bottle in the paper entry and make one or two sweeps the length of the entry while squeezing the oil bottle.
3. Move the power switch to Auto (I) position, or depress the manual forward button (depending on model of shredder) and allow the blades to run at least three seconds.
4. Move the power switch to Reverse (R) position and allow it to run for at least three seconds.
5. Repeat steps three and four above at least three time.
Regards.
Apr 20, 2011 | Geha Primo 1400 Shredder
How do I life up the screen (open the laptop) on an HP Pavilion vd 4000? when I press the central button on the front, nothing happens.
When you push on the center button, that is supposed to move two hold down teeth to the side allowing the screen to move up. You then grab the lid and lift the screen manually into position. If the lid will not move up with the button depressed, then a piece of linkage is either binding or broken. In that case, keep the button depressed and try taking a credit card and sliding it from one side to the other and then back in the opposite direction, the teeth are tied together so if you move one, you move both. If you feel resistance on the card, try lifting the lid as you move the teeth.
Sep 27, 2009 | Computers & Internet
Porsche Boxter rear luggage compartment lid pull-button problem
remove the two plastic bungs in the side of the cover panel down side of seat, then inside are two 6mm allen screws, these need to be loosened, not removed to allow the trim to be lifted up to access switches. refitting is reversed
Jul 06, 2009 | 1997 Porsche Boxster
How do i fold down the mutsy urban rider pushchair
To fold the Mutsy Urban follow these steps:
Stand slightly to the left of the pram, but have the handle bar (with button depressed) in your right hand. Have your left hand on the black cuff (on the left hand leg of the chassis)
In one movement, push in the button on the handle (with your right hand) and move downwards, whilst pulling the cuff upwards (with your left hand). Do this quite firmly and the pram will then collapse. Make sure that the handle is in the lowest position after folding, ensuring that the pram is as small as possible.
I hope this helps.
Jul 04, 2009 | Baby Gear
Set luggage lock
the lock is currently set to 000. To set your own combination and with the lock in the 000 position, open the case and on the inside of the lock mechanism you will see a red tab. slide this tab to the left and then move the digits on the front to your desired code. ie 123. then move the red tab back to lock in this new setting as your own personal combination. close the case and then move the digits away from our setting of 123 and this locks the case. only if the digitrs are 123 in this example will the lock now open.
Dec 24, 2008 | Locks & Locksmithing
Pierre Cardin Revolution 4-piece Spinner Luggage Set Burgundy Logo
Top Pierre Cardin Luggage & Travel Experts
Dave braun
Dave braun
Tom Chichester
Bobby Lewis
Bobby Lewis
Are you a Pierre Cardin Luggage and Travel Expert? Answer questions, earn points and help others
