Question about Sharp Sf 2050 3062 Compatible Copier Toner Sd-360
Sharp sf-2050 toner moter how to chuch moter is working or not working
    Problem Solver:
  • 20 Answers
In put key *c+interput+0+interput+10+start+1+start =active motore toner for 30 sec
Posted on Feb 07, 2014
4 Suggested Answers
  • 163 Answers
SOURCE: sharp ar-162
CHANGE TONER CARTRIDGE CHIP
Posted on Sep 08, 2007
randula7
  • 78 Answers
SOURCE: The Sharp SF-2050 is displaying L4, call for
L4-01 Drum motor drive problem
L4-02 Main motor drive problem
check drum unit and all the gears
Posted on Jan 10, 2010
  • 5 Answers
SOURCE: I have a Sharp SF 2114 copier. Just replaced the
if taking the toners back out and putting them back in doesn't fix it, try having it run an alignment. Let it redo the setup for it as that is a lens adjustment error code.
Posted on Sep 14, 2010
No fonctions
  • F2 with sub code 00 - Toner Sensor problem, ID pattern reading error;
  • F2 with sub code 02 - Toner Motor problem, check toner dispenser motor;
  • F2 with sub code 31 - Image Density error, Check the light level or the drum surface reflectivity;
  • F2 with sub code 32 - Drum Mark sensor, missing/dislocated mark or sensor faulty. Sensor cannot scan mark properly;
  • F2 with sub code 33 - grid voltage wrong, either too high or too low;
  • F2 with sub code 35 - grid voltage correction will not work during simulation;
  • F2 with sub code 37 - drum mark sensor adjustment required.
Feb 24, 2014 | Sharp SF-2025/2030 Copier Toner Black...
After powering on, it will show F2 on the Sharp SF 2540 Copier, So please, I need a programme code to clear it or any other solutions to solve it problem
You need to take it to a Sharp technician to check machine , usually a toner issue that toner is unable to replenish in developer unit and so blows the chip on toner cartridge ,
replacing toner cartridge rarely helps
seeing as it is a deeper issue
Sep 12, 2013 | Sharp SF 2540 Copier
I have a Sharp SF-2020 pedestal copier. The red triangle dots appeared above the yellow digital copy #. Prior to this, it took over a minute for the copier to "boot up". I added factory toner...
Hi r_finch424,
The blink red triangle means that the toner is completely over and can't be refilled. The toner cartridge comes with on-chip sensor that counts the toner life. To resolve this issue, you need to replace a new toner cartridge.
Hope it helps.
Thank you for using FixYa.
Aug 29, 2011 | Sharp SF 2020 Copier
How can I change the toner in my sharp 2530 sharp
open front cover ,release green holder on the right,pullout developer unit add toner .
Apr 26, 2010 | Sharp AR-M237 Copier
The Sharp SF-2050 is displaying L4, call for service. What exactly does this mean and how can it be fixed?
Jan 09, 2010 | Sharp Office Equipment & Supplies
Sharp SF-7370 copier, with a dark line going from top to bottom
check the drum cleaning blade maybe the blade is worn out
Jan 04, 2010 | Sharp Office Equipment & Supplies
After changing toner on my sharp, SF-2022 copy machine, the copies are coming out with black smudge marks across the paper? how/where should i clean?
This means the machine is over-toning ie using more toner than required caused by either improper toner or different brand of toner. The correct toner is sf 222T1. Replace developer and use the right toner and clean the drum and its blade. You may need to clean fuser rollers for cleaner copies.
Nov 13, 2009 | Sharp Office Equipment & Supplies
Sharp sf 2114 toner
Type SF-214NT1 toner cartridge.
Jul 10, 2009 | Sharp Office Equipment & Supplies
Sharp sf 2050 prints dark lines on page when beginning copies, lines dissapear after about 100 copies....is there some kind of heating element in these or something i am overlooking please let me know
replace the drum cleaning blade , clean the optices if this does not work replace the drum but this is a old copier not really worth much $50 mabye
percison roller phx az has parts
Feb 25, 2009 | Sharp Office Equipment & Supplies
SHARP COPIER
Have you cleaned the optic's? what roller was replaced? Was it the drum unit? If not you may need to replace the drum unit.
Jan 22, 2009 | Sharp SF 2020 Copier
Sharp Sf 2050 3062 Compatible Copier Toner Sd-360 Logo
29 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
