Question about Neato XV11 Vacuum
Neato seems to have died but the green light is on
My Neato had been cleaning and appeared to have stopped under a table. I was gone for the weekend and found it when I returned. The green light was on, but it was completely unresponsive. I put it on the charger and it is still unresponsive 2 days later. What is wrong with it?
Mine was doing same thing. was working flipped upside down to replace the rubber blades then nothing.Display dark only it has green led around orange button. Unplugging batteries didn't help.pressing buttons nothing. holding buttons down nothing. Found this on another site. Connect the vac to your computer and place it on charger at same time. Press and hold the orange button for about 10 sec. or so. it should turn of the LED then let up and repress button. vac should then reboot. Unplug computer. Wouldn't hurt at this time to tell it you put in "New Batteries" but first remove any scheduled cleaning days to clear its memory. After doing the New battery, reset the schedule and let it charge. After that it maybe a good time to check your program version and update it from the Neato web site to the newest update. The newest update does wonders for the battery run time issues.
Posted on May 03, 2015
  • Chris Keene
    Chris Keene Jul 04, 2015
    This fix worked BRILLIANTLY. Thank you, thank you, thank you! I'd tried everything else to no avail and this is the only thing that got Rosie back into the land of the living robots.
  • Dede Clement-Lawton
    Dede Clement-Lawton Sep 01, 2015
    Thank you!! But please tell people the usb port is hidden on the back behind a weird piece of rubber! It only took me an hour to find it! The mini usb connector is hard to find also. Luckily, I had a Bluetooth speaker connector that worked. Also, you had to ignore the manufacturers instruction to not have the robot on the charger while hooked up to the computer. Other than that, 2 hours later, it is now charging. Thanks!!
Did you ever get an answer? My Neato is doing the same thing. Solid green light but unresponsive.
Posted on Nov 19, 2014
4 Suggested Answers
app_3rp22205
  • 3 Answers
SOURCE: My neato won't map, just
Make sure you have upgraded to software version 2.6:http://neatoroboticsupdates.com/
Joewww.joeramsay.ca
Posted on Feb 26, 2012
app_3rp22205
  • 3 Answers
SOURCE: using neato in a new
Make sure you have updated the on-board software to the latest version, 2.6.
Joe www.joeramsay.ca
small6363
  • 18392 Answers
SOURCE: wondering where I could obtain a schematic for my neato xv-11 all floor vacuum system.
this link is for the manual may help you..
http://www.roboshop.lt/wp-content/uploads/2012/05/neato-xv-11-user-guide.pdf
Posted on Dec 08, 2012
Neato botvac connect does not return to dock
If it's still under warranty, the best thing would be to call Neato support. There is also a very active Neato support forum on the site robotreviews [dot] com where you will find many experts who own Neatos.
Apr 25, 2017 | Neato Vacuums
Tip
How to fix the neato vacuum
It's a great design BUT the weak point in the design is the quality of the 100uF electrolytic capacitors that they use on the main board. After 2-3 years these cause problems with the Neato not turning on (dim green lights only) and its vision gets worse so it has problems with eratic cleaning patterns and can't redock itself.
in this video we show show to fix all those issues by changing the main board capacitors. It's like new again now! See it redocking itself late on in the video, it is about 50ft away in another room and comes back for charging!
Here is a video showing a quick temporary fix and the full fix showing the change of all the electrolytic capacitors.
on Nov 25, 2015 | Neato XV-21 Pet & Allergy Automatic Vacuum...
My Neato XV1 says it's vision is blocked. I have cleaned everything-used pressure air, wiped off all vision eyes but it still says it's vision is blocked. What else can I do?
There are several errors that can occur for unknown reasons if your batteries are not working properly. How old are the batteries? There is a piece of software designed by Neato users which can diagnose issues with your Neato, including getting a map of the lidar scans. Search for the download on the site robotreviews [dot] com in the Neato forum.
Mar 30, 2017 | Neato Vacuums
MY NEATO VACUM , IS SAYING SOMETHING IS STUCK IN BRUSH CLEAN ! I CLEANED IT BUT STILL SAY IT STOP,
The bearings are dirty so heating up and waking the voice alert. Take out the brush and scrub the part it sits in. It'll be packed with something nasty. Rouge fishing .inexpensive wrapped in there will burn away the plastic seating. Keep your equipment clean and it will perform and last much longer
Feb 01, 2017 | Neato Vacuums
My Neato XV-12 runs for only a few seconds and stop. The message says, please dust me off I cant see. I have dust and cleaned my neato and it still says the same thing. How do I fix this problem?
Hi Guys
I've fully dismantled my Neato XV-21 to locate the source of the "can't see" problem. (And also replaced a tight wheel Motor causing a "something is caught in my right wheel" message)
There several screws underneath the Neato XV-21 that must be undone to allow the top to be separated. A bit of a pain just to get into the visual sensor area. But not too hard with an electric screwdriver.
There is a Laser device & a Photo sensor mounted to a black plastic rotating wheel which is covered by a black cap with 2 holes in it. One hole for laser beam to exit & one to pick up return laser light return data. They are both rotated by a motor & pulley via a rubber "o" ring which could slip, break or get hairs caught in it.
These could be the source of problems. Once mine was cleaned & checked I had no more problems. Then the wheel motor got tight. Replacing the motor fixed the problem. This requires hoping the Motor Gear Box assembly out by poping the pivot shaft out of it's plastic holder. Then disconnect the spring & cable connector. But you bust be prepared to carefully remove the magnet off the motor shaft (vice & 2 flat blade screw drivers) then unsolder the small PCB at 2 points. With practice (twice) I can now replace a motor in 20-30 minutes.
Hope this Helps some Neato Users out there
Cheers
Trevor
neato-xv-12-runs-only-few-seconds-stop-qnpe3nojpvl4vx0tieerofmg-2-0.png Wheel Motors Here
Wheel and brush motor for Neato XV 11 XV 12 XV 14 XV 15 XV 21 XV Signature...
Apr 05, 2015 | Neato Robotics XV-12 Vacuum System - White
Neato won't charge
Hi, it's Jeremy from Crucial Vacuum.
Try charging your Neato vacuum directly with the plug. If you take apart the dock you will find the plug inside. Plug that plug directly into Neato and charge the Neato until its light is green. If your Neato's Battery charges and it works ok, reassemble the base with the charger making sure that the plug you plugged into your Neato is plugged FIRMLY into its connector inside the base.
You can purchase direct your replacement Neato parts from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/catalogsearch/result/?q=neato&order=relevance&dir=desc
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jeremy Lerner
Crucial Vacuum Customer Care
Aug 05, 2014 | Neato Vacuums
Neato vacuum display will not come on.
Jul 04, 2014 | Neato XV11 Vacuum
Why does my neato xv-12 keeps saying "put me on the floor" but it is and I cannot turn off
There are sensors in the wheel housing that let Neato know whether it is being held (wheels protruding from the frame), or whether it is on the floor (wheels tucked into the frame). If those sensors are not working, you will need to have the unit serviced (if under warranty), or you can look up information on how to correct the problem yourself (if out of warranty). This information can generally be found by searching the Neato Robotics forum at:
RobotReviews com
May 11, 2014 | Neato Vacuums
Neato vacumm won't turn on
Apr 17, 2013 | Neato Vacuums
Neato XV11 Vacuum Logo
1,026 people viewed this question
Top Neato Vacuums Experts
richie46
ray gallant
Are you a Neato Vacuum Expert? Answer questions, earn points and help others
