Question about Canon imagePROGRAF iPF8000 Printer
IPF650 Canon Hardware Error 03130031-2F26 is it main board problem
What is causing persistent error 03130031-2F3A?
hi, are you machine is use for long time ?? see may be is usage ink tank supply unit reach the counter count limit,may be need to reset it by use canon service tools.but this tool only got in canon service tecnician only. if usage no high look like is the main controller PCB fauly need to replace it,this part will cost high cause very expensive price to replace it.
Apr 05, 2016 | Canon imagePROGRAF iPF650 largeformat ...
Hardware error 03130031-2f13 on IPF650
update your firmware version to 1.35
if your printer firmware is 1.32 and below. try this linkhttp://software.canon-europe.com/software/0027485.asp?model= follow the instruction included.In Case You Still face Problem and Need Online Assistance Then Please Follow Us For On :
Canon Printer Support
Feb 27, 2014 | Canon imagePROGRAF iPF650 largeformat ...
Canon ipf650 Keep terminating print job
Hello my name is Steve. And I would first un install and re install your drivers. Also have you registered your printer with Canon.? This is important since any updates to your printer and to follow commands, print job recognition, fonts, ect. depend on this. With Windows updates, certain devices do not get recognized for any update. Also if you have a change of internet service provider, it is advisable to perform the Driver Recondition process. This way It will ensure all files are working between printer and Computer .
Jan 10, 2014 | Canon Office Equipment & Supplies
03130031 2F26 ERROR
Hi! please read this:
http://canonipf.wikispaces.com/message/view/FAQ/23678081
Dec 02, 2012 | Canon imagePROGRAF iPF650 largeformat ...
Garodclfilter error : 3000
Disable Fast Graphic Process. This is located in the Main menu of the driver. From memory you have to select the Advanced tab from the Main menu to see this setting.
Jan 06, 2012 | Canon imagePROGRAF iPF650 largeformat ...
How do i get into service mode for canon ipf650
Power off the printer, then hold "Load" and "Navigate" while powering on, until the display shows "Starting Up".
The Service Menu is in the settings menu, on top.
Sep 17, 2011 | Canon imagePROGRAF iPF650 largeformat ...
Hardware Error 03130031-2E23 Turn off printer, wait, then turn on again I done this twice and it does not fix the problem, it just repeats the same message. Any ideas what the problem is?
This error on the Canon iPF-605 wide format printer means that there is a problem with the paper cutting knife. The knife (black block) should be at the left front side in it's rest position.
Powered the printer down and moved the knife block from right to left, powered on and voila: problem solved ! Thanks Canon support!
May 19, 2011 | Canon Office Equipment & Supplies
Error on Canon Pixma IP5200
20 times Other hardware error [6500] - Logic board ***'y (QM2-2670)*1
Its the small circuit board next to the carriage unit
You can get one for about $30 from this company web site.
www.euro-parts.it/download/slowmover_oct-2008.xls
You probably have to contact them directly to get your exact circuit board.
Sep 29, 2009 | Canon PIXMA IP5200 InkJet Photo Printer
Canon imagePROGRAF  iPF8000 Printer Logo
51 people viewed this question
old marine
old marine
