Computers & Internet Logo
A
Anonymous Posted on Feb 07, 2014
Setting clock on laptop toshiba need to find out how to change time on laptop pc
IFBEAR
Level 1:
Problem Solver:
  • Contributor 30 Answers
  • Posted on Mar 23, 2015
IFBEAR
Contributor
Level 1:
Problem Solver:
Answers
30
Questions
Helped
3428
Points
57
The above answer is simple and correct. If you need to regularly change the time if for example your clock is not keeping time, then I suggest you load Atomic Clock which is a free app that will synch the item daily and keep your clock accurate.
http://www.worldtimeserver.com/atomic-clock/
stephen Adams
Level 3:
  • Toshiba Master 2,219 Answers
stephen Adams
Toshiba Master
Level 3:
Answers
2219
Questions
0
Helped
355162
Points
22262
Click on the clock time and you can edit the time and date.
The clock time is on the bottom right hand side of the desktop.
How do I set the date and time on my Toshiba lap top computer?
You can set it by changing the clock in windows.
Or go into the BIOS usually F2 or Delete key.
How to change the date and time settings on a Toshiba Chromebook CB30-102
To change the time, adjust your time zone, or to switch to a 24-hour clock, visit the Settings menu.
  1. Sign in to your Chromebook and click the status area in the lower-right corner of your screen.
  2. Select Settings.
  3. Click Show advanced settings at the bottom of the page.
  4. In the "Date and time" section, you can adjust the following settings:
    • Select your time zone from the menu.
    • Switch to a 24-hour clock, instead of a 12-hour clock.
Wolf ovens getting err message after power outage
I had a Wolf 30F wall oven with a similar problem
after power outage. It wouldnt stop beeping with error message related
to temperature control. My solution was to turn power of at circuit
panel, then reset by pressing and holding the clear button for 5
seconds.
Also note: in my case I had to close the display
before switching the panel off. When I tried to the reset process with
the panel showing, it wouldn\'t reset.
To reset other
various parts of the control panel Instructions said:
Time-of-Day Clock
Immediately after the oven is installed, set
the 12-hour clock to the current time of day. It may need to be reset
after a prolonged power failure. The clock is visible on the control
panel during all modes. If the upper oven timer is set, the clock will
not be visible in the upper oven control panel display.
SETTING CLOCK
1) Touch CLOCK.
2) Touch number pads to
set current time of day.
3) Touch CLOCK or ENTER to start
clock.
24-HOUR CLOCK
The time-of-day clock can be
changed from a 12-hour clock to a 24-hour clock. After the clock has
been set, touch TEMPERATURE for three seconds, touch CLOCK, and then
touch ENTER. Follow the same sequence to change back to the standard
12-hour clock setting.
Fahrenheit to Celsius
The
oven can be changed from Fahrenheit (°F) temperature to Celsius
(°C).
Toshiba satellite laptop won't keep the correct time
Sounds like you need to change the CMOS Battery. Most times you will have to disassemble the laptop to get to it. It is on the motherboard somewhere. Looks like a silver nickel and once you see it pop it out with a flat head screw driver. The normal size is CR2032 but check yours. They can be purchased at Walmart, your grocery store or drug store for less than $5.00
My clock is losing time
double click the time at the bottom right corner click on change date and time settings then click the internet time tab at the top then press the change settings button then uncheck the sync with internet time
Clock will not set for correct time. Manually change but this does not work.
Most likely the CMOS (Bios battery), which is a small silver coin shaped battery on the motherboard needs changing. This maintains the correct time when the laptop is switched off. They last for up to 3 years then need replacing. (example in picture)
http://cgi.ebay.co.uk/CMOS-RTC-Battery-Toshiba-Satellite-A105-Series-/270751984156?pt=US_Batteries&hash=item3f0a136a1c
Be careful in changing the battery, If you have not done this before, refer to a computer repair shop.
2answers
When i turned on my computer message RTC battery is low or CMOS checksun is inconsistent press f11 key to set date i have tryed f11 and had it pluged in all night still same message.
Means your CMOS battery is flat and will need to be changed, as that keeps the date and time saved at all times if it dead then every time you turn off the computer the date and time will not be saved and have to re-set it. changing the battery will solve this problem. Kronoguy
Real time clock loses time even while running off of AC. So, I don't believe it is a CMOS battery issue? The model is Toshiba A135 S2276 running Vista Home (32). Also, I have the dreaded self-assigned...
If you once take bios battery out the password issue will be reseted , the time zone of the date and time settings will changed , set the correct time zone first after that set the present timing, the time zone will be available in the time settings window itself , try it you can definitely fix it.
1helpful
2answers
Laptop's clock runs slow.
A near flat battery will cause the laptop to lose the time and date even if you change the BISO time and date, it will still lose time.
To get into the BIOS setup press F2 as you boot up the laptop.
Check the various settings and you will get to the time and date setting, follow the screen instructions to set the time and date.
I suggest you get a new battery installed before you change the time and date.
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
